BPP Vortex Ram Induction System?
Old Oct 17, 2007 | 08:49 PM
bpproducts's Avatar
bpproducts
It is a special Vortex cleanable filter with filtration material at the tip and the sides. We even have a merge cone on the inside to increase velocity.
Cleaning the filter at about 10,000 miles
Ernie
www.BreathlessPerformance.com
Old Oct 17, 2007 | 08:50 PM
Andi's Avatar
Andi
Ernie
Thanks for the quick response.
Is it oiled like a K&N?
Old Oct 17, 2007 | 08:56 PM
bpproducts's Avatar
bpproducts
yes.
Ernie
Old Oct 17, 2007 | 11:03 PM
TTRotary's Avatar
TTRotary
Another happy BPP Vortex customer here. All three of my Vettes have had them. The C6 version is very carefully thought out.
Old Oct 18, 2007 | 12:40 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
Just came back from Moroso drag strip....Hot muggy night. Just took off my OEM air intake and my Vetteair. My car is a 08 LS3, A6 with melrose headers, SLP cat back and a Mike Norris tune. Just added the the BPP Vortex and beat my best previous time by .2 and ran a higher top speed. New best for my car 11.9 @118mph. Previous best 12.1 @ 116mph. Similiar race conditions (DA 2500). Can't wait for some cooler conditions. Car was not retuned after the Vortex was installed. I think that extra air from the Vortex helped me achieve this improvement.
Old Oct 18, 2007 | 08:39 AM
bpproducts's Avatar
bpproducts
Told you that you would go faster, by the way can I use your post in our customer testimonials section?
Ernie
Old Oct 18, 2007 | 04:31 PM
theofel's Avatar
theofel
Ernie
I'm glad you caught this post. I was on my way to tell you in person, but I got side tracked. My 60' was the same as before but the Vortex helped in both mph and ET. DA2500 WHICH WAS IDENTICAL TO MY LAST TRACK DAY. The improvement was about .2 of a second and the top speed also improved by 2MPH. And yes you could use me in a testimonial.
Old Oct 19, 2007 | 08:37 AM
bpproducts's Avatar
bpproducts
Well I guess that proves again that the Vortex will give you big HP #'s to get you 2 tenths and 2 mph faster in the 1/4 mile without a tune for it!!
Ernie
954-925-7725
Old Oct 19, 2007 | 11:01 AM
fright88's Avatar
fright88
I know on most CAI there is a risk of cutting the AC condensor or whatever. You said the placement was different is there the same risk of cutting the condensor?
Old Oct 19, 2007 | 06:17 PM
Fuego's Avatar
Fuego
I'm still torn between this and the VR.Does that scoop on the VR ram the air in better?
Old Oct 20, 2007 | 09:03 AM
bpproducts's Avatar
bpproducts
I can tell you no it does not. The VR has only about 20 sq inches of area in there scoop opening for air flow to enter where the Vortex Ram has about 100sq inches. The Vortex system has been proven on the track to produce greater hp gains by all our customers.
We also have less of a tendency of injecting water into the intake by having the box opening at the highest point and not low to be scooped in.
Ernie
Old Oct 23, 2007 | 06:16 PM
bpproducts's Avatar
bpproducts
Remember the special price of 485.oo shipped ground free.
Ernie
954-925-7725
Old Oct 23, 2007 | 10:02 PM
  #33
kfox's Avatar
kfox
Default BPP Vortex Rammer
I have owned two of them now. One for my 1997 6-speed coupe and now one for 2006 Z51 6-speed coupe. Both are clear. Also, I cut the opening in the shroud. Both were easy installs. I highly recommend this CAI. Personally, I like the clear unit, mainly because I can see if it has become loose, dirty or if there are any papers or other junk that might have been sucked up in the cavity. This has not been a problem, but peace of mind means alot.
This has been the one mod that I know has made a big difference in the performance of my car.
Kfox
Old Oct 25, 2007 | 01:00 PM
  #34
bpproducts's Avatar
bpproducts
Ernie
954-925-7725
Old Oct 25, 2007 | 06:33 PM
  #35
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I do like the look of this system but can someone please post a picture of the lower portion of this system. The pics on the site show the top of the system but I can't find any showing where the air is "rammed" in.
thanks in advance!
Old Oct 26, 2007 | 09:18 AM
  #36
Mike Campbell's Avatar
Mike Campbell
I had a Vortex on my '99 and later swapped it for a VR. As far a performance, I never experienced any better times. I put a VR on my '06 & the car runs great. However, the reason I chose it was price. I can testify the Vortex filter is much easier to clean & service. It's a very good product & you can't go wrong with one.
Old Oct 26, 2007 | 09:56 AM
  #37
jterp's Avatar
jterp
Wow .. I was almost sold on the vararam until i found this post.. Do you offere a pre-cut shroud for this unit? I prefer to keep my stock shroud intact in case i should sell the car.
To BPP Vortex Ram Induction System?
Old Oct 28, 2007 | 11:45 AM
  #38
robl45's Avatar
robl45
yep, people need to get over the cost issue as the LS3 uses z06 type intakes and they all cost the same if not more than the vortex. I should be ordering mine next week with any luck.
Originally Posted by theofel
Just installed it. Previous 06 C6 had Vararam. The BPP Vortex unit is of a much higher Quality and the installation was easier than the Vararam. This BPP Vortex unit is actually less expensive then the competetive units on the LS3's. When you purchase the Vararam for the LS3, you must purchase the ZO6 model, much more expensive than the standard C6. BPP Vortex also came with a coupler that replaces tha stock accordian hose(nice touch). On the bling side--very sexy--carbon fiber one piece Vortex bridge and I chose the clear air box rather than the carbon fiber. This unit appears to be well engineered and appears to have the largest opening in the shroud (10x10)---so that fresh cold air can do its job.
Old Oct 28, 2007 | 11:51 AM
  #39
robl45's Avatar
robl45
precut is a gimmick, what you do is you cut your schroud and then you have a cut schroud. You go to Gene at gmparts direct or your local stealer and buy a shroud. Now you will have an uncut shroud.
  #40
BAADC6's Avatar
BAADC6
Originally Posted by Sativa
Does anyone have any feedback on the Breathless Performance Products Vortex Ram Induction System?
I have one and love it. i have to remove it because I am adding a procharger. PM me if you would like it. I also bought two extra filters. I will give you a good deal. Spare filters were 50 each and system was about 500. It was my first mod and It was great.
