flushing 06 vette brake fluid
Old Oct 11, 2007 | 01:24 PM
Dkay's Avatar
Dkay
Default flushing 06 vette brake fluid
I have a 79 & 06 vette. every year I have flushed the fluid on my 79 since new. One person pumping and me opening and closing bleeders. Is this OK for my 06 or is it necessary to purchase a power bleeder?
Thanks in advance DKAY
Old Oct 11, 2007 | 01:40 PM
AU N EGL's Avatar
AU N EGL
Two person works just fine.
Old Oct 11, 2007 | 03:17 PM
C6~Missle's Avatar
C6~Missle
Do yourself a favor and get the power bleeder. They make them just for that size reservoir.
With the pedal method you run the risk of over-extending the boot inside the master cyl and tearing it, due to the extra length in travel.. not made to extend down that far..
The gravity method also may work fine, have not personally tried it on a vette.. just make sure the MC doesn't go dry... its also slow going.
Old Oct 11, 2007 | 03:19 PM
carpe dm's Avatar
carpe dm
I also have a small hand operated vacuum pump that works well.
Old Oct 11, 2007 | 08:16 PM
Brett Hunter's Avatar
Brett Hunter
However my wife got tired of pushing the pedal so I ordered the Motive brake bleeder last week. I completely flushed the system in no time at all. I did finish up using the two person method for at least two times on each caliper to insure a stiff pedal.
On a side note I used ATE super blue which makes it very easy to tell when new fluid is coming out. You simply use super blue the first time and then switch to their "amber colored" fluid the next time.
Old Oct 12, 2007 | 12:45 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I recently bought the Motive bleeder as well. It's not expensive and it makes it easy to do it yourself. I use Motul 600 fluid which seems to hold-up well on the track.
Old Oct 12, 2007 | 08:49 AM
Miaugi's Avatar
Miaugi
Originally Posted by Wayne O
I recently bought the Motive bleeder as well...I use Motul 600 fluid which seems to hold-up well on the track.
To flushing 06 vette brake fluid
