c6 Vs zo6
What's more, I don't think they could out run a Z in my car either. That low end torque of the Z does wonders for the 1/4 mile times.
I ran 11.81 with gears and full boltons, which was a record for MZ6 trans at one time. Having driven my cammed car now, I bet I'm only going to run 11.5 on a great day. Stock Z's with a sharp driver and drag radials can run lower than that all day long.
If someone sends me a stock Z .drf dyno file I'll overlay it to my car's below. The Z's have more torque below 4k and that makes a huge difference.
I don't see why cam only c6's can't run very low 11's with a good set of drag radials.
I also think we should be seeing more H/C ls2 or ls3's running mid-high tens.
the ls3 car will have trouble on the 285 runflats, but once it has shoes, a good driver ought to be able to pull outstanding times
I have an LS3 with LG's, Vararam, and LG Tune and my numbers are as follows
422.6 RWHP 424.7 RWTRQ on a dynojet
will post up the dyno if anyone is in doubt
i think the best thing that i can do ,, without spending money is buying a Procharger and Run it With 8 psi
and i think that is the best Soloution !
better then adding and adding and adding and then at the end ! the Zo6 is faster
but do i need to change my Chumber ? or keep it as the gm one ?
I also recently talked to my tuner about adding more cubic inches to my motor which was going to cost about the same as what you will be paying for the procharger. He was talking about stroking a LS3 out to 416 cubic inches. With everything he said the project woud be in the range of $8K to $10K price range with 500 - 525 RWHP and lots of low end torque. If you are still looking at a naturally aspirated engine, this may still be an option. Im sure this would give a Z06 a run for the money!
The Procharger sounds like a lot of fun as well. Please keep us posted as to what you decide to do with your mods...Kevin
My Z is a modded with bolt-ons only. LPE conservative cam package. No head work or bottom end work.
525RWHp.
I have laid waste to turbo charged c6's withh 600RWHP. Procharged C5z's with 620RWHP. I was beat, not by much by a C6 with a 403 forged bottom end, with a procharger and Methyl kit. He's making nearly 700 RWHP. Now that was a race.
You see, the C6's need considerably more HP than just matching #'s on the dyno to match the RAW power of this fast reving 427. Trust me this engine is
.. Build a forged 427. The heavier rods and pistons won't rev like this engine. This is the ultimate NA motor IMO ever built.Although with the forged components a 250 shot could also be an option.
525RWHp.
"I have laid waste to turbo charged c6's withh 600RWHP. Procharged C5z's with 620RWHP" I don't see it =/
the driver is 80 percent of the win not the car
525RWHp.
Peak horsepower doesn't tell the whole story. Power under the curve, weight to power ratio, and ability to rev quickly all add up. Lightweight rotating assemblies/pistons are hard to catch. They "doth not suffer ill tunes or fools." Especially without adequate octane or tuning. I personally would prefer forged internals as you never know when you'll get bad gas and/or detonation, but that's me.
San
sorry i mean chumber = intake
i will post my dyno after i finish my car
because i have a problem which is no one know about it !
you can help me so i can take my car to dyno jet and post the numbers
,,, i will write my problem so everybody can read
i changed my Clutch master ( the Down clutch pump ) 3 times !
everytime i change it ! i use the car for about 2 weeks ,,, a little racing ! then Boooooooooooooombs ,,, no oil in the clutch and the pedal goes fully down and i cant use the clutch at all ! i took it to the Gm dealer in my country so they change the clutch pump ,, they change it but still the same ,, so if any body of you guys can help me with that i will be very greatfull !!
otherwise ! i will sell my car and buy a camaro ,, or C5 cuz really ! this car has pissed me off !! i am sending it to the garage more then driving it !
cheeeeeeeeeeeeeeeRS !
and really hope i post the dyno in the next few days !
Sorry to hear about your clutch issues. You may want to start a separate thread post about this topic.
Intake/TB spacer
Long Tube Header/catless x-pipe/mufflers
aggressive cam/ported head
dyno tuned
big brakes/sway/wheels/tires
for the price.. maybe you should just buy a factory z06, lol
In this case, the Z driver was new to the car. I've got a few runs under my belt. But watch him run me down. Equal drivers, even now with my Cam and 436 rwhp, that Z is gonna whoop my modded C6. The driver makes a huge difference in these high powered, hard to launch cars. But you need heads + cam to give a stock Z a run for their money, and you better be a sharp driver.
A cam alone won't do it. I would love to see the LS3 with the full package running through the 1/4 mile. Maybe a slight edge over a stock C6 Z06?
The dealer wanted my 2006 C6 + $42,000 for a Z06.
I thought I could do a few engines mods for about 1/4 of thet cost and boost HP substantially.I have all the mods you have listed with the exception of ported heads and I am $6,300 into my engine project. I'm wondering if heads will make up the difference in low end torque where I fall short when compared to the LS7? I'm at 446 RWHP and 404 RWTQ. If the LS2 cannot be built to be comparable to the LS7, I wonder why we do not see more LS7 engine transplants? It appears some members posts in this thread it is believed that no matter what you do do to your LS2 including stroking it, you will never reach the power of the LS7. I do not quite understand that.
Does GM sell the LS7 short block and if so how much does it cost? I have only seen the LS7 Crate engine for $12,500. I'm not sure I want to sink over $3K into heads with installation if I am still falling short of my goals. I'm think my next mod will be more in the area of adding cubes maybe 427...
