OnStar removal
Old Oct 18, 2007 | 07:24 PM
martialman.45's Avatar
martialman.45
4th Gear
Default OnStar removal
Is it hard to take out the onstar system? TIA guys
Old Oct 18, 2007 | 08:29 PM
dbradley's Avatar
dbradley
Don't know why you would want to "take it out". Why not just unplug the antenna if you want to disable the thing. That way if you ever sell its there for the next owner.
Old Oct 18, 2007 | 08:34 PM
saplumr's Avatar
saplumr
If you don't want it....cancel it, don't take it out.
Old Oct 18, 2007 | 09:32 PM
martialman.45
4th Gear
I actually dont have a car yet, just shopping for my graduation present early. Just want a sports car without onstar, radio, cup holders etc. no one seems to make one anymore.
Old Oct 18, 2007 | 09:35 PM
carbuff's Avatar
carbuff
Per my stereo install experience this weekend, it seems that when you remove the Onstar box, the computer goes nuts. It must be a pass-through path for the body-link network.
So, while my stereo worked great, I couldn't start the car...
It's a small / lightweight box, so you won't gain much by trying to remove it...
Old Oct 18, 2007 | 11:46 PM
Gold Z's Avatar
Gold Z
Veteran: Marine Corps
If your car should ever get stolen you'll sure wish you had On-Star.....
Old Oct 18, 2007 | 11:52 PM
HemiSport's Avatar
HemiSport
i have a 07 z51 no on star to be found
Old Oct 19, 2007 | 06:44 AM
timd38's Avatar
timd38
Ditto, but 06
Old Oct 19, 2007 | 07:34 AM
avacorvette's Avatar
avacorvette
From: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
My brother has a 08 and I asked Onstar if it can be disabled by pullin the fuse or cutting wires. She said "NO! it will disable the car..the car will not start"
Old Oct 19, 2007 | 08:46 AM
Walt White Coupe's Avatar
Walt White Coupe
Just remove the antenna from the windshield. Slide it to the right and it will unsnap from its mount and then just disconnect the wires. Done.
Old Oct 19, 2007 | 09:45 AM
NHRA95's Avatar
NHRA95
This will show you exactly how to disable it.
http://www.digitalcorvettes.com/foru...ad.php?t=84434
Old Oct 19, 2007 | 10:55 AM
Kent1999's Avatar
Kent1999
If you (or anyone) want to sell the OnStar pieces, PM me. I'm buying.
-Kent
Old Oct 19, 2007 | 02:37 PM
timd38's Avatar
timd38
I have a base mirror that I will sell you at a deal that doesn't have On*Star.
Old Oct 19, 2007 | 02:57 PM
LS1LT1's Avatar
LS1LT1
Not if you don't actually discover that it was stolen until days later.
On Star only helps in a stolen vehicle situation if it's reported right away (before the perpetrators can disable it that is), I sometimes don't see my C6 for weeks on end so On Star might not help all at all times in that regard.
Old Oct 19, 2007 | 03:04 PM
LS1LT1's Avatar
LS1LT1
Wow, I didn't know it was so tied in like that, I really don't want On Star (or XM Radio) at all so this will continue to be a small dilemma for me and any future new Corvettes I might be considering.
Did you weigh it at all, it looks like it could be a couple of pounds or so but maybe not.
Old Oct 19, 2007 | 04:08 PM
martialman.45
4th Gear
I'm surprised no one has an aftermarket plug or something yet to remove the system,they could make a small fortune. I have seen one to remove the radio or change it out to an aftermarket unit though.
Old Oct 19, 2007 | 04:30 PM
carbuff's Avatar
carbuff
The XM box and the OnStar box combined can't weigh more than 5 pounds. There just isn't much to them.
As for making a harness to remove them, I'm pretty sure you are in the minority. You can order a car without them, but all cars come with a radio. And I expect FAR more people want to replace their stereo with something else than care about removing the OnStar. The only reason I tried was that I wanted to mount an amp in that spot. And heck, I didn't even realize it was OnStar I was trying to remove until the car wouldn't start.
You probably could unplug the antenna wire to the box without upsetting the car's computer, and that would pretty effectively (although not completely) disable it.
To OnStar removal
Old Oct 19, 2007 | 06:39 PM
Dbl6gun's Avatar
Dbl6gun
Default OnStar is EASY to disable....
Originally Posted by LS1LT1
Wow, I didn't know it was so tied in like that, I really don't want On Star (or XM Radio) at all so this will continue to be a small dilemma for me and any future new Corvettes I might be considering. .
a) Remove the one and only fuse for OnStar
b) At the back of your car, open the right rear storage compartment, the OnStar module is in there, you might have to pry up the carpet to get at the VCIM (OnStar Module).
c) UNPLUG connectors J1, J2 & J3 ...and UNPLUG the 2 antenna connections. One antenna is for OnStar's GPS signal. (If you have a 3LT car w/NAV, don't worry, the NAV has it's own GPS antenna!) The second antenna is OnStar's Cellular Phone Antenna.
d) The 4th connector, J4, is part of your car's Computer Network Data Bus. LEAVE that connector alone! If you unplug J4, your engine will not start. If you REALLY want the OnStar module out of your car THAT bad, you NEED to install a termination resistance! The "easiest solution" is to just leave the OnStar module in the car with J4 connected! The OnStar module will be TOTALLY DEAD!!
If you EVER plan on reselling your C6, just leave the OnStar module in place and re-connect the connections your previously disconnected, PRESTO, OnStar is re-enabled again.
For even more detailed information about disabling OnStar, visit:
Old Oct 19, 2007 | 07:49 PM
martialman.45
4th Gear
thanks Dbl6gun for the detaild info.
Old Oct 19, 2007 | 11:40 PM
Vette_DD's Avatar
Vette_DD
You cannot order an 08 C6 without them. OnStar & XM Radio are standard on EVERY 08 C6.
