Why no gear indicator?
Old Oct 29, 2007 | 08:00 PM
Maui's Avatar
Maui
St. Jude Donor '08
Default Why no gear indicator?
I don't understand why GM doesn't include an gear indicator in the dic for manual transmissions. I have found myself trying to take off in 3rd gear many times. I can't believe the computer doesn't know what gear you're in.
Old Oct 29, 2007 | 09:41 PM
reidry's Avatar
reidry
Gear indicator is really more of a manually shifted automatic thing like the sporttronic, tiptronic, etc. I've been driving maunal cars since I got my learner's permit (ages ago) and never had the issue ... drove a buddy's 2008 Z06 a few weeks back, seemed like the gate spacing was near perfect.
Maybe just a little more left pressure on the shifter when going for first?
Ryan
Old Oct 29, 2007 | 10:16 PM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
Be nice to see it in the h.u.d. also.
Old Oct 29, 2007 | 10:34 PM
runutzzzzz's Avatar
runutzzzzz
Never had that issue...
Left and up!
Do you have a short shifter?
Old Oct 30, 2007 | 09:27 AM
FloydSummerOf68's Avatar
FloydSummerOf68
When you're at a light just check your gear real quick...only takes a second to pop it down and see if it'll go left anymore.
Old Oct 30, 2007 | 11:35 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Been driving sticks since early 60s, never consideed a need for a a "helper" like this.
Old Oct 30, 2007 | 01:44 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
I can't imagine ever having that problem in a car.
Old Oct 30, 2007 | 03:31 PM
Vette_DD's Avatar
Vette_DD
I could have used one the first 2-3 days I had my 05 PR MN6, since it was my first time to shift a manual tranny in about 30 years, but I got used to it.
Old Oct 30, 2007 | 03:34 PM
Maui's Avatar
Maui
St. Jude Donor '08
It does not happen too very often but for another ten cents they could probably indicate the gear on the hud. I have a colorado pickup for my company car and it does not provide the exterior temperature even though the vehicle is pretty well loaded. I know for a fact that the computer does monitor the exterior temps because the ac unit will not operate when the exterior temp drops below freezing.
Old Oct 30, 2007 | 04:06 PM
joegengsta's Avatar
joegengsta
i can't believe you try to take off in 3rd gear, el oh el!
i never have this problem. go buy an automatic?
Old Oct 30, 2007 | 04:11 PM
FloydSummerOf68
The C6 has enough grunt where it can get out in 3rd gear anyway...just dont do it anymore :P
Old Oct 31, 2007 | 05:46 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You can set a rev limiter for each gear separately on a manual trans car with HP Tuners. That leads me to believe the car must have a sensor to know what gear its in, so maybe this would be possible?
But I don't need this mod - with 3.90 gears it doesn't really matter what gear you take off in. I take off in 2nd a lot if the trans won't go into first, which happens from time to time.
Old Oct 31, 2007 | 05:52 AM
timd38's Avatar
timd38
It would be nice, but I never had a car with it, so I don't miss it.
Lets talk compasses........
Old Oct 31, 2007 | 06:04 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have a compass in my mirror and a nav system in my dash! Do love that nav even if it pales in comparison to the nav system in my wife's Honda Odyssey.
Old Oct 31, 2007 | 11:58 PM
Maui's Avatar
Maui
St. Jude Donor '08
I have 4.10's so the car will take of in 3rd if there is no slope.
Old Nov 1, 2007 | 12:25 PM
Wayne O's Avatar
Wayne O
CF Senior Member
No need to even do that...I've already downshifted into 1st gear before coming to a complete stop. I know which gear I'm in when sitting at a light.
It wouldn't matter to me if GM included a gear display but I think you just 'know' what gear you're in at any given time.
Old Nov 1, 2007 | 01:23 PM
Ken07AOVert's Avatar
Ken07AOVert
St. Jude Donor '11-'12
Default manuals
I am new to the 'new' vettes, but certainly not new to stick shifts. I do not know if it is instinctively knowing what gear I am in or muscle memory taking over, but I always know what gear I am in.
I think a gear indicator for a manual would be like a 'engine on' light or 'window down' indicator. Maybe a 'wheels turning' gauge?
You are messing with us, right? Good one! You got quite a few guys.
To Why no gear indicator?
Old Nov 1, 2007 | 02:21 PM
Buffy's Avatar
Buffy
It doesn't have a sensor (except for reverse), so it doesn't know what gear you're in until you're moving. Then it can calculate the gear from the known values of engine RPM and rear wheel RPM. But this doesn't do any good when you're sitting stopped at a light and slip it into first. Or third, as the case may be.
Old Nov 2, 2007 | 03:57 AM
97vetteman's Avatar
97vetteman
If your coming to a stop light you should be changing down through the gears anyway, you should be making 2nd gear your last selection as you come to a stop and then it's a natural thing to push the stick forward into first gear!
Anyway I can't be bothered to change gear so that's why I have a A4!
Old Nov 2, 2007 | 09:19 AM
johnodrake's Avatar
johnodrake
Moderator
There is an engine on indicator - Tach and a wheels turning gage - speedometer I am looking for a top down indicator though.....
