Traction control/competitive mode
Old Nov 2, 2007 | 06:53 PM
14 Red Z51 Vette's Avatar
14 Red Z51 Vette
Default Traction control/competitive mode
My wife conned her way into picking up my new 08 Z51 auto/paddle Vette while I was out of town. I had plans with the service dept. to put the car on a lift and go over it and ask questions at delivery. I know you can push the button and turn off the traction control. I held it down and it turned off the traction control and active handling?. I pushed it again and it went into competitive mode. I know what happens when the traction control is off, but what happens in the other modes?
Old Nov 2, 2007 | 07:49 PM
Danny318's Avatar
Danny318
It explains it in the manual, but from what I remember. Traction controll off leaves the traction control off but leaves active handling intact. Comp mode does the same as that, but I think it leaves a lot more tolerance in the yaw control, so you can slide around more without it trying to straighten you out. Both off, well then everything is off.
Old Nov 2, 2007 | 08:08 PM
willhaveC6's Avatar
willhaveC6
That's pretty much it ---- In case your wondering ABS works all the time
Old Nov 3, 2007 | 10:44 AM
goatts's Avatar
goatts
A little advice. For street use leave AH on. No reason to ever take it off. Makes a HUGE difference with car control.
Old Nov 3, 2007 | 10:47 AM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
or yul b sorry
Old Nov 3, 2007 | 11:51 AM
14 Red Z51 Vette
If I understand correctly, if you turn off traction control, active handling is still on. If you are in competition mode, active handling is still on, just less of it, correct?
Old Nov 3, 2007 | 05:41 PM
goatts's Avatar
goatts
Yes. You have to hold down the button to turn it off.
Old Nov 4, 2007 | 12:11 PM
vvette_c6's Avatar
vvette_c6
i tried my car with these modes on and off
when i tuned my car with the cam i rolled 40K/h and accelerated
the car went crazy but the actinve handing CUSION came on
and it holded the car
i think even when the traction on if the car start playing the computer will hold it
Comptitive drive
i noiced that when i drive in a race ,, Rolling 80Km/h
and the car start drifting when i change the gear from 2 to 3 ( Rpm 6500)
instead of dropping the rpm to 5000 or 5100
it goes down to 4500 to hold the car and let it stop drifting
this is what happened to me from my experience
some one can correct me if i am wrong
but at all ,,, in the C6
you cant Stop the traction of the car !!!
even when i turn it off in all the wife ,, after the drifting
i always have a caption about the traction and Service break and traction
this is another thing i noticed
Old Nov 5, 2007 | 05:01 PM
timafey's Avatar
timafey
Is comp mode also a standard option in the 05 C6? or does it only come with 1sb package/ z51?
Old Nov 6, 2007 | 10:38 AM
vvette_c6's Avatar
vvette_c6
dunno man
mine is 2006 z51 package
Old Nov 6, 2007 | 11:27 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I have the 1SB option but I believe TC/AH/Comp Mode is a standard feature with all C6 Corvettes. If you have a 'base' 05 it would be simple to find out.
Old Nov 6, 2007 | 11:37 AM
oneblackvette's Avatar
oneblackvette
Old Nov 6, 2007 | 10:22 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Comptitive drive
You can completely turn off all of the active handling and traction control by holding down the button continuosly for more than 5 seconds. The display will show AH TC OFF. Be careful if you do this as there will be no electronics to save you if you make a mistake.
Old Nov 6, 2007 | 10:43 PM
timafey's Avatar
timafey
So does anyone else know if the 05 base has comp mode and how to engage it?
Old Nov 9, 2007 | 08:57 PM
C6400hp's Avatar
C6400hp
yes they all have it, just push the button 2 times or until it says competition mode on the display.
To Traction control/competitive mode
