Headers No matter the Brand!
Old Nov 15, 2007 | 07:17 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Default Headers No matter the Brand!
Re torque your Header bolts, Mine were all working loose at 1000 miles.
re-torqued mine to 20 foot-pounds! Important to have a good seal!
Old Nov 15, 2007 | 08:29 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
Thats why we sell these
http://marylandspeed.com/stage-8-loc...00-p-1006.html
Old Nov 15, 2007 | 08:39 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Woa, 20ft/lbs
http://forums.corvetteforum.com/show...ht=header+bolt
http://forums.corvetteforum.com/show....php?t=1660507
I would not go beyond 18 ft/lbs and even less than that with a greased bolt.
Old Nov 15, 2007 | 09:02 PM
SpinMonster's Avatar
SpinMonster
Shows how often I drive my car. Since the install of the new headers, I havent been in the car. Thats right, I drove it home and parked it. Sits there in a sleep state. Thanks for the reminder.
Old Nov 15, 2007 | 09:06 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Goign to check mine !
Old Nov 15, 2007 | 10:02 PM
rws.1's Avatar
rws.1
12k miles since my install... will have to check them.
Old Nov 15, 2007 | 10:42 PM
tjwong's Avatar
tjwong
I retorque after three over night cool downs. After that I check them a couple times a year and never had one work loose.
I looked at those other threads concerning broken bolts and torque wrenches. No one mentioned what brand or type of torq wrench they were using. Most of the 3/8" wrenches have a range starting at 10 ft/bs to 100 ft/lbs and they are inherently inaccurate at the lower end of the scale. Also I have found Sears Craftsman to be a POS, and then there are the Harbor Freight JUNK. All of my wrenches are Snap On, some are the beam and lever a couple spring click type but all my current wrenches has been replaced with their new electronic wrenches. These are by far the most accurate TQ wrenches I have ever used and they are repeatable from day to day.
I can't even tell you how many headers I have installed here in my shop, and using my trusty Snap On electronic TQ wrench I have never ever broken a GM exhaust manifold bolt.
The only TQ wrenches I recommend are those made by Precision Instrument who makes them for Snap On, Cornwell and others and their own name brand. Yes they cost a heck of a lot more than Sears or Harbor Freight, but for me there is no other wrench!
Old Nov 15, 2007 | 11:02 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by MarylandSpeed
I couldn't keep the header bolts tight on my '79 Camaro. Then I installed a set of those stage 8 bolts 15 years ago and they haven't loosened up yet.
Old Nov 15, 2007 | 11:07 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
So how much should you torque them down to?
To Headers No matter the Brand!
