Header gaskets
Old Nov 17, 2007 | 09:59 AM
tloon's Avatar
tloon
Default Header gaskets
Doing the Kooks install today. Should I use the supplied gaskets, or reuse the factory stainless that have only 5200 miles on them? I have seen many posts saying reuse the factory units.
Old Nov 17, 2007 | 10:43 AM
BAADC6's Avatar
BAADC6
Reuse the factory gaskets....DO NOT use the crap you get with the headers. I used the ones with the headers and blew them out. Reuse the factory gaskets!!
Old Nov 17, 2007 | 11:05 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Nov 17, 2007 | 04:34 PM
glennhl's Avatar
glennhl
I've heard a lot of people reusing the stockers. Or you can do like me and go buy brand new OEM gaskets from your local Chevy dealer. They are pretty cheap.
Old Nov 17, 2007 | 06:13 PM
toro1966's Avatar
toro1966
+1, I NEVER like to reuse any gasket. I know for the headers it will work, but for a few bucks, get new OEM ones from the dealer.
Old Nov 17, 2007 | 07:09 PM
SpinMonster's Avatar
SpinMonster
I lost count after 14 but that is how many times I reused the factory header gaskets and they are still working fine with my new headers.
Old Nov 18, 2007 | 12:22 AM
Bludog's Avatar
Bludog
New factory gaskets every time!!
Old Nov 18, 2007 | 12:49 AM
SpinMonster
Multi layer steel gaskets are designed to be reused.
Old Nov 18, 2007 | 08:33 AM
lemans 07's Avatar
lemans 07
I have installed 2 sets in the past couple months and both times I reused the factory gaskets. No leaks
Old Nov 18, 2007 | 08:39 AM
LSCHLEM's Avatar
LSCHLEM
A new set of OEM Gaskets will run about $35.00
Old Nov 18, 2007 | 11:09 AM
tjwong's Avatar
tjwong
Reuse the factory MLS style gaskets. They will not blow out or burn out, I use them in every header install I have done. Not ONE LEAK has occured.
To Header gaskets
