cams for the LS3
Depending on what you want to go with we have packages that range from tame to extreme.
This is a 2008 M6 with LG Pro Long Tube headers, K&N cold air intake, and G7X4 cam package.
We can put any kind of package together that meets your needs. Let me know how I can help!
Anthony,
Are we going to be seeing any more LS3 testing info from you Guys anytime soon?
Is the car that posted the 506 above ever going to be taken to a dragstrip? I would love to see what kind of trap speed that it is capable of.
Thanks...
Anthony,
Thanks...
We are working on some drag runs now, the 36 degree weather and rain are not helping us out any though.
I have been trying to get ahold of Lou from LG for cam install ideas such as the compression issue. I would like to know what the DCR is of the cam as it is installed here and what it could be if it were bumped 1/2 a point or so. I would imagine aside from a 7hp/10rwtq at peak, the 3k area would jump more like 20rwtq.
What static compression can be run with this cam Anthony? I know you rent the fly-cutting tools/head and will do that if it would make for a bigger jump.
A big cam with 10.7:1 static compression should make a curve like that.
I'm with you in thinking that maybe a bump in compression could help or an adjustment in timing at this RPM range relative to the rest of the timing curve. But myself, I'm thinking cam design, ramp speed Vs duration Vs lift and moving the intake centerline around.
Not having imperial flow data to observe the velocity plotted against the lift curve I can only make assumptions which, as you know, is like throwing darts.
To keep this relative to the chart posted I would be interested to know if the heads were cut to reduce chamber size or installed as is with the resulting drop in compression.
If the heads are surfaced to reduce chamber size what does it do to the flow and what restriction does the smaller bore have on the flow as it exists the valve relative to the larger bore of the LS3. History tells us that the smaller bore should reduce flow sightly, but what effect would it have if the heads are angle milled and the subsequent slight change in valve angle relative to bore centerline. Of course, the deck thickness of the L92 head isn't the thickess.
Also,
Due to the relative size of the port is it more advantageous to use a more aggressive ramp speed to initiate cylinder filling sooner relative to what is used in a cathedral port or perhaps a narrower lobe center w/shorter duration @ .050 with more lift.
Questions, Questions, Questions.......
It took some time but the L92's proved me wrong. What I was right about was that the tune and fly-cutting were needed to get it all to work right. These steps make it more expensive and the huge savings everyone yaps about dont exist for a max effort H/C install. Some porting to the exhaust runner is easy for the DIY'er to do on his own. I have seen 230cfm acheived. A better valve job, fly cut and compression costs, and millingget you better than cathedrla head power when you factor in that the forthcomming L92/LS3 FAST manifold is on the dyno now at Comp. So ported L92's with real springs = 2k. The new FAST will be 800-850. AD in flycutter tools or the cost of a shop doing it and you have the same costs in the end. Dont expect the L92 tune to come in a few hours. Mine took 15 before I said, OK they are better than my old heads.
Milling costs you flow especially on the 4" bore since the head combustion chamber is bigger than the cylinder bore and you minimize that. Once ported as with the porting from WCCH, the heads intake to exhaust ratio is pretty much the same as AFR, ETP, TF's, and ported 243's. WCCH gets 355cfm/235cfm. Check what the ETP's do on the 225.
This actually does hold true on stroker motors. LSK lobes though initially start out with a ramp rate of 50 are mor aggressive in the midlift than XER lobes. 500/500 has been seen with stock heads and a 4.03 bore with a 232/236 LSK cam. I dont recall the LSA but I do remember the 425-450rwtq below 3k rpms.
The low TQ does seem to be superior. RPM's max effort H/C LS2 with that 238 cam had 480rwtq at peak. Compression is important with big cams.
