C6 air intake.
Old Dec 21, 2007 | 04:49 PM
ZIPNBYU's Avatar
ZIPNBYU
Default Cai
If truely want a "cold" air intake get a vararam, it draws cool air from in front of the radiator, the K&N is the that filter inside the engine compartment only breath in heated air, which does not help in the performance of the engine, as always heat kills.
Old Dec 21, 2007 | 04:53 PM
ZIPNBYU's Avatar
ZIPNBYU
Default Cai
If you truely want a "cold" air intake. get a vararam, it draws in cool air from in front of the radiator, the K&N gets heated air from inside the engine compartment and the engine only breaths in heated air, which does not help in the performance of the engine, as always heat kills, so does not proof reading your first message.
Old Dec 21, 2007 | 06:10 PM
Larry R's Avatar
Larry R
I am interested in a CAI, and have read with much intrest the different opinions. I am leaning toward a Vararam, but wondered if anyone has a Vortex Rammer and what they think of it? Thanks
Old Dec 21, 2007 | 07:03 PM
bosco 08's Avatar
bosco 08
if cold air is the goal here why can't you just cut a hole in the radiator shroud next to the filter seems other than the scoop part of it that's all a Vararam does. flame suit on.
Old Dec 21, 2007 | 07:04 PM
timd38's Avatar
timd38
You don't get it. If you don't spend money, how can it work.
Old Dec 21, 2007 | 07:06 PM
NHRA95's Avatar
NHRA95
Old Dec 21, 2007 | 07:14 PM
bosco 08's Avatar
bosco 08
no kidding, there is a lot i don't get. maybe i'm missing something here but looking at my 08 it sure looks to me like you could cut a section of the radiator shroud the exact size of the filter inlet and if it really bothered you you could also seal the housing to the shroud. i mean GM spent a lot of money to keep the intake noise down as well as flow enough air for 436 hp how much is really there with a $400 intake? just the cold air alone would probably make the biggest difference in performance unless you had more mods.
Old Dec 21, 2007 | 07:48 PM
bosco 08's Avatar
bosco 08
looks like it's already been done from stock inlet w/cold air then to after market filter w/cold air not bad.
http://public.fotki.com/ttschwing/co...air-cold-air-/
Old Dec 22, 2007 | 01:21 AM
bosco 08's Avatar
bosco 08
after further review i see that Vette-Air will save me a lot of work.
