C6 1/4 Mile Performance Challenge
Old Aug 16, 2008 | 06:29 PM
  #3041
Hllywood's Avatar
Hllywood
Sorry if I've missed it. But how many C6's have gone 9's in the 1/4...on a 18" or larger wheel?
Anyone?
Old Aug 17, 2008 | 12:43 AM
  #3042
LS1LT1's Avatar
LS1LT1
As far as I know, only one ('non Z06') C6 has gone 9s, the yellow Cartek supercharged car.
And no one has done it on 18s.
Old Aug 23, 2008 | 01:28 AM
  #3043
06C6FVR's Avatar
06C6FVR
I havent posted in a while, havent run the car since march, right after the gears and new stock clutch that was replaced under warranty.
That day, it ran 12.10 @ 117 (lost the slip)with a DA of around 800'
Today, with a DA of over 2000', it ran 12.07 @115. It was hot and humid in Houston tonight, with 88 degree temps, with around 85% humidity, and no wind...We were all soaked from the heat. I really didnt believe the car would run better than a 12.4 today...but I was pleasantly surprised to turn in a new best on such a bad air day!!
I finally found the right pressure for this car for the DR...15 PSI...On the run, it spun sideways out of the hole, grabbed 2nd, it straightened out and just went!! ... It felt good, and I knew it was a good pass, with a 1.76 60', which is also a personal best for this car.. (best for my 06 was 1.72)... I think the car just needed to loosen up a bit after the new parts.... I cant wait til December on some 50 degree days... Right now i think it will go 11.7's with some negative air.
Tommy, please change me on the list
Daren
For those who might ask, here is the car and mod list
07 Coupe, Non Z51 M6
Z06 Body kit, wheels tires and brakes
BFG drag Radials (bald)
3.90 Gears
CAI
Z06 Exhaust manifolds
Z06 Mid and H-Pipe (3")
stock over axle pipe,
Magnaflow 14336 Weld in mufflers
160 Thermostat
Tuned. (still could be tweaked a bit...not as much timing as it could use)
380 RWHP, 375 RWTQ
Old Aug 23, 2008 | 07:10 AM
  #3044
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Nice pass Daren.
Old Aug 23, 2008 | 07:33 AM
  #3045
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Daren
3.90 Gears
CAI
160 Thermostat
380 RWHP, 375 RWTQ
I think you are dead on with your estimate - I ran a best of 11.7 with 386/379 in some 1000 DA air. And don't underestimate the benefits of some new DR's, I find a new set will give me an extra tenth and much less risk of a spinning 1.9. After about a year mine just aren't as good as new even though they aren't bald.
Great gains from the Z06 manifolds and mid pipe BTW! That is a great option for folks who have tests they have to worry about.
Old Aug 25, 2008 | 08:17 PM
  #3046
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order.
________________________________________ ________________________________________ _______
NEW or IMPROVED ELASPED TIMES
12.07 @ 115.31 06C6FVR
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 Z51 M6 - (2690)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.23 @ 112.86 - 940CACC - 08 Z51 A6 - (2880)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.35 @ 117.47 - Bain - 08 A6 2.73 npp - (2759)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 117.11 - EZ28 - 08 Z51 M6 - (2735)
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.49 @ 115.54 - 1.8T - 08 Z51 M6 - (2314)
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.52 @ 114.44 - Pettvette - 08 A6 - (2842)
12.54 @ 114.67 - Proney - 07 M6 - (2886)
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4 - (60)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6 - (51)
12.66 @ 113.61 - CFP40 - 08 A6 2.73 npp - (2834)
12.66 @ 113.03 - Mdrrandall - 07 Z51 M6 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 Z51 A6 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 Z51 M6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 Z51 A6 - (907)
12.79 @ 112.17 - Jchazr - 05 Z51 M6 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 Z51 A6 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 Z51 M6 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.83 @ 109.44 - Tommy D - 05 A4 3.15 - (114)
12.84 @ 112.98 - Proney - 06 M6
12.85 @ 114.53 - Mr Z51 - 06 Z51 M6
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 F55 A4 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 Z51 M6 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 F55 A4 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 Z51 M6
13.25 @ 110.60 - C6 Matt - 05 Z51 M6 - (122)
13.26 @ 108.59 - Sfadchi - 06 Z51 A6 - (888)
13.26 @ 105.30 - Joeking - 05 Z51 A4 - (661)
13.30 @ 107.00 - Shurite44 - 06 Z51 A6 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 Z51 A4
External Engine Modifications (Bolt-Ons)
10.92 @ 123.63 - Dennis50NJ - 05 Z51 A4 - CAI, CB, conv, hdrs, 3.73, tune, DR - (2540)
11.44 @ 119.11 - Theofel - 08 A6 - CAI, CB, conv, hdrs, 315, tune, DR - (2108)
11.47 @ 121.93 - Jbsblownc5 - 08 M6 Z51 - CAI, CB, Hdrs, ported int, 3.73, tune DR - (2504)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, CB, Hdrs, ported int/tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 Z51 M6 - CAI, DR - (1852)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 Z51 A6 Npp - El wp, hdrs, tune - (2175)
11.76 @ 119.00 - NastyC6 - 05 Z51 A4 - CAI, conv, hdrs, 3.73, ported int/tb, tune
11.77 @ 121.58 - Red06vette - 06 Z51 A6 - CAI, CB, hdrs, ported int/tb, tune - (2179)
11.77 @ 121.41 - XStang - 08 A6 Z51 - CAI, Tune - (2522)
11.80 @ 118.62 - 8850 - 08 A6 2.73 NPP - CAI, hdrs, tune - (2012)
11.81 @ 118.76 - Joe G - 05 Z51 M6 - CAI, hdrs, 3.90, ported int, tune - (1874)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, CB, hdrs, conv, tune, DR - (839)
11.88 @ 119.97 - HPAvette - 08 A6 - CAI Hdr tune - (3032)
11.94 @ 117.99 - JimSpeed - 06 Z51 M6 - CAI, CB, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 Z51 M6 -CAI, hdrs, ported int, bilstein shocks, tune, DR - (2163)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970)
11.99 @ 120.44 - 1.8T - 08 Z51 M6 - CAI, CB, Hdr, tune, DRs - (2471)
11.99 @ 118.51 - JMT1669 - 06 A6 - CAI, CB, tune - (2176)
12.01 @ 116.00 - Mr Z51 - 06 Z51 M6 - CAI, CB, hdrs, ported int, tune, DR
12.03 @ 120.42 - Quikag - 08 Z51 M6 - CAI, CB, hdrs, tune - (2529)
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, CB, hdrs
12.03 @ 118.43 - Glennhl - 06 Z51 A6 - CAI, hdrs, ported int, tune DRs - (2277)
12.04 @ 114.01 - 06C6FVR - 06 Z51 M6 - Mufflers, tune, DR - (1301)
12.05 @ 117.67 - C5pilot - - 07 Z51 A6 - CAI, Tune - (2598)
12.05 @ 117.02 - CYA Vett - 05 F55 M6 - Hdrs
12.07 @ 115.31 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 Exhaust, Muff, Tune, DR - (2048)
12.08 @ 117.00 - Forrest - 06 Z51 M6 - CAI, CB, hdrs, tune, DR - (1449)
12.13 @ 115.15 - Ben Diss -07 F55 M6- CAI, hdrs, Nitto Ivos, tune - (1919)
12.17 @ 119.00 - RHecox - 06 Z51 A6 - CAI, CB, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, Kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 Z51 M6 - CAI, CB - (1822)
12.18 @ 114.00 - Toptoneone - 06 Z51 M6 - CAI, CB, hdrs, tune DR - (1824)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, CB, hdrs, Intake - (659)
12.26 @ 116.65 - Waveblaster785 - 06 Z51 A6 - CB, hdrs, Intake - (1118)
12.28 @ 115.91 - C5Pilot - 07 Z51 A6 - CAI, DR, tune - (2551)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, CB, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 Z51 A6 - CAI, TB, DR - (1473)
12.41 @ 115.40 - Icebourg - 05 Z51 M6 - CAI, CB
12.41 @ 112.07 - WS6JJP - 05 Z51 M6 - CB
12.42 @ 116.12 - YellowVette22 - 05 F55 M6 - CAI, CB, hdrs, DR - (393)
12.44 @ 114.34 - Mike Campbell - 06 A6 - CAI, stat - (2611)
12.46 @ 117.86 - MMartin - 08 Z51 A6 - CAI, hdrs, tune - (2910)
12.48 @ 113.00 - Demented - 05 Z51 A4 - CAI
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, CB & hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, CB, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, CB, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 Z51 A6 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, CB, hdrs, tune - (1602)
12.53 @ 113.78 - Ultimate CC - 07 Z51 M6 - CAI - (1641)
12.54 @ 114.01 - Siffert - 07 A6 - CB, open shroud - (1990)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, CB
12.54 @ 113.24 - NineBall - 05 Z51 M6 - stat
12.55 @ 115.85 - Yell03 - 06 M6 - CAI, CB
12.55 @ 114.95 - Shurite44 - 06 Z51 A6 - CAI, CB, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 Z51 A4 - CAI, CB, hdrs - (240)
12.57 @ 113.04 - Jschindler - 05 F55 M6 - CB - (241)
12.57 @ 110.67 - Yell03 - 05 A4 3.15 - CB - (464)
12.59 @ 114.89 - AZVette2005 - 05 Z51 M6 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 Z51 M6 - CAI, CB, hdrs, tune - (59)
12.63 @ 112.35 - Lusky - 06 Z51 A6 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI,CB, Tune - (2601)
12.68 @ 113.92 - Sditch - 05 Z51 A4 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 F55 A4 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 Z51 M6 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - tune - (1179)
12.80 @ xxx.xx - Thanos - 05 Z51 A4 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, CB, tune
12.89 @ 112.57 - Bunk22 - 05 Z51 M6 - CAI, CB, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 Z51 M6 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 Z51 M6 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 Z51 M6 - CAI, CB, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 Z51 M6 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 Z51 A4 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 Z51 M6 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 F55 M6 - CAI, CB - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 Z51 M6 - CB
13.33 @ 113.31 -Gaussian Mist - 08 F55 Npp M6 - Npp comander - (2706)
13.95 @ 104.94 - Fright88 - 06 A6 -CB, hdrs - (1683) high alt
Internal Engine Modifications
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
10.84 @ 128.58 - Doug@ECS - 08 Z51 M6 NPP -Blistens, Cam CAI, hdrs, 3.90, tune DR - (2914)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, CB, conv, H&C, hdrs, 3.42, intake, tune, DR
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, gears 3.15, tune, DR - (2805)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.21 @ 120.79 - Thesubfloor - 07 A6 - CAI, cam, Conv 3.42, hdrs, DR - (2999)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, CB, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.37 @ 124.40 - Evilways - 06 Z51 A6 - CAI, CB, cam, hdrs, L92/L76 Combo tune, PS2 - (2443)
11.39 @ 122.58 - Isaiah48 - 05 Z51 M6 - CAI, CB, H &C hdrs, tune, DR - (2801)
11.44 @ 122.91 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, udp DR - (2826)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, CB, cam, hdrs, portintake - (2847)
11.49 @ 125.62 - Wa$nt me - 06 Z51 M6 - CAI, CB, cam, hdrs, intake, udp, tune - (1610)
11.50 @ 125.76 - BlownV6 - 06 A6 - CAI, CB, H&C, hdrs, tune, DR
11.52 @ 125.73 - High Roller1 - 06 Z51 A6 - CAI, CB, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 F55 M6 - CAI, CB, H&C, hdrs, intake, tune -(871)
11.54 @ 121.39 - Joe G - 05 Z51 M6 - CAI, CB Cam, hdrs, 3.90, ported int, tune, DR - (2718)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, CB H&C, hdrs, PFast, susp tune, DR - (2757)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
11.76 @ 116.76 - 1955 Belair - 05 Z51 A4 - CAI, CB, conv, H&C, hdrs, intake, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, CB, 3.15, H&C, hdrs - (1821)
11.80 @ 123.50 - Xstang - 05 Z51 M6 - CAI, 3.90, H&C, hdrs, tune, DR - (1178)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, Cam, hdrs & tune -(3039)
11.98 @ 120.87 - Mr Z51 - 06 Z51 M6 - CAI, Cam, 4.10, hdrs, ported int, udp, DR - (1265)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, Cam, hdrs & tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, CB, H&C, hdrs, intake, tune
Power Adders (supercharger, turbo, nitrous)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 - N2O, CAI, CB, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 Z51 M6 - SC with meth, cam, CB, hdrs, DR
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, CB, conv, 3.73, hdrs, tune, DR - (480)
10.88 @ 132.41 - Todd@RPM - 05 A4 -TT 427, L92 heads, 3.42 RPM Trans DR (2273)
10.89 @ 129.93 - DTE - 05 A4 - Gears, Mufflers, Twin Turbo, DR - (939)
10.96 @ 129.73 - Blue Racer - 05 Z51 A4 - SC LPE 427 & RPM trans DR - (1795)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 Z51 M6 - N2O, CAI, CB, DR
11.21 @ 127.82 - Schilitj - 05 Z51 M6 - SC, CB, H&C, hdrs - (1235)
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, CB, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, CB, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 126.64 - Nine Ball - 05 Z51 M6 - SC, CB, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, CB
1/8 mile (All entries)
7.42 @ 95.92 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, udp DR - (2889)
7.48 @ 96.60 - StageIt - 08 Z51 M6 - hdrs, Intake, DR - (2863)
7.59 @ 95.93 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2556)
7.60 @ 92.00 - Joe G - 05 Z51 M6 - CAI, 3.90, hdrs, ported int - (1803)
7.83 @ 92.14 - Bunk22 - 05 Z51 M6 - CAI CB, hdrs, Fast, rockers & tune - (2671)
8.14 @ 90.00 - Carmos - 08 A6 Z51 NPP - (2660)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 - CAI CB, tune - (1664)
The bold numbers refer to the post number utilized to report the elasped times in this thread
Old Aug 25, 2008 | 08:21 PM
  #3047
Tommy D's Avatar
Tommy D
Hey Daren,
Nice time........so I guess there is hope for those of us who installed the Zo6 exhaust I need to have mine tuned but I am still over my head catching up......The next run should crack the 11s for sure good luck!
Old Aug 25, 2008 | 08:23 PM
  #3048
Tommy D's Avatar
Tommy D
Originally Posted by tamars
hey,,,it been early since i bought my zo6 - c6 , moreover, i am intrested to add supercharge on it ...so, i was thinking about the 700 horse power and i want some replay's or opinions of chosing what,, and if the 700 horse power is good enough for my zo6 or the daily use...because i dont have experience of stuff like these..
You may want to try the Z06 section of the C6 forums
Old Aug 25, 2008 | 08:48 PM
  #3049
06C6FVR's Avatar
06C6FVR
Thanks, but Im gunnin for ya joe Currently, you are the fastest LS2 M6 for the bolt on category...I want that spot... Thinking about the fast intake now, and with that, im thinking 11.50's are in my future with some good weather!
Old Aug 26, 2008 | 10:08 PM
  #3050
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Tommy D,
I was wondering if you could update me on the 1/8 list.
Best pass
60ft.....1.684
330ft...4.777
1/8......7.34@96.69mph
The video doesn`t catch the numbers on the board but this is my best.
There is a slip that i couldn`t scan because it was to light but i will give the break down and video of that pass.
60ft.....1.691
330ft....4.796
1/8.......7.36@96.55
Old Aug 27, 2008 | 02:51 AM
  #3051
LS1LT1's Avatar
LS1LT1
Nice work Tony, that sixty is dropping nicely and we all know how lower sixty foots affect ETs.
Old Aug 27, 2008 | 10:07 AM
  #3052
bunk22's Avatar
bunk22
Holy crap, nice times Tony B4
Old Aug 27, 2008 | 11:07 AM
  #3053
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Now if we could only get those darn torque converters to work properly, huh?
Sorry, couldn't resist.
Old Aug 27, 2008 | 12:35 PM
  #3054
LS1LT1's Avatar
LS1LT1
Yeah really, gears alone are just fine, higher stall converters do NOTHING for the A6 cars.
On a more serious note...yours is working fine now I assume, no hunting or surging issues or anything?
Old Aug 27, 2008 | 12:39 PM
  #3055
thesubfloor
Yeah, it works great now. All it needed was to have the idle airflow bumped up a bit.
Christopher
Old Aug 27, 2008 | 12:44 PM
  #3056
LS1LT1's Avatar
LS1LT1
Excellent.
Old Aug 27, 2008 | 01:04 PM
  #3057
8850's Avatar
8850
If a properly sized stall converter doesn't work on an A6 then I think proper tuning just hasn't been configured or perhaps the ECM is not capable of the correct tuning. Converters have contribute tremendous gains on all auto transmissions. Our stock converter is so tight too that a converter would have to work it's magic.
To C6 1/4 Mile Performance Challenge
Old Aug 27, 2008 | 01:35 PM
  #3058
LS1LT1's Avatar
LS1LT1
100%...others who are somewhat 'less informed' tend to disagree of course.
Old Aug 27, 2008 | 01:51 PM
  #3059
thesubfloor
Must....resist.. ... ... urge to .......ju...jum...jump into....conversation......
Old Aug 27, 2008 | 04:59 PM
  #3060
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Thanks Marc and i agree.
Thanks Bunk!!
