C6 1/4 Mile Performance Challenge
Tire pressures were left at 30psi cold..
1st run... All nannies off, no burnout, left at idle, is s mode, no paddles...78 degrees out and 180 eng temp...60 = 1.97 1/8 = 8.04@90.37 1/4 12.34@115.97
2nd run, same as above with light power brake. It spun,then got wheel hop at the top of first, then went sideways when it hit second...I backed out..60ft = 2.13 1/4 = 18.96@54
3rd run... after an 1.5 hour wait from the second run and being spooked on the 2 run I left all the nannies on... 72 degrees, 160 engine temp...60ft 2.01 1/8 = 8.12@89.95 1/4 = 12.44@115.23
Tommy if you could move me up on the Showroom Stock list....Thanks
This car should be the #2 car on the "showroom stock" list. Removing the fuse is a sound mod not a performance mod. Removing air in the tires is not considered a mod, removing a fuse should not be either. Plus he also ran a 12.12 with the fuse in, proving there is no performance gain. This gentleman should be credited with having the second quickest stock car and quickest A6 on the list.
Yes the exhaust valves open on their own anyway but not until 3500rpms I think it is. If they're not a performance mod then I guess removing cats or putting a freer flowing muffler isn't as well?
Now I'm not so obtuse as to actually believe that it really makes that much of a difference or that the car couldn't have still run the number with the fuse in (as the owner even said it did), I know that it can/will. It's just there has to be a line drawn on stock versus altered and if this is fuse removal (or one of the Mild to Wild switches/devices) is allowed then what happens when the next guy wants passenger seat and/or entire cat back exhaust removal allowed in as well?
If that's the case then I'm taking the Vararam off, pulling the seat, radio and glove box lids out and going back out there in search of "bone stock" 12.1s/12.0s.
I personally have no problem with his results being allowed on and I can almost assure that this same car/same driver will be posting an even quicker stock time very soon, even with the fuse in, but the list says bone stock, not bone stock with a few things unplugged or added on.
This is done to maintain some integrity not just for those already on the lists but for those in the future (including yourself) vying to get on it as well.
Tire pressures you ask?
The factory sets them one way but I would have to bet that NOT ALL 30k+ Corvettes leave the factory with identical pressures in their four tires so there really are no 'stock standard' pressures to begin with. And what if one of the tires has a slow leak/loses a little air and you refill it, or if one is set at 45psi by accident from the factory and you let some out, that's no longer factory air pressure either and THAT'S why something like tire pressures aren't questioned/factored into this stock list thing.
I'm not disagreeing with you on this, I too feel that the line could be moved up a little, just asking.
Maybe it should be a poll or vote.
Of course it does open the door to some people then saying that swapping in a K&N air filter (flows MUCH better than a stock LS3/Z06 filter) is perfectly fine...then it's gutting the cats...then it's cut outs in front of the mufflers...and so on...
Dennis your my idle..!
See I made it on.!!
Have to admit for a a stock external mod (bolt on) that is flying!
As per GM, the 6 hp gain is at 5900 rpm, way up in the powerband. Below 5000 rpm the gain is negligible. Also, the exhaust valves are open by the 60 foot mark under full throttle. So basically, the exhaust valve is open whether the fuse is in or not, for 90% + of the 1/4 mile. Any measureable gain in the 1/4 would be in thousanths of a second....not even worth mentioning, unless somebody cared about the difference between a 12.121 and a 12.123.
I'm all for it, let 'fuse removal' in.
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order.
________________________________________ ________________________________________ _______
NEW or IMPROVED ELASPED TIMES
12.34 @115.97 Pettvette
10.90 @ 127.51 N77nxc
Showroom Stock
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 Z51 M6 - (2690)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.23 @ 112.86 - 940CACC - 08 Z51 A6 - (2880)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.34 @ 115.97 - Pettvette - 08 A6 - (3167)
12.35 @ 117.47 - Bain - 08 A6 2.73 npp - (2759)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 117.11 - EZ28 - 08 Z51 M6 - (2735)
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.49 @ 115.54 - 1.8T - 08 Z51 M6 - (2314)
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.54 @ 114.67 - Proney - 07 M6 - (2886)
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4 - (60)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 114.99 -PhillyLS1 - 09 M6 - (3156)
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6 - (51)
12.66 @ 113.61 - CFP40 - 08 A6 2.73 npp - (2834)
12.66 @ 113.03 - Mdrrandall - 07 Z51 M6 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 Z51 A6 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 Z51 M6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 Z51 A6 - (907)
12.79 @ 112.17 - Jchazr - 05 Z51 M6 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 Z51 A6 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 Z51 M6 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.83 @ 109.44 - Tommy D - 05 A4 3.15 - (114)
12.84 @ 112.98 - Proney - 06 M6
12.85 @ 114.53 - Mr Z51 - 06 Z51 M6
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 F55 A4 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 Z51 M6 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 F55 A4 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 Z51 M6
13.25 @ 110.60 - C6 Matt - 05 Z51 M6 - (122)
13.26 @ 108.59 - Sfadchi - 06 Z51 A6 - (888)
13.26 @ 105.30 - Joeking - 05 Z51 A4 - (661)
13.30 @ 107.00 - Shurite44 - 06 Z51 A6 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 Z51 A4
External Engine Modifications (Bolt-Ons)
10.92 @ 123.63 - Dennis50NJ - 05 Z51 A4 - CAI, CB, conv, hdrs, 3.73, tune, DR - (2540)
11.44 @ 119.11 - Theofel - 08 A6 - CAI, CB, conv, hdrs, 315, tune, DR - (2108)
11.47 @ 121.93 - Jbsblownc5 - 08 M6 Z51 - CAI, CB, Hdrs, ported int, 3.73, tune DR - (2504)
11.55 @ 120.71 - StageIt - 08 Z51 M6 -CB, hdrs, Intake, 3.90, Et St - (3089)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, CB, Hdrs, ported int/tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 Z51 M6 - CAI, DR - (1852)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 Z51 A6 Npp - El wp, hdrs, tune - (2175)
11.76 @ 119.00 - NastyC6 - 05 Z51 A4 - CAI, conv, hdrs, 3.73, ported int/tb, tune
11.77 @ 121.58 - Red06vette - 06 Z51 A6 - CAI, CB, hdrs, ported int/tb, tune - (2179)
11.77 @ 121.41 - XStang - 08 A6 Z51 - CAI, Tune - (2522)
11.80 @ 118.62 - 8850 - 08 A6 2.73 NPP - CAI, hdrs, tune - (2012)
11.81 @ 118.76 - Joe G - 05 Z51 M6 - CAI, hdrs, 3.90, ported int, tune - (1874)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, CB, hdrs, conv, tune, DR - (839)
11.88 @ 119.97 - HPAvette - 08 A6 - CAI Hdr tune - (3032)
11.94 @ 117.99 - JimSpeed - 06 Z51 M6 - CAI, CB, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 Z51 M6 -CAI, hdrs, ported int, bilstein shocks, tune, DR - (2163)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970)
11.99 @ 120.44 - 1.8T - 08 Z51 M6 - CAI, CB, Hdr, tune, DRs - (2471)
11.99 @ 118.51 - JMT1669 - 06 A6 - CAI, CB, tune - (2176)
12.01 @ 116.00 - Mr Z51 - 06 Z51 M6 - CAI, CB, hdrs, ported int, tune, DR
12.03 @ 120.42 - Quikag - 08 Z51 M6 - CAI, CB, hdrs, tune - (2529)
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, CB, hdrs
12.03 @ 118.43 - Glennhl - 06 Z51 A6 - CAI, hdrs, ported int, tune DRs - (2277)
12.04 @ 114.01 - 06C6FVR - 06 Z51 M6 - Mufflers, tune, DR - (1301)
12.05 @ 117.67 - C5pilot - - 07 Z51 A6 - CAI, Tune - (2598)
12.05 @ 117.02 - CYA Vett - 05 F55 M6 - Hdrs
12.07 @ 115.31 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 Exhaust, Muff, Tune, DR - (2048)
12.08 @ 117.00 - Forrest - 06 Z51 M6 - CAI, CB, hdrs, tune, DR - (1449)
12.12 @ 118.06 - Badassbu - 09 A6 npp - Removed fuse - (3145)
12.13 @ 115.15 - Ben Diss -07 F55 M6- CAI, hdrs, Nitto Ivos, tune - (1919)
12.17 @ 119.00 - RHecox - 06 Z51 A6 - CAI, CB, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, Kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 Z51 M6 - CAI, CB - (1822)
12.18 @ 114.00 - Toptoneone - 06 Z51 M6 - CAI, CB, hdrs, tune DR - (1824)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, CB, hdrs, Intake - (659)
12.26 @ 116.65 - Waveblaster785 - 06 Z51 A6 - CB, hdrs, Intake - (1118)
12.28 @ 115.91 - C5Pilot - 07 Z51 A6 - CAI, DR, tune - (2551)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, CB, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 Z51 A6 - CAI, TB, DR - (1473)
12.41 @ 115.40 - Icebourg - 05 Z51 M6 - CAI, CB
12.41 @ 112.07 - WS6JJP - 05 Z51 M6 - CB
12.42 @ 116.12 - YellowVette22 - 05 F55 M6 - CAI, CB, hdrs, DR - (393)
12.44 @ 114.34 - Mike Campbell - 06 A6 - CAI, stat - (2611)
12.46 @ 117.86 - MMartin - 08 Z51 A6 - CAI, hdrs, tune - (2910)
12.48 @ 113.00 - Demented - 05 Z51 A4 - CAI
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, CB & hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, CB, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, CB, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 Z51 A6 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, CB, hdrs, tune - (1602)
12.53 @ 113.78 - Ultimate CC - 07 Z51 M6 - CAI - (1641)
12.54 @ 114.01 - Siffert - 07 A6 - CB, open shroud - (1990)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, CB
12.54 @ 113.24 - NineBall - 05 Z51 M6 - stat
12.55 @ 115.85 - Yell03 - 06 M6 - CAI, CB
12.55 @ 114.95 - Shurite44 - 06 Z51 A6 - CAI, CB, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 Z51 A4 - CAI, CB, hdrs - (240)
12.57 @ 113.04 - Jschindler - 05 F55 M6 - CB - (241)
12.57 @ 110.67 - Yell03 - 05 A4 3.15 - CB - (464)
12.59 @ 114.89 - AZVette2005 - 05 Z51 M6 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 Z51 M6 - CAI, CB, hdrs, tune - (59)
12.63 @ 112.35 - Lusky - 06 Z51 A6 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI,CB, Tune - (2601)
12.68 @ 113.92 - Sditch - 05 Z51 A4 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 F55 A4 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 Z51 M6 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - tune - (1179)
12.80 @ xxx.xx - Thanos - 05 Z51 A4 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, CB, tune
12.89 @ 112.57 - Bunk22 - 05 Z51 M6 - CAI, CB, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 Z51 M6 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 Z51 M6 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 Z51 M6 - CAI, CB, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 Z51 M6 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 Z51 A4 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 Z51 M6 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 F55 M6 - CAI, CB - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 Z51 M6 - CB
13.33 @ 113.31 -Gaussian Mist - 08 F55 Npp M6 - Npp comander - (2706)
13.95 @ 104.94 - Fright88 - 06 A6 -CB, hdrs - (1683) high alt
Internal Engine Modifications
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
10.84 @ 128.58 - Doug@ECS - 08 Z51 M6 NPP -Blistens, Cam CAI, hdrs, 3.90, tune DR - (2914)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, CB, conv, H&C, hdrs, 3.42, intake, tune, DR
11.15 @ 121.43 - Thesubfloor - 07 A6 - CAI, cam, Conv 3.42, hdrs, DR - (3154)
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, gears 3.15, tune, DR - (2805)
11.20 @ 123.89 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, udp DR - (3109)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, CB, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.37 @ 124.40 - Evilways - 06 Z51 A6 - CAI, CB, cam, hdrs, L92/L76 Combo tune, PS2 - (2443)
11.39 @ 122.58 - Isaiah48 - 05 Z51 M6 - CAI, CB, H &C hdrs, tune, DR - (2801)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, CB, cam, hdrs, portintake - (2847)
11.49 @ 125.62 - Wa$nt me - 06 Z51 M6 - CAI, CB, cam, hdrs, intake, udp, tune - (1610)
11.50 @ 125.76 - BlownV6 - 06 A6 - CAI, CB, H&C, hdrs, tune, DR
11.52 @ 125.73 - High Roller1 - 06 Z51 A6 - CAI, CB, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 F55 M6 - CAI, CB, H&C, hdrs, intake, tune -(871)
11.54 @ 121.39 - Joe G - 05 Z51 M6 - CAI, CB Cam, hdrs, 3.90, ported int, tune, DR - (2718)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, CB H&C, hdrs, PFast, susp tune, DR - (2757)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
11.76 @ 116.76 - 1955 Belair - 05 Z51 A4 - CAI, CB, conv, H&C, hdrs, intake, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, CB, 3.15, H&C, hdrs - (1821)
11.80 @ 123.50 - Xstang - 05 Z51 M6 - CAI, 3.90, H&C, hdrs, tune, DR - (1178)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, Cam, hdrs & tune -(3039)
11.98 @ 120.87 - Mr Z51 - 06 Z51 M6 - CAI, Cam, 4.10, hdrs, ported int, udp, DR - (1265)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, Cam, hdrs & tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, CB, H&C, hdrs, intake, tune
Power Adders (supercharger, turbo, nitrous)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 - N2O, CAI, CB, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 Z51 M6 - SC with meth, cam, CB, hdrs, DR
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, CB, conv, 3.73, hdrs, tune, DR - (480)
10.88 @ 132.41 - Todd@RPM - 05 A4 -TT 427, L92 heads, 3.42 RPM Trans DR (2273)
10.89 @ 129.93 - DTE - 05 A4 - Gears, Mufflers, Twin Turbo, DR - (939)
10.90 @ 127.51 - N77nxc - 07 A6 - CAI, cam, conv, hdrs, N20, DR - (3166)
10.96 @ 129.73 - Blue Racer - 05 Z51 A4 - SC LPE 427 & RPM trans DR - (1795)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 Z51 M6 - N2O, CAI, CB, DR
11.21 @ 127.82 - Schilitj - 05 Z51 M6 - SC, CB, H&C, hdrs - (1235)
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, CB, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, CB, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 126.64 - Nine Ball - 05 Z51 M6 - SC, CB, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, CB
1/8 mile (All entries)
7.34 @ 96.69 - Tony B4 - 06 A6 - CAI, Cam, CB, Conv, hdrs, PIntake/TB, tune udp DR - (3056)
7.36 @ 98.03 - StageIt - 08 Z51 M6 -Cb, hdrs, 3.90, Intake, Et Street - (2863)
7.50 @ 99.47 - Vettechictwins - 08 Z51 M6 - CAI, Cam, CB, hdrs, PIntake/TB, tune PS2s - (3081)
7.59 @ 95.93 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2556)
7.60 @ 92.00 - Joe G - 05 Z51 M6 - CAI, 3.90, hdrs, ported int - (1803)
7.83 @ 92.14 - Bunk22 - 05 Z51 M6 - CAI CB, hdrs, Fast, rockers & tune - (2671)
8.14 @ 90.00 - Carmos - 08 A6 Z51 NPP - (2660)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 - CAI CB, tune - (1664)
The bold numbers refer to the post number utilized to report the elasped times in this thread
Pettvette.... very nice improvement
You can tell when they tack the track. You can hear the tires. When you role up into the beam.
Last time we were out. Our 60ft was way off. High 1.2'S
and 1/8 WERE OFF BYE 6-9 tenths. Tires were just spinning. Still went 8.50's at 160mph. Track wasn't there.
It's nice to go on rental days. They put lots of tack down
Mike T's car is a 2007 LS2 C6 with manual trans with the following mods:
Kooks long tubes
Cat back
Vararam
FAST intake
160 degree thermostat
Cartek 4.10 gears
Cartek clutch
Cartek dyno tuning
BFG drag radials
MGW Shifter
381.6 rwtq
384.2 rwhp
60' - 1.73
1/4 - 11.87
MPH - 120.54
Here's a not so great photo of the time slip, a better one should follow:
Tommy can get quite busy with the business he is in so he can't visit here all day like some of us do
but he will take care of any posts/updates that are made and we do all fully appreciate and praise his efforts.
In the case of the slip/entry that you show above, that was not the normal procedure for posting a slip so it might need a little more information before being put on the list. I am helping gather that info as we speak.
http://
Thesubfloor & Stageit smokin times
