C6 1/4 Mile Performance Challenge
Old Mar 3, 2009 | 02:52 PM
  #3881
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Well done, Tommy, well done!
Old Mar 3, 2009 | 03:07 PM
  #3882
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I should be working on work rather that reading about what should be done or not with regard to this list. This item was resolved prior to Chris posting his time on the list.
I try to resolve any problems by e-mail as not to bother the moderators. It keeps discussions from turning into arguments and keeps the list from getting locked.
Unfortunately, I can not edit the rules page. I have submitted revisions in December and once I can change the rules page I can make the necessary changes.
Now lets stop the unnecessary discussions and get back to racin
Thank You
Tommy
Old Mar 3, 2009 | 03:32 PM
  #3883
siffert's Avatar
siffert
Now lets stop the unnecessary discussions and get back to racin Thank You Tommy
Thanks, I am going to delete my posts now since the time Chris
posted his slip and highly suggest others do the same as to not clutter this list. Just go back to your posts, hit edit, then delete and then select "delete message". When we are back to around page 191, I'll delete this too one too.
Old Mar 3, 2009 | 04:20 PM
  #3884
dennis50nj's Avatar
dennis50nj
Originally Posted by Tuner@Straightline
If not threatened by the LS3 because you're on the top of the list, why feel threatened by an LS7. It can't be because of the displacment, because there's other out there with larger displacment motors you didn't worry about.
duh, isnt it a 100 more hp! why dont you take a bolt/on LS2 and compete against him, and i guess it was put were i said it would be, and subfloor already knew were it was going
Old Mar 3, 2009 | 06:22 PM
  #3885
Fasrdnu's Avatar
Fasrdnu
Tommy Did the right thing as usual! I told you guys this would happen!!!
Old Mar 3, 2009 | 06:38 PM
  #3886
LS1LT1's Avatar
LS1LT1
Good suggestion, I'm going to do the same.
Hoping that others will follow as well, this thread just had roughly an extra 4-5 pages of unnecessary postings tacked on to it and that just makes it more difficult to maintain so please, let's clean it up a little.
I'm even going to delete this post eventually.
Old Mar 3, 2009 | 07:40 PM
  #3887
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Great Job Tommy D!
Old Mar 4, 2009 | 09:12 AM
  #3888
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Lets go racing
Old Mar 5, 2009 | 06:22 AM
  #3889
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Folks are ALWAYS gonna whine about times...........real or unfounded.
All the posters should be minful of the OP rules though.......
Here they are, plain and simple and to the point from page 1:
There will be no arguments only discussion! I will have any argumentive posts removed from the thread. If you ignore the forum rules, you will be subject to whatever actions the moderators decide as appropriate.
If you don't like something, take it to PM/E-mail vs. posting in this thread.
Old Mar 5, 2009 | 06:53 AM
  #3890
Caeruleus Diabolus's Avatar
Caeruleus Diabolus
I didn't know you could hit 11's with a stock C6!
Old Mar 10, 2009 | 01:21 PM
  #3891
rmm2424's Avatar
rmm2424
Default 11 sec c6
don't believe the 11sec runs were stock
Old Mar 10, 2009 | 03:53 PM
  #3892
Tommy D's Avatar
Tommy D
OK guys we all have our own opinions, If you wish to dicsuss the aforementioned, please start another thread.
I only post the numbers and as I have stated on page one of this list in the rules section, nothing says that anyone has to believe anything posted in this thread. Any other discussion posts placed in this thread will be deleted. This thread is for the recording of times.
Thank You
Tommy
Old Mar 12, 2009 | 12:08 PM
  #3893
Isaiah48's Avatar
Isaiah48
Default PB 11.16 @125 w/1.65 60'
New PB at MIR
I had a great day last Friday at an MIR track day, the weather felt great as far as humidity goes and it was in the mid to high 60's. The track was a little slick in the morning, but was great in the afternoon after they put down some fresh VHT.
Another Forum member Jamie Furman witnessed the run and he also was having a great day, running 3 sub 11 passes in a Stock W/DR's C6 Z06.
I was running Mickey Thompson ET Street Drag Radials which, as always hook pretty good. I just upgraded my entire drivetrain putting 3:90's in along the way.
A recent Dyno run put me at 467rwhp with 417rwtq which was 20rwhp over the last dyno due to putting in 48# injectors and retuning. I was hoping to gain at least .2 with my changes and I netted a .23 so I met my initial goal, even though I really want 10's!!!
MIR Track
3/6/09 Clear with temps in the high 60's
1.65 60'.............
3.697 330'...........
7.200 660'...........
97.43 660’ mph....
9.365 1000'.........
11.167 1320'.........
125.34 1320’ mph…
Here is a log for all you HPTuner guys...
Old Mar 13, 2009 | 04:47 PM
  #3894
gunnerrun's Avatar
gunnerrun
Default Way Better Evaluation
I suggest we break the records into the LS2s and the LS3s it would be a more accurate method of evaluating driver skill vs the hp factory advantage.
Old Mar 15, 2009 | 01:21 PM
  #3895
socalzo6's Avatar
socalzo6
Default 11.0@126.9
Wanted to update my times on the list. Finally was able to get down to the 1/4. The car is an 08 LS3 A6 2.56. Modes: Mild CAM, 2800 PI, tune, headers. The car still has stock gears, intake/T.B, pulley.
Old Mar 15, 2009 | 01:38 PM
  #3896
xstang's Avatar
xstang
So close to a 10!!!!!! Congrats! Tou are flying!
Old Mar 15, 2009 | 01:48 PM
  #3897
8850's Avatar
8850
That's some great times! Goes to show you don't need a big gear to run good. That converter is in effect a gear. Had you gotten a 3600 PI you would have been well into the 10s. Way to go!
To C6 1/4 Mile Performance Challenge
Old Mar 15, 2009 | 04:42 PM
  #3898
beefcake's Avatar
beefcake
10.87 @ 131.13 - Beefcake - 08 A6 F55 - Vortech V3, Cam, Headers, DR's, 2.56 Gear
Old Mar 15, 2009 | 05:11 PM
  #3899
dennis50nj's Avatar
dennis50nj
thats nice 10s and over 130 mph
Old Mar 16, 2009 | 07:26 AM
  #3900
Isaiah48's Avatar
Isaiah48
I know it's a lot of work to keep this up as it is but it would be more accurate, the LS3's are just too strong to compare to the LS2's. Maybe they could go in the Larger Displacement category...
