C6 1/4 Mile Performance Challenge
Pass was made at Fayetteville Motorsports Park on 10/30/11 temp was about 60 degrees.
4. Year Corvette 2005
5. Type of Trans- M6
6. Type of Suspension-Z51
7. Stock Performance options-Z51 suspension package
8. Tires utilized-ET streets
9. Modifications- Custom ground cam kit, CAI, fast102, custom tune, LT's, Off road X pipe, mcleod RST clutch
10. Dyno numbers if you have them-440/406
11. As much info you may want to add about the run- Left around 3500 rpm's with tires at 20psi, still had factory wheels up front.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track-Fayetteville Motorsports Park, NC
___ Date of the pass & weather conditions-10/30/11 60 Degrees with low DA
___ 60'.............1.7358
___ 330'...........4.8809
___ 660'..........7.4683
___ 660’ mph...97.05
___ 1000'..........N/A
___ 1320'..........11.5146
___ 1320’ mph….122.48
IMAG0073 by mwstevens86, on Flickr
NEW or IMPROVED ELASPED TIMES
11.514 @ 122.48 GTkiller97
Hey Mike
Very nice improvement with those mods,
Category: LS3 bolt on
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # 5464
3. The complete the details of your pass using this template in your post:
4. Year Corvette - 2008
5. Type of Trans - A6
6. Type of Suspension - Z51 w/base brakes
7. Stock Performance options - 2.73 Gears
8. Tires utilized - Hoosier 275-40-17 drs rear, M&H front runners on GTO spares
9. Modifications if any - CAI, headers, udp, converter, tune
10. Dyno numbers if you have them - None
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc - 25 psi rears 38 psi fronts 1/4 tank of gasoline, left from just over 1000 rpm
___ Name of the Track - Royal Purple Raceway, Houston
___ Date of the pass & weather conditions 11-4-11 with a -434 DA
___ 60'.............1.644
___ 330'...........4.582
___ 660'..........7.034
___ 660’ mph...100.88
___ 1000'..........9.148
___ 1320'..........10.949
___ 1320’ mph….124.08
Even with better weather the Yank 3200 just doesn't cut it. The STR is way too low...it's a great street/strip converter, but definitely not a record setter.
It's, without a doubt, the biggest regret I have with my car.
The best 60' I could get out of mine in -1000 DA was 1.68-1.69, so I anticipated larry's car (LS3 vs my LS2 would run about .05 quicker in the 60'....looks like it was a good guess
) Next summer I'll pull mine out and install a different one.
4. Year Corvette 2007
5. Type of Trans M6
6. Type of Suspension Base
7. Stock Performance options Base
8. Tires utilized hoosier 315 drs@19.5psi cold
9. Modifications if any Vararam CAI,LTH no cats,
Ported Fast 102,C6Z Diff,McLeod RXT,bad driver,C5Z axles
10. Dyno numbers 405whp 407wtq
11. As much info you may want to add about the run, launch techniques, little better than a 1/2 tank of gas,5000-5500 rpm launch hooked hard then bogged, DA unknown
Atco
11-6-11
1.733 - 60'
4.901 - 330'
7.471 - 660'
96.07 - 660’ mph
9.668 - 1000'
11.522- 1320'
122.72- 1320’ mph
http://www.youtube.com/watch?v=QmA7BrB0bi8
http://www.youtube.com/watch?v=gr3zPT7ZjB4
Vararam CAI
LTH no cats
Ported Fast 102
C6Z Diff
bad driver
405whp 407wtq
DA unknown
Atco
11-6-11
1.733 - 60'
4.901 - 330'
7.471 - 660'
96.07 - 660’ mph
9.668 - 1000'
11.522- 1320'
122.72- 1320’ mph
Oh he did go...I was with him all day yesterday at E-town and he was remotely considering going down to MIR last night/today.
Speaking of which, how's Fartpipe doing down there I wonder?
looked good two me but I was 2 cars behind him...
He should see a high 9 in that bolt ons only C6 Z06 at some point over the next 6 weeks though.
Vararam CAI
LTH no cats
Ported Fast 102
C6Z Diff
bad driver
405whp 407wtq
DA unknown
Atco
11-6-11
1.733 - 60'
4.901 - 330'
7.471 - 660'
96.07 - 660’ mph
9.668 - 1000'
11.522- 1320'
122.72- 1320’ mph
