C6 1/4 Mile Performance Challenge
Old Jan 7, 2012 | 03:24 PM
  #5661
dicky's Avatar
dicky
wow congrats jeff
Old Jan 7, 2012 | 03:30 PM
  #5662
winters97gt's Avatar
winters97gt
New Best! Set the C6 M6 record last night!
-Year Corvette2008
-Type of Trans Stock M6
-Type of SuspensionStock
-Stock Performance options (as in optional gears with the automatic, & etc.) Stock Performance options
-Tires utilized MT 295/45-17
-Modifications if any 402, LS3 heads, Novi 1500
-Dyno numbers if you have them 814rwhp
-As much info you may want to add about the run, launch techniques, tire air pressure & etc Full street car the way I run it daily. No drag pack/or spare tires up front, full weight. Race weight is 3565 with me
-Name of the TrackRPR
60'.............1.464
330'...........4.102
660'...........6.362
660’ mph....112.67
1000'.........8.253
1320'.........9.843
1320’ mph…143.14
Copy of Time Slip Below
I'm still on cloud nine!
http://forums.corvetteforum.com/c6-f...84-143mph.html
Old Jan 7, 2012 | 03:54 PM
  #5663
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Stock rear too? Geesh that's a sick 60'. Any plans on upgrading the trans/rear?
Old Jan 7, 2012 | 04:54 PM
  #5664
8850's Avatar
8850
Congrats Mark! Your 402 is making some real power. Great launch too!
Old Jan 7, 2012 | 07:21 PM
  #5665
Justasheet's Avatar
Justasheet
Originally Posted by Joe_G
What have you done since last year with 11.2's?
Joe, they were 11.3's last year. I took out the pass. seat, added GTO skinnies and of course HP Sales added some Texas Speed milled Stage 3 "PRC" heads with a Cometic gasket and his tune. I got nearly 3.5/10's of a sec. with all this.
I can't get my 60' down. I never tried launching from idle. All my runs were launched at 1500 rpm. I think I may have to be satisfied with 1.6x 60' times with Yank 3200 stall.
Theofel (Mike) was there all night coaching me along. Of course he was running 10.8's all night.
Thanks Derrick. Thanks Justin.
Jeff
Old Jan 7, 2012 | 07:47 PM
  #5666
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Jeff
I'd try flashing from idle. Can't hurt!
Old Jan 7, 2012 | 08:03 PM
  #5667
Justasheet's Avatar
Justasheet
No your right. Maybe all I need is some better weather? I took out the front sway bar today. Maybe that will do it. The shift points were dead on. 6800 from 1st to second. I think it was closer to 7k on the 2nd to 3rd shift.
Thanks as always for all your help. I'm gonna need a tweek on warm start up from you. It's happening again since the latest tune.
Jeff
Old Jan 7, 2012 | 09:32 PM
  #5668
theofel's Avatar
theofel
St. Jude Donor '10-'13
Jeff
JEFF:
Next cold day and you'll be in the 10's. Track got real damp and wet toward the end of the evening.
Old Jan 7, 2012 | 10:59 PM
  #5669
winters97gt
Thanks, Justin! No plans on upgrading the rear end right now. I went through quite a few on my Z06, but knock on wood, this one has been good to me. When it breaks, I'll probably add a built C5 differential to the car.
Thank you, Larry! Hope to see you out at the track soon. I got my number, and won't run again unless I upgrade the blower or tune the nitrous bottle on the car. I'm interested to see what it will run on a 75 shot spraying 2nd-4th gear. My tuner says it will add 100hp with the blower, so I think 146-148mph might get the car in the mid to low 9's.
Let me know when you head out next, and I'll try to come out and video and watch!
Old Jan 7, 2012 | 11:23 PM
  #5670
JUIC3D's Avatar
JUIC3D
Mark, can you give a walk through on your launch? I see in the video you started to move for just a split second, then all hell breaks loose--apparently resulting in a 1.4x 60'. Right now, I can click off a 1.6-1.5 with relative ease but I'm wondering what it is you're doing that's getting you the extra oomph.
I'll be picking up a set of MTs tomorrow which I'm hoping perform better than the Toyo's I'm currently using.
TIA for the help.
Old Jan 8, 2012 | 07:15 AM
  #5671
8850's Avatar
8850
I'm planning on next Friday. Prediction says it's going to be cold. If I can make a pass in -1000 DA I might throw up a new best. Just don't know how good.
Old Jan 9, 2012 | 05:21 PM
  #5672
winters97gt
I'll see you out there then! I think you will get a new best!
Old Jan 9, 2012 | 06:44 PM
  #5673
8850's Avatar
8850
I bet you will too. 150 mph maybe! Your car is putting down some numbers now.
See you Friday!
Old Jan 9, 2012 | 07:36 PM
  #5674
4SELLL's Avatar
4SELLL
Mark told me at a 3500 launch he slips it until he feels the car going forward and then mashes it. Is that right mark?
Old Jan 9, 2012 | 07:56 PM
  #5675
winters97gt
TIA for the help.
I think you will like the MT tires, Justin. I have used Nitto, BFG, and MT and like them the best, but haven't tried Toyo. My launch technique is just like you said. I feel the car move, then do a hard slip on the clutch. I've kept the 60fts consistant and in the 1.60-1.62 range because of the amount of power my car has and being on the stock diff. That 1.4 pass, I told the guys around me that I was going to launch the car hard that pass for the first time. I probably wont do that again unless going for a new personal best.
I think you have it nailed down on driving. I think there is more than 1 way to launch these cars, and whatever works the best for you, I would stick with it.
Old Jan 9, 2012 | 07:58 PM
  #5676
winters97gt
Yes, Dan. That is correct. Just how I personally like to do it and I feel the most comfortable that way.
Old Jan 9, 2012 | 09:14 PM
  #5677
8850's Avatar
8850
For optimum results and this is assuming you have the traction, adequate drive train and suspension, hold rpm a couple hundred below peak hp, at launch go full throttle, keeping full throttle, and work the clutch so you don't drop below peak torque and of course keeping off the rpm limiter. And if you can do that you are good! Very low first gear gearing helps make it work. And of course for best et you want to be WOT throughout the pass shifting 300-500 above peak hp. Your gearing should be such that you are 300-500 above peak hp at the finish line.
How is your car coming along Dan?
To C6 1/4 Mile Performance Challenge
Old Jan 9, 2012 | 09:28 PM
  #5678
JUIC3D's Avatar
JUIC3D
Sounds great Mark, thanks for the info. I can hit 1.5-1.6 consistently now so I feel pretty good about it. I'm excited to try the new tires and I also have a new secret weapon in the works (turbo kit) so ya, should be fun.
Congrats again on a monster of a daily driver.
Old Jan 12, 2012 | 10:49 PM
  #5679
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
The list has been updated on page one, post # 4:
NEW or IMPROVED ELASPED TIMES:
11.075 @ 124.83 Justasheet
09.843 @ 143.14 Winters97gt
Jeff nice improvement
Mark That car is Flying
Historical Record:
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - ????)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
13.354 @ 110.78 - M453W - 09 A6 NPP- (4057)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - ????)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.136 @ 115.15 - Ben Diss -07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.539 @ 113.53 - Vade46 - 07 M6 Z51 - CAI, CB - (4276)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.72x @ 110.85 - AngeloC6 - 05 A4 F55 3.15 - open shroud - (1650)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.902 @ 111.82 - Goatdad - 06 A6 - CB - (5198)
12.933 @ 110.64 - C6Vette - 05 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.820 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (4804)
10.949 @ 124.08 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (5464)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Nitto Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
12.002 @ 116.49 - Chets Z06 - 08 M6 - Nittos - (4475)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
11.528 @ 121.89 - GrandSportMan -10 A6 - CAIHM, hdr, tune, - (5533)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
Internal Engine Modifications LS2
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4330)
10.599 @ 130.09 - Dennis50NJ - 05 A4 Z51 - CAI, cam, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (4302)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.789 @ 122.48 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, DR - (5379)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
10.995 @ 126.67 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (4706)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.075 @ 124.83 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (5659)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.258 @ 124.03 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5374)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.851 @ 128.51 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb, Removed fuse, skinnies, udp, tune, DR - (5622)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 A6 - CAI, cam, hdr, tune - (3035)
Power Adders LS2 (supercharger, turbo, nitrous)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
11.521 @ 128.93 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (5369)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
11.308 @ 124.45 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (4218)
Power Adders Grand Sport (supercharger, turbo, nitrous)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
Larger Displacement (All entries)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.650 @ 141.11 - Tluck - 05 A4 Z51 - 402cid, ccw drag pack, 373, N20 & more, tune, DR - (3926)
09.843 @ 143.14 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5663)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.369 @ 134.42 - Pete Champion Motors - 06 A6 – LS7, cam, cb, conv, fast, 3.15, forged int, ph, tune, DR - (5153)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.519 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (4688)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
Old Jan 13, 2012 | 10:16 AM
  #5680
PRE-Z06's Avatar
PRE-Z06
TIA for the help.
300 more hp lol...once you figure out how the track is hooking psi/rpm, you want to bring the clutch right up to the engagement point and accelerate into the launch keeping the engine from bogging and the nose from dropping
You haven't tried the Hoosiers yet So ultimate goal now is to need a parachute?
Didn't realize you're on a completely stock diff, no hardened diff output shafts? I do believe that is a c6 m6 record!
