C6 1/4 Mile Performance Challenge
Going to need to change my time just a hair. I manage to squeak out a trio of 10.8 sec passes tonight thanks to some 1.5 60's. All this time, I thought my Toyo's were crap but it turns out, the track was actually prepped tonight and despite the DA hovering around 700-1000, I still managed to have a good launch and an improved ET.
Category: LS3 cam-only
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2008
5. Type of Trans MN6
6. Type of Suspension: Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.): Stock 3.42 Gears
8. Tires utilized: Toyo TQ DR 275/40/17, GTO Spares(skinnies)
9. Modifications: Halltech intake, OBX headers(catless), cam, underdrive pulley, CNC ported throttle body
10. Dyno numbers if you have them: 494whp/443tq
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: Launched it around 6300rpm(rofl), skinnies were aired to 60psi. Front passenger seat removed, front sway bar removed. Toyo drag radials aired at 16psi hot. Slipped the clutch and didn't allow it to bog.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Bradenton Motorsports Park
___ Date of the pass & weather conditions 12/15/2011 70* +700-1000 DA
___ 60'.............1.599
___ 330'...........4.550
___ 660'...........6.990
___ 660’ mph....101.99
___ 1000'.......... 9.089
___ 1320'..........10.851
___ 1320’ mph….128.51
Run #3
Run #3
Thanks so much.
My new goal is to take the #1 LS3 internal mods spot without removing the heads.
I still have the intake manifold I can port, gears I can add, and a lighter battery to swap.
I also want to add the lighter Hoosiers as well.
The air was also lackluster at best with DAs in the +800-1000 range.
I think with gears, better air, and a 1.4 60', I should be very close to the 10.60 spot.
-Year Corvette2008
-Type of Trans Stock M6
-Type of SuspensionStock
-Stock Performance options (as in optional gears with the automatic, & etc.) Stock Performance options
-Tires utilized MT 295/45-17
-Modifications if any 402, LS3 heads, Novi 1500
-Dyno numbers if you have them 774rwhp
-As much info you may want to add about the run, launch techniques, tire air pressure & etc Full street car the way I run it daily. No drag pack/or spare tires up front, full weight. Race weight is 3565 with me
-Name of the TrackRPR
60'.............1.625
330'...........4.321
660'...........6.569
660’ mph....112.43
1000'.........8.480
1320'.........10.082
1320’ mph…141.82
Copy of Time Slip Below
-Year Corvette2008
660’ mph....112.43
1000'.........8.480
1320’ mph…141.82
Thats Movin
PS: Blowned cars if the DA is worst can usually make up the difference; by turning the boost level up to run the same time as they did in better air/DA.
PS: Blowned cars however can usually make up the difference; by turning the boost level up to run the same time as they did in worst air.
Edit - Grandsport man commented at the same time as me...
I'm not certain, but I'm pretty sure Mark is running meth, which definitely helps negate the effects of poor DA.
-Year Corvette2008
660’ mph....112.43
1000'.........8.480
1320’ mph…141.82
The mph is there or you could just add skinnies
