C6 1/4 Mile Performance Challenge
http://dipyourcar.com/shop/page/4?shop_param=
From this
To this
And back. (The night I sold it)
How far away did you hold the nozzle?
2. A copy of your entire time slip posted to the thread: See Below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2005 Convertible Z51
5. Type of Trans MZ6
6. Type of Suspension Stock both swaybars on
7. Stock Performance options (as in optional gears with the automatic, & etc.) none
8. Tires utilized Mickey Thompson 315/35/17
9. Modifications if any See Signature
10. Dyno numbers if you have them 472/414
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 6,746 launch, 17 psi.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Palm Beach Int'l Raceway
___ Date of the pass & weather conditions 2/12/12, -581 DA per Drag Times 54 degrees, 55% humidity, 30.25 baro
___ 60'.............1.445
___ 330'...........4.431
___ 660'...........6.920
___ 660’ mph....98.15
___ 1000'.........9.047
___ 1320'.........10.815
___ 1320’ mph…128.07
Copy of Time Slip Below
Thread discussing the run:
http://forums.corvetteforum.com/c6-t...post1579995307
Catagory LS2 Bolt on
1. Your entire profile completed & read Instructions: Done
4. Year Corvette 2007
5. Type of Trans A6
7. Stock Performance options (as in optional gears with the automatic, & etc.) stock 2.56
8. Tires utilized Mickey Thompson 305/35/R18
9. Modifications if any CAI, 3200 FTI Conv, PFast,Hdr,no cats, MTW,160 TS, Z06 Mufflers,Tune, DR
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc Left a 1500 rpm, 22psi in DR & 42 in Front tires
___ Name of the Track State Capitol Raceway Baton Rouge
___ Date of the pass & weather conditions 2/12/12, -1700 DA per Drag Times 45 degrees, 35% humidity, 30.53 baro
___ 60'.............1.574
___ 330'...........4.613
___ 660'...........7.165
___ 660’ mph....95.37
___ 1000'.........9.353
___ 1320'.........11.194
___ 1320’ mph…122.53
[IMG]
[/IMG]
[/IMG]
Skinnies will help, you wait and see. They are a great mod.
NHRA/IHRA rules have always been directed at narrowly defined classes of competition. Due to a number of evolutionary changes, very few cars going down the track today fit in any specific class, so each track has created their own version of competition. However, to be a NHRA/IHRA member track they still group cars by the ET reference guides for required safety equipment.
The tech inspector is far more concerned with a young kid in a '90's import with nitrous who runs high 11's, than a mid-forties guy with a $50K Corvette bolt-on running low 11's.
A rollbar is just one of several, on the list of items supposedly required below 11.00, but it's the main one the tech guy wants to see.
That being said, I did get a 'talking-to' the last time I was at the track when it went 10.70s. I was asked to run N/T from now on, unless/until I get a roll cage and that they just want to see some effort from the 'fast street car' crowd. They understand not wanting to put a roll cage in my daily driver but they wanted me to have a fire jacket from now on and to make sure my times aren't displayed. I guess it's all about attitude and making friends with the track officials while walking the line between breaking the rules and staying safe.
I'm doing my 1.50 60fts with 40mm less rubber
The 315's are more forgiving to a less than stellar prepped track I've found. But not worth the cost of a wide body. I don't think the extra weight is hurting me much.
