C6 1/4 Mile Performance Challenge
The engine displacement is 6.8L/414 cid, Callaway developed and assembled. It has a 4.125" bore GM Motorsport cyl. block, 3.875" stroke 4340 steel crankshaft, custom forged pistons, CNC-ported heads, custom camshaft and valvetrain, etc., with stock 6 speed man. trans., on 93 octane pump gas. A very streetable configuration. It had 3.90 gears and drag radials when it turned the 10.7's.
(Current production Callaway SuperNatural 550's are 427's/7.0L with stock final drive ratio. The man. trans. cars are capable of consistent 10.9's on drag radials.)
YUP what a ride
I got to see it run last year at the Corvette show & go at Englishtown. Hey check out our discussion on TM in the C6 Corvette.http://forums.corvetteforum.com/show....php?t=1433999 any input will be greatly appreciated Thanks
Tommy
2005 (2006 Model year noted by 06)
Drag Radials posted below stock ETs
David K runs 12.49 @116 nice times
Bone stock
06C6FVR, Z51 ....12.23 @ 115.58 06
DrRichie, Z51 .... 12.42 @ 113.9
David K, Z51 .......12.49 @116
Jschindler, Z51 .... 12.49 @ 114.9
Orange C6, Z51/auto .... 12.5 @ 112
Nine Ball, Z51 ..... 12.54 @ 113.24 (fan/stat mod)
Zippin Zee, Z51 .... 12.65 @ 111.65
Demented, Z51/auto ...... 12.71 @ 111
Shooter 49, Auto/3:15 .... 12.74 @108.67
Tommy D, Auto/3:15 .... 12.83 @109.44
Jchazr, Z51 ...... 12.86 @110.98
Ginny C6, Auto/F55 .... 12.97 @ 108
Tampa Vet, Auto/3:15 .... 12.98 @108
C64ME, Z51 ........12.99 @111.7
Soldsyclone, Auto …….13.05 @ 108.7706
C6 Matt, Z51 ........... 13.25 @110.6
JDWK, Z51 ………. 13.25 @108.4
Rich28, Z51/auto ...... 13.62 @ 106.18
Cai
Demented, Z51/auto ........ 12.48 @ 113
Sditch, Z51/auto ...... 12.65 @ 111.39
Cai, Larger Tires 325/30
Lusky, Z51/Auto.......12.63 @ 112.35 06
Cat Back
WS6JJP, Z51 .... 12.41 @ 112.07
Jschindler, F55/6sp ....... 12.57 @113.04
FLC6, Auto/3:15 .... 12.7@
Thanos, Z51/auto .... 12.8 @
Zoli007, Z51 ....... 12.97 @ 111.22 06
Parkev. Z51....... 12.99 @ 111.25
Cat Back & Cai
Icebourg, Z51 ..... 12.418 @115.4
Anky1631, 6sp ..... 12.54 @ 113.63
FLC6, Auto/3:15 .... 12.55@
Cat Back & Cai Nitrous
FLC6, Auto/3:15 .... 11.89 @ 120.20
Cat Back & Cai, Tune
Larry Chip, 6spd .... 12.5 @ 118
Headers & Cat back
CTVette05, auto/3:15 .... 12.37 @ 112.29
Headers & Cat back, Cai
2003Anniversary, Z51/auto..... 12.55 @111.98
Headers, Cat back, Cai & Tune
SScamero, Z51 .... 12.6 @ 114
1955 Belair, Z51/auto ....12.938 @ 108.60
Headers, Cat back, Heads & Cam, Converter
Blue Racer, Z51/auto..... 12.1 @ 115.36
Headers, Cat back, Cai &Tune, Heads & Cam, Intake
Mitchell242, 6spd ....... 13.12 @ 119
Heads & Cam, Intake
Xstang, Z51....... 12.6 @ 118
Tune
Flooznie, auto .......12.50 @ 115.2
Drag Radials
Cai, Cat Back, Converter, Headers, Heads & Cam, Intake, Tune, UD
1955 Belair, Z51/auto ....... 11.76 @ 116.76
Just orederd the procharger kit
-Dennis
Only change was I practiced my shifting based on this thread from Ranger:
http://forums.corvetteforum.com/show....php?t=1424699
I had a big problem going from my C5 shifter to the C6 until I practiced, now I can shift my C6 just as fast.
whats the different?
Ranger
MM6 is the option code for the 6 speed manual without it.
Both use the Tremec T56 6pseed manual. However the Z51 equipped car (MZ6) has more aggressive transmission gearing, through gears 1,2,3 for quicker acceleration.
Ranger
So you are saying I can find 2-3 tenths in shift points? So far the best results have been shifting all at redline, in fact I tapped the limiter briefly on the 3-4 on the best time. Anytime I go less on any shift I'm much slower, usually 2-3 tenths. What did you find to be optimal shift points?
I'll tell you one thing though.... those pesky C5 LS6's sure have more top end than us. I ran next to JohnSea06 all day and he handed me my behind every time if he was close at 1000 ft. I had to tree him good to beat him.
I'm scheduled for headers, trans brace, hardened shaft & 3:90's on Wednesday. Might go for a little lower than 1.8's with that setup
Ranger
Of course, I always mention my times are grannyshifted.
If you want to powershift and get those extra strengths, by all means go for it!
Howard
Unfortunately most will tear the he11 out of their vehicle learning how.
