nice, but i would have thought that the 1.96 60 ft would have yileded 12.3x
Originally Posted by mdrrandall
I went last night and it was still 85 degrees outside but I installed a vararam and a flowmaster axle back since running it bone stock but still with the run flats.
I would normally guess that too but the consecutive runs I think were causing the engine to run a little but higher temps than normal. I tried to allow for cool down between runs but at 85 degrees it is hard to cool the car down. I did notice the mph was the same as previous but I would imagine had I let it fully cool down maybe the run would have been better, just speculating though. You never know, there might have been a slight headwind on that run
My 60 ft for that run was 1.742........but I have a problem with tapping the brakes because I use hand controls. When I push down on the controls (gas) I actually push alittle forward (brakes) and this you can see in my videos of the runs. The car's brake lights flashing after the 1/8 mile mark.
I was wondering if you guys will seperate the LS2's & LS3's when you start getting info on them. It should be interesting. If not, that's okay, if those that post identify what the heck they're driving!
Nah I don't think they will be separated at all, it would mean far too many sections and sublists for all of the various stock and modded categories and I think that's a lot to ask of Tommy D (or anyone else) to constantly maintain.
But yes it will be needed to specify which motor (or simply which model year?) the C6 has when requesting spots on the current lists.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
There have been many suggestions with regard to changes to our list. I have taken a "wait & see" position with regard to making a separate list for the LS3's .......... for now we will have one list.
I have received many suggestions with regard to changes. Once we see what the LS3's do ............ I'll present all the suggestions and we'll discuss the suggestions before the list is modified
Tommy, I didn't realize the huge scope of your listings. I suppose just having the year will do the same thing. Of course, what also happens is as more amd more LS2's break in, their times will also get better.
