Vararam install nightmare....
Old Dec 28, 2007 | 09:05 PM
  #121
asian-winkie's Avatar
asian-winkie
Originally Posted by goatts
Just installed my Vararam the other day. I found the fit to be excellent. If there is trash getting by the filter it's due to installer error.
Give a month a recheck. The heat and the vibration will effect it.
Old Dec 28, 2007 | 09:07 PM
  #122
asian-winkie
Originally Posted by dennis50nj
i havent had a problem with warranty work, even with all my mods
I don't think they will warranty your engine when they find out all the debirs in the cylinder.
Old Dec 28, 2007 | 09:13 PM
  #123
asian-winkie
Not my car but it looked close to this. Try talking your way into warranty this.
Old Dec 28, 2007 | 09:15 PM
  #124
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Hey, Asian winkie, i thought you said that you weren`t on here to bash the Vararam? Yet all your posts are bashing Funny, i have had the Vararam on my car for over 2 years now and i have never had a problem. I think its all about the install,and if you install it the wrong way, anyone will have problems. And by the photos that you posted you can clearly see the crack,so who`s fault is that? If you had a crack why did you install? Why would you install something that was cracked? I think that you messed up the install and are blaming others when you should be accountable.
Old Dec 28, 2007 | 09:35 PM
  #125
asian-winkie
I could get real details on Vararam and start the name calling, but I am not here for that. There are several posting about this problem and I want people to be aware. This is nothing to over look lightly because it could lead to catastrophic failure. Its your $$$, go ahead and install what ever you want but be warned.
I am glade you are not going through what many of us have experienced, but there are always exception to the rule. It is a very expensive gamble that many people are taking. From what I have been reading, the quality and reliability on Vararam is a hit or miss.
Are you talking about the crack on the bottom of the intake side? I can't 100% that is a crack but why would that effect what is BEHIND the filter?
Old Dec 28, 2007 | 09:44 PM
  #126
asian-winkie
PS Tony B4 like your choice in color
Old Dec 28, 2007 | 09:46 PM
  #127
Tony B4's Avatar
Tony B4
St. Jude Donor '08
When you installed the unit did you look to see if the gasket made the perfect seal? I bet you didn`t. What do the directions say about the install? Make sure both pieces are together before you install into the car. I can almost bet my bottom dollar that you installed the bottom piece first and then the top piece and then put the straps on....That is the wrong way to do it...Anytime you want to strap those pieces together its supposed to be out of the car...Its in the directions...And if you followed the directions you would have seen that the gasket didn`t properly match up....Its all about the install.
Old Dec 28, 2007 | 09:47 PM
  #128
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Old Dec 28, 2007 | 09:49 PM
  #129
Tony B4's Avatar
Tony B4
St. Jude Donor '08
The entire unit should be sealed with straps outside the car and then install as one unit.
Old Dec 28, 2007 | 09:53 PM
  #130
asian-winkie
I use to turn wrentch for a living and I can assure you that it was installed properly. The problem comes from heat, vibration, weak glue, and foam. The glue or double sided tape is not strong enough. My Vararam come form the factory with miss aligned foam. It was all over the place so I had to correct it.
Old Dec 28, 2007 | 09:55 PM
  #131
asian-winkie
The overall quality of the product is not there. Plastic is too thin and looks like it start distorting under heat.
K&N and KB use much thicker plastic yet they both distort.
Old Dec 28, 2007 | 09:58 PM
  #132
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Mine did to but i called Steve and he sent me the gaskets for free and extras too. I am telling you that its like anything else, you just don`t throw it on their and forget about it....Its just like checking oil/tires.
Simple pre-trips once in awhile.
Old Dec 28, 2007 | 10:02 PM
  #133
asian-winkie
But don't you think the quality should be much better for the $$$ you are paying? Special on such a critical piece?
Old Dec 28, 2007 | 10:09 PM
  #134
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Anything can happen in shipping. So i don`t blame anyone for the gaskets, but as far as quality goes....I am telling ya, its top notch, i get complements all the time and i also put a little armoral on it and it shines. Now i know some people don`t think that the quality is good but i don`t see what there talking about and i have 20/20
Maybe i am lucky, i guess, but i will always stand by this product because it flat out works and looks good. By the way i am a truck driver and i am not in anyway getting paided to say this I drive concrete trucks for a living, Kenworlths
Old Dec 28, 2007 | 10:15 PM
  #135
Jim_H's Avatar
Jim_H
I have to disagree, it ain't like checking your oil or tires.
I can't remember the last time I thought I had to check to see if MY air cleaner was still working right, and not falling apart on any car, truck, bike or boat I've ever owned (aftermarket or not).
Old Dec 28, 2007 | 10:19 PM
  #136
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Why wouldn`t you check to see if the gaskets were sealed before installing in the car? Can you answer that? Did you ever own a Vararam?
If not then this discussion has nothing to do with you.
Old Dec 28, 2007 | 10:34 PM
  #137
Jim_H's Avatar
Jim_H
I would check everything when installing something, but that isn't what you said, maybe you should re-read your own post.
I admit I don't own a Vararam, for a reason. Sorry if you don't like my opinion in YOUR discussion, but tough S&*t.
To Vararam install nightmare....
Old Dec 28, 2007 | 10:46 PM
  #138
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Dude I hate to tell you but shiny black plastic, post amoral coating does not equal quality.
Old Dec 28, 2007 | 10:51 PM
  #139
3 Z06ZR1's Avatar
3 Z06ZR1
It is all about the install. You have adjust correctly,On mine It was
cutting the angled coupler about 1/2" more. I had the big filter that was too big for the front and had no design to it. "big filter"
is about it.and the fit was worse, Couldn't see how it was supposed to get air since it was solid rubber on the bottom where the then Vette -air (good product for stock 08's or K&N's unit.) bring's the air in and the bottom layed on the shroud futher blocking air. Only thing left was pulling some warm/cool air mix from the underhood.Unless
you make a cover.
Vararam is no worrys if you get it together and on correctly.
least all you get is cold air period.
Old Dec 28, 2007 | 10:54 PM
  #140
asian-winkie
easy guys. Keep one thing in mind, we are all here to help each other. We don't need to get nasty.
I have dishagree on the quality of the Vararam, I've been moding over 17 yrs and quality of Vararam has been very disappointing
