Check Engine Light
Old Dec 28, 2007 | 08:16 PM
double a vette's Avatar
double a vette
Default Check Engine Light
Asking for help for code 0701 on HP Tuners . Car has been tuned and just started doing this recently. Help would be appreciated.
Old Dec 28, 2007 | 08:29 PM
johnodrake's Avatar
johnodrake
Moderator
Code is P0701 - Transmission Control System Range/Performance
Other than that, don't have a clue.
Old Dec 28, 2007 | 10:43 PM
knkali's Avatar
knkali
auto?
Old Dec 28, 2007 | 11:01 PM
double a vette
05 z51 6 speed
afr205
lg long tubes
comp camps cam
fast intake
varram
underdrive pully
160 stat
390 gears
tuned by phill97svt
Old Dec 28, 2007 | 11:09 PM
knkali's Avatar
knkali
try the tuners forum section but i think if you hang here you will get an answer. Bump for ya
Old Dec 29, 2007 | 03:22 PM
Phil97SVT's Avatar
Phil97SVT
The car is a AFR 205/Custom cam with ford 42# injectors. Car was tuned and made 490/447 on a dynojet, dealer reflashed the "PCM" changing a portion of the program that corresponds to the Onstar. Now the car has a lean bank 1 & 2 code. I'm leaning toward the "fix" performed by the dealer is causing the issues. I'll have the car in a couple of days to trouble shoot it.
Phil
To Check Engine Light
