Nav screen delete
Old Dec 30, 2007 | 05:21 PM
Bobootz's Avatar
Bobootz
Default Nav screen delete
Does anyone have info on how to delete the C6 logo from the nav screen? I'm thinking the logo will burn itself into the screen after awhile
Old Dec 30, 2007 | 05:23 PM
johnodrake's Avatar
johnodrake
Moderator
No but it is simple to turn the screen off.
Old Dec 30, 2007 | 05:57 PM
kwickag's Avatar
kwickag
Also, the screen is an LCD so it isn't subject to burn in.
Old Dec 30, 2007 | 06:06 PM
toro1966's Avatar
toro1966
This is incorrect. While I agree that LCD's are less susceptible to burn in, they are still subject to burn in none the less.
Cheers.
Old Dec 30, 2007 | 06:11 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Cheers.
It is referred to as "LCD Image Persistence":
Image persistence on LCD's is generally caused by the continuous display of static graphics on the screen for extended periods of time. The static image causes the LCD crystals to remember their location in order to generate the colours of a given image. When a different colour is then displayed in that location, the colour will not be displayed correctly and may show a faint image of the "picture" that was previously displayed.
LCD image persistence can be prevented by:-
1. Using windows power management settings to turn off the screen after a few minutes of screen idle time
2. Using a rotating / moving screen saver
3. Rotating the background images/wallpaper on the desktop
4. Turning off the monitor when not in use
If your LCD is suffering from image persistence try the following:-
1. Turn off your monitor for extended periods of time, you may need to do this for several hours or even several days.
2. Use a screen saver with a rotating image and run it for extended periods of time. The rotating colour palette should help remove the persistent image but it could take a long time
3. Run the screen with a single solid colour or bright white background for an extended period of time, this will cause all of the crystals to be reset at a single colour setting and should erase any previous image persistence.
Old Dec 30, 2007 | 06:25 PM
dennis50nj's Avatar
dennis50nj
so then you are saying when the radio mode is on this will burn in too. same station for 25,000 miles
Old Dec 30, 2007 | 08:53 PM
*FAÇADE*'s Avatar
*FAÇADE*
WOW, the SAME station for 25,000 miles??
With devotion like that, I am sure that you will be spared the "dreaded burn-in" by the "airwave gods"!!
Happy New Year To You!!
Old Dec 30, 2007 | 09:28 PM
robvuk's Avatar
robvuk
Not an issue with modern day LCD's. It's not the same as plasma or CRT burn-in either. If it does show up at all, its only on monitors that are on the same image for 24/7/365. It is temporary and usually avoided by turning the monitor off for as little as 15 minutes per day. This will surely never be an issue in your car. Besides, if I'm not mistaken, the screens on the Corvette navigation is an OLED NOT an LCD. So don't worry about it and enjoy your car.
Old Dec 30, 2007 | 09:39 PM
dennis50nj's Avatar
dennis50nj
Old Dec 30, 2007 | 09:55 PM
Maui's Avatar
Maui
St. Jude Donor '08
I don't understand. The flags only show up for a few seconds until the nav comes on.
Old Dec 30, 2007 | 09:56 PM
*FAÇADE*'s Avatar
*FAÇADE*
You are absolutely correct, although "burn-in" is possible with all LCD screens, one would have to leave the same image on the screen continuously - as you said, 24/7/365!
And I agree with you as well, that the OP should just enjoy his Vette, however, if it is a concern of his, he can always turn the screen off.
SCREEN OFF
Touch SCREEN OFF to turn off the screen. Press the NAV, SRCE, or / (audio adjust) hard key
to turn the screen back on.
Happy New Year!
Old Dec 30, 2007 | 10:30 PM
robvuk's Avatar
robvuk
Happy New Year!
I looked it up to verify. It is indeed NOT an LCD screen. No need to turn it off.
Old Dec 31, 2007 | 04:17 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
The gauge cluster info bar is OLED; the navigation is LCD.
To Nav screen delete
