Header Coating
Old Jan 5, 2008 | 12:26 PM
timd38's Avatar
timd38
Default Header Coating
Does anyone have experience with coated and non-coated headers?
I hear two stories on header coating. One says you are wasting your money if the are stainless steel, and other says do it, because it keeps the heat in the headers and keeps the engine compartment and tunnel area cooler.
Thanks!
Old Jan 5, 2008 | 12:46 PM
vettl83's Avatar
vettl83
I had my Kooks coated by Jet Hot, besides keeping the heat down a little the cosmetic value alone was worth it to me. I have none coated stainless headers on my ZR1 and they do discolor despite being stainless.
Old Jan 5, 2008 | 12:48 PM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
Old Jan 5, 2008 | 03:43 PM
C6LSx's Avatar
C6LSx
St. Jude Donor '08
As mentioned above and speaking from experience; the Jet-Hot sterling coating prevents the polished stainless steel from discoloring and does significantly reduce the underhood heat temperatures associated with LT headers.
Old Jan 5, 2008 | 03:47 PM
Range_Rat's Avatar
Range_Rat
I have LG LT's --- same thoughts. One other thing, they sure are purdy with Jet Hot coating.
Old Jan 5, 2008 | 07:22 PM
HeadPapago's Avatar
HeadPapago
Old Jan 5, 2008 | 07:34 PM
siffert's Avatar
siffert
I had my Kooks headers coated with Jet Hot 1700 Extreme Sterling for free from MarylandSpeed. They look good, jury is still out on the reduced underhood and cockpit heat until summer weather heat. I called Jet Hot to see if they clean the inside of the pipes of the grease and shavings prior to coating and they said they do. I sure hope so...it did look smooth from what I could see inside. Not sure how much coatings help but dont think they hurt.
Old Jan 6, 2008 | 03:36 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Old Jan 6, 2008 | 04:07 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Thanks!
Once you have had coated ones,
you'll never go back.
Old Jan 6, 2008 | 05:48 AM
805Z06's Avatar
805Z06
It's going to be hard to notice. With my headers, I first installed the tunnel plate. I didn't notice the difference much. My headers are now coated, and I still don't notice the difference much. There is too much heat coming through.
The best solution is to add additional insulation around the gear box area.
Old Jan 6, 2008 | 06:07 AM
timd38's Avatar
timd38
Thanks everyone for your feedback! It sounds like the key is that it makes them look really good and the other value is marginal. The posted pictures sure do make them look "purdy"!
Old Jan 6, 2008 | 11:14 AM
vettl83's Avatar
vettl83
Jet Hot also has other colors available too.
Old Jan 6, 2008 | 11:17 AM
timd38's Avatar
timd38
Thanks for the feedback. I just took the coating dollars and bought a tunnel plate.
Old Jan 6, 2008 | 01:35 PM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
We sell a ton of coated headers..and quite honestly an uncoated header would never touch one of my cars. The science is there behind the coating, which I have posted several times..and additionally, your part looks good longer.
In my experiance, the places that try to talk you out of coating do so because quite honestly, it is a hassle shipping the parts around..and having the customer wonder where their header is for two weeks. It is easier for them to just sell you an uncoated header..take your money, and get you out their face. Also, there is really not any money in coating..it is something you add at cost or so. So next time you hear someone going on about how coating sucks...take a deeper look...there is likely other motivation
We have a free coating sale going on here that is a great deal. It includes free shipping, and Jet Hot 1700 degree extreme sterling for free.
http://forums.corvetteforum.com/show....php?t=1873105
Old Jan 6, 2008 | 03:02 PM
Wayne88's Avatar
Wayne88
Originally Posted by siffert
...if they clean the inside of the pipes of the grease and shavings prior to coating and they said they do. I sure hope so...it did look smooth from what I could see inside. Not sure how much coatings help but dont think they hurt.
The way I see it, If the inside coating flakes or chips, it could clog the cats.
Old Jan 6, 2008 | 03:25 PM
timd38's Avatar
timd38
Thanks for the info! I was going to have it done in Detroit, so the shipping issue wasn't a concern, but your right, it is a hassle. We used to coat our kart headers, so I am familiar with most of the pluses, but I never had stainless headers on a car before.
The headers haven't arrived yet and I still believe that I need a tunnel plate, I may just do them both.
Old Jan 6, 2008 | 03:47 PM
3 Z06ZR1's Avatar
3 Z06ZR1
I did the other way except there was no coating dollars,
Free coating, at great delivered price. Stainless will heat discolor and stain
No coating wrong move.IMO I added a heat sheild in the tunnel above
the exhaust.
To Header Coating
Old Jan 6, 2008 | 04:54 PM
glennhl's Avatar
glennhl
In my opinion the only reason to coat Stainless Headers is for the bling.
1) Stainless steel has 1/3 the thermal conductivity of carbon steel. The thermal coating (Jet Hot) is needed for Carbon steel to cut the heat transfer and to keep them from rusting. The coating is just not needed for the stainless.
2) If I'm going to spring extra to buy stainless headers, I'm going to show them off. When I see coated headers I figured the guy was cheap and bought carbon steel headers.
Old Jan 6, 2008 | 05:22 PM
1.8t's Avatar
1.8t
If you think the only reason people buy coated headers is to keep the from rusting, you VERY mistaken.
Old Jan 6, 2008 | 05:27 PM
timd38's Avatar
timd38
Why? That is why I am asking the question.
Thanks!
