Keep hitting the rev limiter
Old Jan 6, 2008 | 09:53 PM
From C6ZO62C8's Avatar
From C6ZO62C8
Default Keep hitting the rev limiter
I hit the rev limiter 50% of the times, I keep short shifting so I don't hit the limiter, I can't do a redline shift like the CPU, so from now on I leave it in S or D
from a roll I down shift to the correct gear and once I punch it I pop it in D then S, shifts right at redline
sick of hitting the limiter
and like other members, if my wheels spin or car goes sideways in 1st I can't shift to 2nd via the paddles
Old Jan 7, 2008 | 06:44 AM
BlackZ51Vett's Avatar
BlackZ51Vett
The paddles have always been a problem trying to shift in the upper RPM's near redline. It's best to use the tranny in "S" for competition shifting as it will allow the engine to use the entire RPM band......I hope someone will someday come up with a fix for this problem as I like to use the paddles myself and would like more instant shifts with them...
Old Jan 7, 2008 | 08:42 AM
siffert's Avatar
siffert
You have to learn and train yourself at what rpm below redline you need to shift so that you dont hit the limiter. Once you do, it no longer becomes such an issue. Generally, it is at least 500-600 rpm below redline (5800-5900 rpm's). Its the nature of the A6 paddle system...it takes a bit for the computer to get the message to shift. Its a little better in the '08 but am afraid you'll have to wait for the C7 for, hopefully, a major improvement. btw-folks who drag race their C6 A6 at the strip
never use the paddles to shift, just "S" mode.
Old Jan 7, 2008 | 01:17 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Mine has hit the rev limiter in S mode before. Not often but occasionally which is still too often. Should never happen in S mode.
Old Jan 7, 2008 | 02:38 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Old Jan 7, 2008 | 02:44 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
You could always buy a 6 speed manual
Old Jan 7, 2008 | 02:56 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Then how would he drink his coffee.
Old Jan 7, 2008 | 05:25 PM
PowerLabs's Avatar
PowerLabs
And talk on the cellphone
Old Jan 7, 2008 | 05:49 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
And put his arm around his chick.
Old Jan 7, 2008 | 06:11 PM
From C6ZO62C8
yeah I've tried to practice, but it seems to always throw me off in 1st, because 1st revs so much faster than the other gears and the biggest problem is
1. when the wheels spin, the paddles don't work
Old Jan 7, 2008 | 11:03 PM
1yy07vette's Avatar
1yy07vette
mine hit the rev limiter in D mode once getting onto the 4 lane,.
doing about 40/45 mph. took it to the dealer, no codes and
nothig on dic.
Old Jan 16, 2008 | 01:32 AM
siffert's Avatar
siffert
I have heard that other '08 A6 owners have tractions problems too...its either more TM (Torque Management) added to the '08 or the added HP is beyond the threshold of the runflats...though I see you added the shocks and sways. Dont have those problems on my '07...one good thing to be said for the LS2!
Old Jan 16, 2008 | 06:57 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
problem solved.
hold the coffee in your left hand. gotta be quick with the shift though, esp. during turns.
use the hands free function
in that case, she will need to be the one handling the stick.
to answer the op, i agree with the others. you will need to determine the 'delay' for each shift at the desired rpms and adjust accordingly.
To Keep hitting the rev limiter
