Invos do help!
Old Jan 10, 2008 | 03:33 PM
ROUSHMAN CONVERT's Avatar
ROUSHMAN CONVERT
Default Invos do help!
Hey all just another data point. I recently swapped in all four Nitto Invos, so far so good, sticky, coner very well, case in point, purposely ran through a puddle of water, stabbed the throttle, tire shook the water and hooked. Don't know about high speed ride yet?????? Like I said at the beginning, just another data point.
ROUSHMAN
Old Jan 10, 2008 | 03:40 PM
LS1LT1's Avatar
LS1LT1
I'm curious how they'll perform at the drag strip, while I'm sure they'll be better than stock run flats they likely will not be any kind of a substitute for drag radials...it's just that being available in the C6 19" size makes them real convenient for use on stock rims.
Old Jan 10, 2008 | 04:20 PM
6Speeder's Avatar
6Speeder
I'll bet the ride is better and quieter to boot. I'm figuring the cold weather traction will be better than the GY's, hoping the warm weather traction is better also.
Old Jan 10, 2008 | 05:38 PM
C6VetteMan's Avatar
C6VetteMan
Keep testing. I'm
Old Jan 10, 2008 | 06:32 PM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
I pulled a 1.8 60' with them. Not drag radials, but not bad either.
Old Jan 10, 2008 | 07:42 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Old Jan 10, 2008 | 07:54 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by C6 DVL
Oh snap!
Old Jan 10, 2008 | 08:08 PM
ROUSHMAN CONVERT
Love the post bro! u be rolling............
Old Jan 10, 2008 | 09:18 PM
Ben Diss's Avatar
Ben Diss
Old Jan 14, 2008 | 04:45 PM
ROUSHMAN CONVERT
This morning the outside air was around 37 according to the car, the F1 eagle's would go nuts at this temp, INVOS little or no tirespin, bear in mind I'm only at 356rwt.............I'm pleased so far, I'll have to wait until May to see hot temp perf, hope this helps...........RM
Old Jan 14, 2008 | 10:27 PM
C6VetteMan's Avatar
C6VetteMan
Default Nitto INVIO's
I order a set last week. I still all Thanks for the update !
To Invos do help!
