FAST intake question
Old Jan 11, 2008 | 10:32 PM
JLINDSEY2's Avatar
JLINDSEY2
Default FAST intake question
I'm getting Cam and Clutch done on Wednesday-already looking down the road to an intake-my question is will a retune be required if I switch to a FAST intake from the stocker?
TIA
Old Jan 11, 2008 | 10:40 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Yes it will have to be tuned with a Fast or even a ported stock intake.
Old Jan 11, 2008 | 10:45 PM
JLINDSEY2's Avatar
JLINDSEY2
Default ...
Yea, I figured that, and esp. since I will prob go w/a 90mm tb.
Thanks man!
Old Jan 11, 2008 | 10:48 PM
Miaugi's Avatar
Miaugi
Thanks man!
I think your '05 would've come from the factory with a 90mm TB.
Old Jan 11, 2008 | 10:50 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
If you order the fast, you need the Fast Intake 90.
Old Jan 11, 2008 | 10:58 PM
Rockdog's Avatar
Rockdog
I would also like to get a fast intake with a cam also. What kind of HP increase can I expect to get with a good streetable cam/fast intake?
Old Jan 11, 2008 | 11:04 PM
JLINDSEY2's Avatar
JLINDSEY2
Default ...
The reason i'm asking is because of the new article in Hot Rod (engines), they got 19 flywheel horsepower from a FAST intake swap from stock.
LG has a 90mm tb available too. Comes with harness for around 500 bucks.
All results above are dyno numbers.
Old Jan 11, 2008 | 11:30 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Weiand is coming out with a new plastic version of its LS series Cast Aluminum intake this March that may be better than the Fast intake for a stock LS2.
Old Jan 12, 2008 | 01:09 AM
vetracn98's Avatar
vetracn98
St. Jude Donor '08
Will you get that much gain going to a fast intake after your mods?
Old Jan 12, 2008 | 01:17 AM
LS1LT1's Avatar
LS1LT1
But that's what they're trying to say above, you do not need to buy an aftermarket 90mm throttle body, your car already came with one. Just mount it up to the Fast 90mm intake.
You may choose to port your stock TB though, that can help a little bit.
Old Jan 12, 2008 | 04:19 AM
satans csex's Avatar
satans csex
BUY A Zo6.................
Old Jan 12, 2008 | 07:18 AM
JLINDSEY2's Avatar
JLINDSEY2
Default ...
Yea, I guess I mis-spoke myself, I meant to say ported. I was wondering from you guys that have the FAST if you gained that much HP from the swap.
Sad, isn't it-haven't got the cam in yet and already looking at the next mod!
Old Jan 12, 2008 | 07:20 AM
JLINDSEY2's Avatar
JLINDSEY2
Default ...
GET OUTTA MY THREAD....TROLL!
Old Jan 12, 2008 | 10:08 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
It's funny that he said that! His profile say's ' Tuner Shop Owner '
Anyway I have my 05 cammed with the Fast 90, great combo, the Fast 90 will give some nice torque in the mid range, and even more with the cam.
Old Jan 12, 2008 | 10:15 AM
JELSIS's Avatar
JELSIS
Old Jan 12, 2008 | 10:22 AM
Wallacefl's Avatar
Wallacefl
the new Weiand repotedly provides 15 more hp thru the midrange over the FAST per the discussion on LS1 TECH.
Old Jan 12, 2008 | 01:03 PM
LS1LT1's Avatar
LS1LT1
Nah, according to other posts he's not a shop owner, he's an independently wealthy 17 year old that owns LS2s, LS3s, Z06s and properties all over southern California yet never took a dime from his parents for any of it LOL.
To FAST intake question
Old Jan 12, 2008 | 01:05 PM
LS1LT1's Avatar
LS1LT1
Wow, they're saying that much? I've read a little bit about it over there as well and knew that it could show plenty of gains over stock but didn't know it excelled that much over the FAST in some areas. And it'll be a little cheaper too.
Nice.
Old Jan 12, 2008 | 02:13 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Nice.
Im holding off on buying the FAST till I get some dyno results on the
new wieand . Its hard to believe 15 HP/TQ over the FAST. Then we must consider the aspect of one ported unit over another. I had a thread going "Ported OEM VS Ported FAST" My tuner figures at least
10 for the fast over the oem ( BOTH PORTED ).
Old Jan 12, 2008 | 02:22 PM
LS1LT1's Avatar
LS1LT1
It is possible I guess but I would want to see some in depth testing of a true production unit on a C6 before passing any further judgement.
Yes, I think it would be at least that much between the two. There are of course other various benefits to choosing either route as well.
