Spark Plugs
Old Jan 12, 2008 | 02:46 PM
timd38's Avatar
timd38
Default Spark Plugs
Putting headers and a tunnel plate on my car and since I have to remove the plugs, is there a recommended plug to change to at the same time. Just a plain old LS2 Manual with CAI, 160 stat, TB spacer and a 92 octane tune.
Any recommendations, or should I just put the stockers back in, the car has 6,000 miles on it.
Old Jan 12, 2008 | 02:48 PM
LS1LT1's Avatar
LS1LT1
At only 6k miles the OEM plugs are still good (though I would check/correct the gap before reinstalling them) but personally I would put some NGK TR55 plugs in if they're coming out anyway.
Old Jan 12, 2008 | 03:10 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
I would let the original Plugs in. If you have two people doing the install
carefully youdont even need to remove the Plugs. I know im going to get some comments on this but it worked for me. I would also reuse the OEM Gaskets. Good luck on your install.
Old Jan 12, 2008 | 03:17 PM
SoldSyclone's Avatar
SoldSyclone
I only had to remove one plug on the drivers side kooks 1 7/8 doing the install myself, I would leave them in no reason to remove IMO.
If you do it by yourself use a piece of rope to lower the stock manifolds.
As recomended by many reuse the stock gaskets and bolts for a no leak install
Old Jan 12, 2008 | 03:22 PM
timd38's Avatar
timd38
Thanks everyone for the info. I will just keep the stockers.
Old Jan 12, 2008 | 08:06 PM
vette05's Avatar
vette05
I did my install by myself (my first header install). I only removed the plug wires not the plugs. Just be careful when removing the manifolds not to let them drop down on them. Piece of cake.
Old Jan 13, 2008 | 10:51 AM
overrev64's Avatar
overrev64
Platinum tipped plugs should not be re-gapped. Just re-install them.
Old Jan 13, 2008 | 11:31 AM
Ragtop 99's Avatar
Ragtop 99
I'd do them while I had everything apart.
Old Jan 14, 2008 | 01:45 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Completely agree. You will have better performance from a copper plug vs. the factory platinum's they will just not have the same life.
Old Jan 14, 2008 | 02:47 PM
obaidan's Avatar
obaidan
What kind of performance gain will one get?
Old Jan 14, 2008 | 03:07 PM
LS1LT1's Avatar
LS1LT1
True, unless of course you dropped one or banged it in the manifold while taking it out.
And let's not forget that the gap might've been off along, wouldn't be the first time I've heard of that happening right from the factory...should one still not re-gap them in that case?
Old Jan 14, 2008 | 04:25 PM
Former Vendor
I'm not talking big hp changes unless the factory plugs were not doing their job to start with. However the Copper plugs do fire better than a plat.
Old Jan 14, 2008 | 06:21 PM
PAUZAO's Avatar
PAUZAO
What about the NGK Iridium IX series? How would they benefit being used versus the NGK TR5 or 55's?
Old Jan 14, 2008 | 10:00 PM
PAUZAO's Avatar
PAUZAO
TTT
Old Jan 14, 2008 | 11:50 PM
LS1LT1's Avatar
LS1LT1
The only likely benefit is going to be longevity, they will out last (meaning changing your plugs less frequently) the cheaper and shorter life TR55s but they will not perform any better (likely worse) than them in a naturally aspirated stock cubic inch application.
Old Jan 15, 2008 | 12:56 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
So, I guess no one indexes plugs any more?
Old Jan 15, 2008 | 07:47 AM
dennis50nj's Avatar
dennis50nj
i do but its hard with no crush ring. in the old days on my 429 it would take 3 sets of plugs screwing in and taking out trying in a different cylinder until they were all just perfect
To Spark Plugs
Old Jan 15, 2008 | 10:29 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
i actually prefer the 'accel u-groove shorty' plugs with the electrode trimmed back, but i haven't gotten around to getting them yet.
currently i'm running a set of ngk's with a wider gap.
Old Jan 15, 2008 | 04:16 PM
Tommy D's Avatar
Tommy D
There is a kit from one of the suppliers (jegs or summit) that sells adjustment washers........ you still have to take them in & out several times to get them just right ..... well at least my son Joey does
Old Jan 15, 2008 | 04:18 PM
Tommy D's Avatar
Tommy D
Ah yes I rmember back in the day cutting back the electrode to get that very last bit of HP....... making the run and installing another set
