Problem shifting into 1st gear
Old Jan 16, 2008 | 06:45 PM
nastyc6vette's Avatar
nastyc6vette
Default Problem shifting into 1st gear
Does anyone have problems shifting into first gear from neutral. It happens maybe 30% of the time at the stop light.
Anything I can do to prevent this?
Old Jan 16, 2008 | 06:56 PM
carnut2912's Avatar
carnut2912
Default Yep
My 05 is like that. From what everyone tells me it's normal. The 08's are said to be better. Here's what I do, when I'm rolling to a stop, I shift it into first. Always goes right in then.
That's my only complaint about this car is the clunky transmission.
Old Jan 16, 2008 | 07:02 PM
07CSicks's Avatar
07CSicks
There is something you could do... Had that issue with my 06 GTO and it drove me crazy and I got rear-ended once because of it...
Option 1:
Get the skip shift eliminator... That fixes it most of the time... $20 dollar part = no more shift problems
Or get an automatic... But I think you'll like option 1 more
Old Jan 16, 2008 | 07:11 PM
calemasters's Avatar
calemasters
Downshift into 1st at the stop and leave the clutch in.
Old Jan 16, 2008 | 08:09 PM
nastyc6vette
Thanks everyone, I'll order the skip shift eliminator. I was getting tired of stepping on the clutch at the stop light.
I can imagine lots of fender benders at the stop light with C6's.
Old Jan 16, 2008 | 09:17 PM
calemasters
The GAGS has nothing to do with the root cause of the 1st gear engagement concern at the stops.
Old Jan 16, 2008 | 10:17 PM
debo's Avatar
debo
I was thinking the same thing. I thought the GAGS deals with eliminating the 1st to 4th gear shift.
Old Jan 16, 2008 | 10:56 PM
Hoonose's Avatar
Hoonose
There is a fix if it happens often enough, I think more than 10-15% of the time. Synchros not lining up. Very common with any manual tranny. My '05 does it occasionally and I just ignore it, or shift to first before I stop, or double clutch it. Even my Miata had this going into reverse. My C6 has trouble going into reverse too occasionally.
Old Jan 16, 2008 | 11:33 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
It happens to me occasionally. I normally try to hit 1st before coming to a stop. If I forget I pull it into 2nd then up into 1st. Works for me.
Old Jan 17, 2008 | 12:44 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Most cars won't shift into 1st when moving, not when stopped. Not sure what is up with yours. If it was my car though, I would drain the ransmission and refill it with a good gear oil such as Redline, Royal Purple, or Amsoil.
Redline Synchromesh did wonders for my 1999 Subaru tranny. It would absolutely not go into 1st unless the car was going under 5 miles an hour. That pretty much fixed the issue. The synchros need some friction modifiers to work properly and as heat breaks those down the transmission won't shft as well.
Old Jan 17, 2008 | 10:59 PM
Rich Farr's Avatar
Rich Farr
Default shifting to first
I had same problem with my 2005 convertible. Dealer did $3,000 work under warranty. Problem was significantly reduced. Dealer made further improvement with anti-venom method. You will find this method posted on the forum. Basically involves placing a copper washer at connection to transmission to reduce tension. I plan to replace transmission fluid with mobil synthetic in spring as this is said to further improve shifting.
Regards,
Rich
Old Jan 17, 2008 | 11:21 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
You hit it! This is an old trick. Shift into 2nd and then push it up into 1st.
Old Jan 18, 2008 | 11:58 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Option 1:
The skip-shift feature or getting a GAGS eliminator has nothing to do with this.
I downshift into 1st by the time I stop for a light. My 2005 MN6 is actually does quite well going from nuetral into first gear. It's balked on occasion but not enough to consider a problem. If you have trouble going from nuetral into 1st gear, try bumping it into 2nd gear and then going up into 1st.
You might also try using Royal Purple Synchromesh tranny fluid. I changed to RP but not because of any problem I was having. Many RP users report that RP helps with smoother shifts. Frankly, if it's doing it 30% of the time I'd have your transmission checked.
Old Jan 18, 2008 | 12:49 PM
SpinMonster's Avatar
SpinMonster
I had my transmission upgraded to a level 4 from Cartek. They put in carbon fiber synchros and it fixed that problem nearly completely. I see it 1% of the time. Thats right in 5 months its happened 3 times. Reverse is the curprit for me if I am not on flat ground.
CAGS has nothing to do with the problem. The skip shift eliminator is a resistor and doesnt do anything to first gear.
Old Feb 18, 2008 | 09:16 PM
dixie's Avatar
dixie
There's a technical service bulletin out to address this problem. It deals with an incorrectly cut first gear synchro that should be replaced under warranty if manifested more than a certain number of times per shift. I'm taking mine to the dealer next week to try and get this fixed. It pisses me off that a car this expensive has such stupid and weak problems. If this is chevy's flagship how bad is their other **** that people buy?
Old Feb 18, 2008 | 10:44 PM
yanniz's Avatar
yanniz
not sure how you guys tolerate that....
Old Feb 19, 2008 | 02:51 AM
Apostle's Avatar
Apostle
To Problem shifting into 1st gear
Old Feb 19, 2008 | 03:16 AM
MARSC6's Avatar
MARSC6
This always works for me. Reverse can be a real pain.
Old Feb 19, 2008 | 04:19 AM
joliett's Avatar
joliett
Any transmission is tight into first gear or reverse gear because of the synchronizers (invented by Porsche BTW).
Leaving the clutch in at a stop light is not correct, and besides being bad for the clutch, it is also a bit unsafe.
When you're ready to go into 1st, press the clutch and put the shift into any higher gear than then push it up into 1st - release clutch.
Same when you go into REVERSE, clutch in, put the shift into a higher gear than into REVERSE - release clutch.
Without even driving a Vette (yet), this is the standard procedure for driving any manual tranny. I know this will result in silky smooth engagement into your problem gears - and it is the way to properly drive a stick.
This all helps align the syncros.
Old Feb 19, 2008 | 04:45 AM
gpmvette's Avatar
gpmvette
synchro 2nd gear replaced at 623 miles.car is still in shop parts backed ordered.
