centrigugal or roots style blower?
The centrifugal are smaller and fit on the front of the engine like a large alternator. They are still very effective.
Shop around some and talk to several manufacturers and installers, then make your decision.
If it wasn't for the hood I probably would have heald out for the Maggie.
On the street for everyday driving where the overwhelming majority of your driving will be below 4000 RPM, the Maggie will be much more satisfying to drive because of the better low RPM power/boost.
Have you seen the difference in boost curves for the two different superchargers and do you know why each is shaped the way they are? That tells the whole story and should make it easy to decide which one you want depending on what you want from the car. The pros/cons list above is a good guide to go by.
Either way, it's great to be blown.
6-speed, and i want to put a supercharger on it. i am looking at the magnuson and the procharger. i want to get around 500rwhp and still be perfectly driveable on the street, but quietness is not important, the louder the better lol
The base 2005-2007 Callaway Corvette made 560 hp (SAE) at the flywheel from bolting-on the MagnaCharger and Callaway exhaust system. The Callaway Corvettes with the "616 HP Performance Package" option raised the ante, generating 503-505 hp (SAE) at the wheels. This option includes a high-lift, relatively short duration cam, CNC-ported LS2 cylinder heads, a Honker cold air intake, and other valvetrain parts. All of these cars have stock exhaust manifolds and catalytic converters (and the '07's have a 100,000 mile warranty). Both are extremely streetable, ask people that have driven them.
These high helix angle Roots-style systems make tremendous torque at low and mid-range RPM, and they keep pulling strong all the way to the red line. C6's prepared with the 616-type of engine, i.e., mild cam, ported heads, aftermarket intake and exhaust are consistently high-10 second cars. And they still get high 20's mpg on the highway.
You don't have to buy a Callaway Corvette, though, to get Callaway Corvette performance. Callaway engineers developed the 616 option specifically for our cars and the specs are proprietary, but we distribute MagnaCharger kits to talented tuners and installers worldwide that can build reliable, durable, powerful engines with their own preferred component combinations. Callaway supplies the PCM calibration, so there's no trouble codes, detonation, or unexpected glitches.
For dyno shootouts or drag-racing-only applications, where the peak power value is the only concern, where the engine is operated in a very narrow RPM band, where you're building an engine specifically for a high RPM, supercharged application, and where idle quality and long-term durability are not a primary consideration, centrifugal supercharging could, in fact, be a better solution than Roots. We thought that most Corvette enthusiasts want a more street-oriented experience.
