Meth 50/50 mix question
Old Feb 3, 2008 | 12:55 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Default Meth 50/50 mix question
How different is it {same,or more difficult}for a Tuner to "tune" a FI Vette with an Alky kit that uses a 50/50 mix compared to straight Meth?
Is it harder for Them?
Thanks,George
Old Feb 3, 2008 | 01:30 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Thanks,George
No.
Old Feb 3, 2008 | 11:30 AM
1bdasvt's Avatar
1bdasvt
Thanks as always Charlie!!
Do You have any preferences{or opinons}on using 50/50 or straight Meth?
Old Feb 3, 2008 | 11:43 AM
vr6aaron's Avatar
vr6aaron
I hear u can use tweed, its sold at Walmart and Autozone.
Old Feb 3, 2008 | 12:10 PM
0C_Williams@RPM
Former Vendor
George,
I mix methanol and plain, distilled water.
Old Feb 3, 2008 | 12:26 PM
1bdasvt's Avatar
1bdasvt
Originally Posted by C_Williams@RPM
George,
No Guys,...My question is which do You prefer,,,, "50/50" or "straight" meth?
Thanks!
Old Feb 3, 2008 | 12:40 PM
0C_Williams@RPM
Former Vendor
Thanks!
It's better mixed.
Old Feb 3, 2008 | 12:53 PM
1bdasvt's Avatar
1bdasvt
It's better mixed.
Why is that Charlie?
Thanks!!
ps,,,It seems like Your the only Tuner that takes time enough to answer questions!
Old Feb 3, 2008 | 01:19 PM
vertC6's Avatar
vertC6
I have been researching this for about 2 years now and most tuners on the forum will say 100%. I personally fall in the middle I plan to run more like 80/20 to add some water to the mix for added safety and if I need to use my washer in a jam.
Bottom line is lots of guys are runing 100% with no problems and several 50/50 with no problems. You lose about 15-20hp by going 50/50 but it cools better than straight meth for added safety.
Old Feb 3, 2008 | 01:48 PM
1bdasvt's Avatar
1bdasvt
BJ,..I talked to several tuners and other performance shops,and most have all said that a 50/50 mix produces "more" power if it's tuned "correctley"!
It takes a little more time to tune a 50/50 mix,but the results are more power!
Old Feb 3, 2008 | 04:05 PM
vertC6's Avatar
vertC6
Really?? What do they say is making more power by doing a 50/50 mix? Is it because the charge is cooler because obviously the meth is going to burn where the water is not. Maybe you can run more timing?
Old Feb 3, 2008 | 06:15 PM
1bdasvt's Avatar
1bdasvt
I'm not too sure,but I believe it's because the water "does" cool the charge that much more!
The Meth really just "boost's" the octane.
Any others info would be helpfull!
Old Feb 3, 2008 | 09:09 PM
0C_Williams@RPM
Former Vendor
Yes, the charge is cooled much better by the water than the methanol. The water turns to steam and carries away heat, the intake charge is denser, and of course the o in H2o is present. An oxygen bearing fuel, if you will.
Methanol is great on octane ~130 so it lends itself to dilution/mixture without severe degradation or lessening of it's anti-knock abilities.
Old Feb 3, 2008 | 11:37 PM
1bdasvt's Avatar
1bdasvt
Great explaination Charlie,thanks a million!!
Seems like You have had alot experiance with 50/50 mix tunes!
I might take You up on a tune when I get My Snow kit!
Old Feb 4, 2008 | 12:27 AM
bosco 08's Avatar
bosco 08
just use blue windshield washer fluid and be done with it. the water does the actual cooling as stated earlier the meth is mainly to keep the water from freezing plus it gives a boost in octane and cleans the combustion chamber.
http://www.snowperformance.net/
Old Feb 4, 2008 | 12:42 AM
1bdasvt's Avatar
1bdasvt
I'll just use Snow's own "Boost juice"!!
Old Feb 4, 2008 | 12:59 AM
bosco 08's Avatar
bosco 08
that will work too
To Meth 50/50 mix question
Old Feb 4, 2008 | 10:43 AM
vertC6's Avatar
vertC6
Hey Charlie,
I know with each application you have different results; boost, engine type, FI type, but what are your typical results using 50/50 mix reguarding hp and tq? Have you done any testing to the intake temps while using 50/50? Thanks for your help.
BJ
Old Feb 4, 2008 | 11:14 PM
1bdasvt's Avatar
1bdasvt
Good question BJ!!
Old Feb 5, 2008 | 02:04 AM
0C_Williams@RPM
Former Vendor
You are welcome..... and anytime on the tune
