ls7 blocks
From reading this forum, it seems that the ls7 crate engine is not the ideal platform to modify if you want over 600rwhp due to initial cost & strength of the block.
The Vehicle is not a corvette, its a 4x4 and this forum seems to be the best source for information on the ls7.
My requirements for the engine is to have the best combination/ compromise of the following :-
No less than 600rwhp, low down torque, reliable under sustained heavy loads, good fuel consumption to be kept in mind ( ive read the standard engine gets 28mpg in the corvette ) the engine will get submerged in water completely time to time ( this could crack a turbo ? ) run on pump gas & be hospitable enough to drive over the continent of europe.
The specification I have come up that is not standard ls7 is :-
Alloy block - Dart billet or ls7x,
Darton liners
Procharger running at 5-7 psi with intercooler ( not as hot as turbo and may take to being covered in submerged in water better ? )
standard ls7 heads, all pro or ls7x ? titanium valves
Forged rotating assembly- lunati internals crank, rods, JE coated pistons with 9:1 CR ?
Modified cams of some type
Standard dry sump system ?
Water/ meth injection.
1 7/8 jba headers, kooks ? straight for max torque ?
intake manifold- some kind of cast aluminium plenum for FI
bank?
Ron Davis Aluminium Radiator
Other parts I would leave to the engine builders preference.
Any advice very much welcome.
TIA
A truck, want low end torque, mileage, going to be submerged in water... I'd be thinking diesel. A slighty modified Duramax.
With all the electronics/ignition on a gas engine, they don't do well under water.
I don't know if I would bother with the whole dry sump system either as it was designed to keep oil in the motor under hard G's. For a 4x4 how many G's can you expect.
If you are building this thing from scratch I would stick with the GEN3 parts in the lower end and use the LS7 stuff up top. If you use LS7 heads you will either have to use a stock LS7 intake or spend $3800 for a custom one from someone like Wilson.
What PCM is going to drive it? If it's an E38 you will need a crankshaft with a 58x reluctor wheel. If not its a 24x.
You may also want to consider a iron block if you are going to pound the hell out of it!
Howard
A diesel was my first choice, but they were too heavy and large in size.
lightness is the main factor here, hence the high power low weigt ls engine. I will place the electronics as much in the roof as possible.
I thought the dry sump would be good as the vehicle can be several minutes at severe angles, so not for the g force rather just getting a steady supply of oil.
Dont know about the PCM, havnt got into much detail yet.
thanks
