Spin - wishing you a fast recovery. If there is going to be some down time where you are stuck in bed tell me where I can send some magazines, etc and I will get so stuff out to you to pass the time away.
I was stuck in bed for a while after a bad accident and I know having things to occupy your time is key....
"disrupting higher brain function" You sure it wasn't the opposite effect where Spin had access to more brain function and focused it all on tuning and LS engine power combos. I have many of his rants bookmarked because it is often too much to take in at once!
Best of luck and you are in my prayers for a speedy recovery! Tell the Doc if he goes drinking the night before surgery you have a some large friends on CF that very strongly discourage it!!
Best of luck Spin, maybe you will be able to rip gears, AND play the piano when you are all fixed up.. Hang tight and recover quickly.
My ten thumbs wouldnt allow that.
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Originally Posted by Evilways
Hey Spin...have them put the C6 logo on the plate, man!
Again...speedy recovery and
Better yet get some nitrous jets installed. Then when you get angry because someone says gears are bad for traction you can purge the nitrous out your ears and it will be just like in the cartoons.
Best of luck Guy.
I thing we'll need to purge him if I am ever going to start, I should've had 3.90's thread
