Torque Specs
Old Feb 15, 2008 | 08:14 AM
alavette's Avatar
alavette
Default Torque Specs
Are the rear axel nut torque specs the same for a Z-06 vs. C-6 and what is that number. Also same question for the lug nuts Z-06 vs. C-6 and again what is that number.
Old Feb 15, 2008 | 11:34 AM
Miaugi's Avatar
Miaugi
I'm going by memory....as I recall it is 160 ft.lbs. for the diff/axle nut and 100 ft. lbs. for the lug nuts.
Old Feb 16, 2008 | 05:30 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Concerning the axle nut for the C6, I believe this is the latest.......
If there is presence of the nut "indexing and/or looseness", do the following:
1. Remove existing nut
2. Apply Goodwrench # 12345493 (also known as Loctite 272) on threads in area where nut finally seats
3. Install new nut (p/n 10257766)
4. Torque nut to 190Nm (140 ft-lb), static
5. Allow 24 hours cure time.
Note that a NEW nut is required and the torque has been increased from 118 ft-lb to 140 ft-lb.
Old Feb 18, 2008 | 09:53 AM
alavette's Avatar
alavette
Thanks Wayne great data!!
To Torque Specs
