Octane question.
Octane rating is just another word for how fast the fuel burns. The higher the octane the slower the burn. If the car is designed to run on 87 octane fuel running a higher octane could cause an incomplete fuel burn.
It is always best to run the octane rating that manufacture recommends unless you are running an aftermarket tune.
I believe if you use a lower octane rating it will reduce your h.p.,,not your m.p.g.,,someone can correct me if I'm wrong,, I was more concerned about the use of different octane ratings that I use and not the fact she gets crappy milage.
In regards to the computer. There were a few theories way back when about computers learning the octane but those have all just about been debunked. The computer will react to whatever octane it's burning. You put in 87 and you will lose power and the engine may run like crap. You put in 93 and you will run on full power and have a strong engine. Mixing 87, 89, 91, and 93 averages out to 91.5 given equal parts of each(which will be hard to do since you constantly switch). Why not just run 91 then anyway? 93 preferred since it's available. I really don't understand your motivation.
Detergent levels are also interesting, and really do prevent carbon from accumulating. See these or do a search to learn more.
http://forums.corvetteforum.com/show...ghlight=octane
http://www.toptiergas.com/
Conversely if the recommended octane is 91 octane running anything less is leaving power on the table.
Not possible (unless Torco were part of the mix).It's just simple averaging:
9 x 87 = 783
9 x 93 = 837
783 + 837 = 1620
1620 ÷ 18(gal.) = 90 octane
Running a higher octane than the engine requires will reduce gas mileage and produce no beneficial effect. Since the car is designed to run on 93, there is no point to this exercise.
9 x 87 = 783
9 x 93 = 837
783 + 837 = 1620
http://en.wikipedia.org/wiki/Octane_rating
Thanks!
Thanks!
The slower burn rate would explain why when using higher octane gas in a non-computer controlled engine requires the ignition timing to be advanced to allow a more complete burn of the fuel.
http://forums.corvetteforum.com/show...9&postcount=31
http://forums.corvetteforum.com/show...7&postcount=32
