~ B E S T Air Intake ~
Old Feb 26, 2008 | 12:46 PM
bob53's Avatar
bob53
You guys are spending 50K on a car and you care about the price of the intake?
I agree, in design the Vararam could be the best at injesting cold air. however, I have not seen any data to prove that Vararam is faster than another intake in a controlled setting. ET time on different days are useless. Show me data from an accelerometer that the vararam is better than say a Honker... I call
For me, I'll be getting the Honker as it is designed by Callaway - a known quantity. There have been zero complaints against the design, fit and finish, and operation of the Honker. In contrast, there have been complaints time and time again against the fit and finish, installation, and most importantly operation of the Vararam. In some rare cases, the filter in the Vararam fit so poorly that large particles were getting past the filter and into the motor.
Let's see, save 100-150 bucks on an intake or spend a bit more for piece of mind on a 50K+ dollar car. That's a no brainer.
Old Feb 26, 2008 | 01:49 PM
SnowyATX's Avatar
SnowyATX
Here is some statistical info:
http://forums.corvetteforum.com/show....php?t=1897629
Old Feb 26, 2008 | 02:15 PM
bunk22's Avatar
bunk22
Another vote for the VR. Had the Halltech with cold air option. Added ET and mph with the VR, consistently.
Old Feb 26, 2008 | 02:46 PM
LS1LT1's Avatar
LS1LT1
Umm, well, yeah. That's how I'm able to afford to pay cash for a car like this because I ALWAYS care about saving money when I can.
Regardless of my desire to save money, cost/price was NOT the motivating factor for me choosing the Vararam over all others, it's performance results (which are just as proven as any other CAIs out there, if not more so) are the reason and the quality and fit on mine are EXCELLENT.
Old Feb 26, 2008 | 03:07 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by FloydSummerOf68
Comparing MPH takes out a lot of the variable.
You're right. I'd trapped over 2.46mph faster versus stock after the Vararam install in worse air but at the same track. Yes I'd had some programming done as well but TM removal only contributes so much to max trap speed.
I did have the opened shroud mod with opened up air boxes and high flow filters (a set up very similar to a 'K&N with opened shroud' mod) just prior to adding the Vararam as well and did see a slight improvement (.93mph) over stock but that was also in slightly better air over my Vararam testing.
The Vararam still beat that set up by 1.53mph, a HUGE difference when you're using trap speed as a power indicator and looking to take out a lot of the variable.
I won't even get into the almost 2/10ths improvement in ET that I achieved with the Vararam.
Anyway, my point is that the K&N with the open shroud is a very viable contender with the vararam...and many write it off due to the hype surrounding the vararam (I'm not saying that it does or doesn't live up to the hype). It can be had cheaper, is a much easier install, and does perform....so it should be kept as an option for people, and I let them know it
That's a valid point, much like in that 'Z06 manifold versus long tubes' thread...yes one set up yields lower gains over another but it also costs less, can't argue with the concept of saving some money even if it means obtaining slightly worse results.
Old Feb 26, 2008 | 03:14 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Well I can basically say the same thing.
With the k&n and tune I picked up .43 in et (12.74 to 12.31) and 3.8mph (113.0 to 116.8) in nearly identical DA. (prior day was in the mid 70s and this day was high 60s...both days 65% humidity and both days near mid 30.xx pressure) Shroud was open for runs prior and shroud was open for runs with the tune and K&N.
The next time I'm at the track I will take the tune off and run the stock tune and see what I run with JUST the K&N intake vs what I ran before. Hopefully that can be this weekend if it doesnt rain.
Old Feb 26, 2008 | 05:03 PM
Silver05GTO's Avatar
Silver05GTO
I'm not going to add a vararam for several reasons.
I can compare it like that to a point...if vararam was some incredible piece then I would see incredible track times produced by these cars while I'm at the track...and I dont see it happening. They MPH very close to me and ET very close to me...telling me that the systems (atleast to some degree) are producing similar results.
I did back to back track runs with my former setup/tune which was K&N filter/Cartek tune. I trapped a best of 112 whith a closed shroud, with the shroud open 111mph, so based on my testing I gained NOTHING from the propped shroud.....Cartek blammed my crummy MPH on heatsoak/IAT at the start of my run. DA was in the 600's. Headers were on the car as well.
I've since gone to the Vararam/CoW tune and plan on hitting the track this spring.....the Vararam will take care of any IAT issue I had on my previous trip...something that the K&N cannot control as well even with a open shroud.
Old Feb 26, 2008 | 05:09 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I went to Cartek, had the same mods as you put on and i have the Vararam and in the 1/8 mile alone i gained .6 and 6mph from stock.
I went from a 8.883@83.06mph to a 8.215@89.56mph with Cartek`s tune, Kooks,and a Vararam. Cartek know`s their stuff!
The way i look at it is: .2 Kooks .2 Vararam .2 Cartek tuning
Old Feb 26, 2008 | 05:17 PM
Silver05GTO
Cartek did tell me while I was there the K&N intake would hold the car back, it dyno's ok but isn't nearly as effective with the hood closed as a Vararam or Honker intake getting fresh cold air.
A propped shroud doesn't get you much gains just by design...your getting air blowing around the engine bay, it's not being directed into the filter area as with an enclosed system like the Vararam.....
There was a thread with hp tuners results showing just how much lower the IAT's were with a Vararam compared with stock and K&N system w/shroud mod.
Bottom line was the Vararam was better.
Old Feb 26, 2008 | 05:22 PM
goatts's Avatar
goatts
I have Vararam
Old Feb 26, 2008 | 05:24 PM
11secondGP's Avatar
11secondGP
My IATs are ambient at all times, not just at the track. I dyno'd 402whp with the hood closed, trapped 121mph, and ran 11.8 four times with ~2.0 60's. I really doubt the k&n CAI is holding me back.
But you wont hear me say anything bad about the vararam.
Old Feb 26, 2008 | 05:37 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Know one is saying anything bad about k&n, its just that most of us know what works and thats the Vararam.
If you want to improve your times, you should really try it and see. It would be one of the best investments you can make for the track.
Old Feb 26, 2008 | 08:31 PM
  #33
LS1LT1's Avatar
LS1LT1
This is very true, hence why there's a Vararam on my car now instead of the mere propped shroud that I'd had before it.
Old Feb 26, 2008 | 08:39 PM
  #34
11secondGP's Avatar
11secondGP
Exactly why I have that area sealed off with a piece of reflectix. Otherwise the temps are not ambient at idle or light throttle.
Old Feb 26, 2008 | 10:36 PM
  #35
siffert's Avatar
siffert
I'm not as impressed with the vararam as everyone else is.
I've raced atleast 3 C6 vettes at the track with vararam, tune, and mufflers and I've out ET'd and out MPH'd everyone in my 07 auto with k&n, tune, and mufflers (and obviously opened shroud...because there is no reason not to).
So until a vararam car handily beats me I'll not be a believer.
The K&N looks 100% better as well and takes 5 minutes to install
I know I picked up about .10-.15 and 2 mph with the propped shroud and stock filter. Personally, I dont think there is much difference in ET whether adding a Vararam, Honker, Vortex or my Xcelerator (Honker clone) ...all about saving .2 in ET. The one advantage to a true closed system CAI is you are lowering your IAT much more than an open system.
Have not tried my Xcelerator on the strip yet, but I doubt its going to be that much quicker than my propped shroud. Though am no longer worried about losing timing due to high IAT's.
Finally, I dont hold much worth to the "ram effect" to any of these CAI's. One thing that I and others found out about the "ram air effect" of the cold air intakes is there is very little of it, if any. Otherwise, one would find evidence of the manifold absolute pressure rising at speed. My own data logging runs from 60-115 mph showed its staying the same with propped shroud and Xcelerator. Some other guys with Z06's with Vararam's found the same thing.
