Will 305/30/19....
Old Mar 2, 2008 | 09:36 PM
Mike V.'s Avatar
Mike V.
Originally Posted by scottycards
Ding, ding. We have a winner. Great observation. To go to a 30 aspect ratio, IMO the tread needs to be a bit wider to look right.
My concern too on going this route, vs KDW2s 295/35-19 which is 27 tall vs 26.3 on the PS2. It's not the width that makes it look funny it's the size of the sidewall, 30 is 30% of the width of 305mm, 30% of a 325mm tire translates to more sidewall. The only thought I've had to lower the rear further than I already have, because realistically the stock tires are 26.9 -26.3 is about a 1/2" resulting in a 1/4" deficit in the fender well space to the tire, thus by lowering there rear 1/4" effectively would eliminate the visual effect.
Check out the math:
285/35-19, 285 x .35 = 99.75mm sidewall (GYSCRF)
295/35-19, 295 x .35 = 103.25mm " (KDW2)
305/30-19, 305 x 30 = 91.5mm " (PS2)
325/30-19, 325 x 30 = 97.5mm " (GYSCRF)
IMO the more tire filling the fenderwell the better the look, unless you lower the car dramatically to fill the gap which looks good too, but comes w/ some tough sacrefices. Check out a 19/20 combo w/ low profile tires w/ the car slammed & it looks really good, but it then dwarfs the rotors along with tougher ride.
Old Mar 2, 2008 | 11:47 PM
C6 2 Envy's Avatar
C6 2 Envy
hmm im now having second thoughts...does anybody have pics of the 295/35/19 KDW2s on there vette if so post up!!!
Old Mar 3, 2008 | 01:34 AM
crabman's Avatar
crabman
Got the 305s. IMO most folks are likely to get an urge to lower after mounting them to rid the car of the 4x look. Once lowered the wheelwells have a very nice "stuffed" look to them.
Old Mar 3, 2008 | 02:55 AM
THECRAIGMEISTER's Avatar
THECRAIGMEISTER
I went with the Nitto Invo's in 305/30/19 and the 255/35/18 in the front. The overall height compared to stock is really close. Won't affect ABS or anything and the speedo is 1.5mph at 80 I believe. The ride quality is much better than the runflats. I can't really report on the traction as it is so cold here in Wyoming and the tires were put on in November. But soon I will be able to test it out. The tires have rave reviews and are priced right so do yourself a favor and check them out!!
Old Mar 3, 2008 | 10:11 AM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
Check out the math:
I agree, Mike. My speedo is dead on still, the look is like another car we've seen around (the Z06) runs that size tire, so it retains the original look, which is part of what I was after.
I also thought about lowering the rear if I went with the 305, but then the stance of the car might be different, and my headlights would shine higher if the rear was lowered disproportionately (no big deal to adjust, but it did cross my mind).
I did not want a 19/20 combo, because the roads here in CO can be rough, and have RR tracks and potholes. Not enough sidewall for me.
I probably way overanalyzed the whole thing, as I tend to do, but in the end, I'm glad I did it how I did.
As more tires become available in a 325/30/19, I'll have more choices if I decide to try something other than the SCRF.
When you get your swap done, post up photos, I'd like to see them.
Old Mar 3, 2008 | 08:12 PM
rocket1's Avatar
rocket1
Default dumb question
Can you increase tire size on stock rim sizes (06 Z51)?
Old Mar 3, 2008 | 08:28 PM
Mike V.'s Avatar
Mike V.
Do a search, I've seen several posts w/ pics. They look very good & to be honest, after all this analysis, my head hurts, & I think I'm going to just get the KDW2s & be done w/ it!
Old Mar 4, 2008 | 02:23 PM
Dgatto's Avatar
Dgatto
Its time for some new threads for the c6 vette and i wanted to go a little wider in the back. Will a 305/30/19 fit in the back on a stock rim without fitment issues? If anybody has this size post up some pics so i can see how good they look :thumb: Thanks
wont fit
Old Mar 4, 2008 | 09:46 PM
Mike V.'s Avatar
Mike V.
Originally Posted by Dgatto
wont fit
Not true, it's been done & well documented
Old Mar 5, 2008 | 11:48 AM
vettl83's Avatar
vettl83
man your car looks sweet...the goals for the car is more staight line than anything..im making good power so ill probably be going with the 305/35/19 PS2..for the fronts is 275/40/18 borderline or would i be safer with say a 255/40/18? Thanks for all the help guys
I don't believe you are going to find any 305X35X19 tires, however there are 305X30X19 available. On stock rims I believe 255X40X18 is the max width you can go safely on the front. The Tire Rack would be a great source of technical info on this subject give em a call 1-888-541-1777.
Old Mar 5, 2008 | 01:51 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
If you lower the rear and don't lower the front proportionately your car will become unstable at high speeds. A lot of the Corvette's high speed stability comes from the rear being higher than the front, producing downforce.
Old Mar 5, 2008 | 04:38 PM
NEV3R L8's Avatar
NEV3R L8
Why not go to a 325 on your stock rim? It doesn't have to stick out at all, and the traction is MUCH improved?
1. Widen wheel an inch.
2. Trim inner fender liner, and file off .020 of your upper A-Arm in one spot.
3. Put 325's out back.
4. ENJOY!
285 vs. 325:
So would you be able to keep the stock size up front (245/40/18) and put the 325s on the back without messing with the computer? Also what size 325? 325/xx-xx
EDIT: I guess the only tire that size is goodyear. What has your experience been? I know it is bigger and should give better traction but those tires suck stock. I'll probably just go with something 305/30-19 because there are more options.
Old Mar 5, 2008 | 08:45 PM
  #33
Vito.A's Avatar
Vito.A
Default Michelin PS2 305/30-19 on the rear and 275/35-18
I put Michelin PS2 305/30-19 on the rear and 275/35-18 on the front. They fit the stock wheels just fine. Both front and rear stock wheels are 1/2" less than the recommended width, but that is just 1/4" on each side and you cannot visually tell the difference.
The larger front and rear tires look like they came on the car. No DIC warnings with this combination.
The first thing you will notice is the car rides much better and really sticks when you are on the throttle.
Old Mar 7, 2008 | 07:46 PM
  #34
rocket1's Avatar
rocket1
How much difference in width from stock?
Pictures?
Old Mar 7, 2008 | 10:33 PM
  #35
SLOW 77's Avatar
SLOW 77
I would like to see some pictures too. Thanks.
