Rear hatch question.
Mar 2, 2008 | 12:26 PM
I have an 08 coupe,,was wondering,,when you close the rear hatch,,should it close automatically when you put it down and it first makes contact with the latching mechanism,,,seems I have to apply a fair amount of pressure to have it close by itself.
Mar 2, 2008 | 12:28 PM
St. Jude Donor '08 thru '13
You have to give it a little push. Normal.
Mar 2, 2008 | 01:00 PM
Mar 3, 2008 | 06:07 AM
St. Jude Donor '08-'09-'10-'11-'12
2008s do not have the auto hatch lock, its been discontinued. Crack a window or door, it'll help if you relieve some of the air pressure.
Mar 3, 2008 | 09:07 AM
Quote:
Originally Posted by
foremaw
I hadn't heard this before, is this correct?
Mar 3, 2008 | 09:21 AM
CF Senior Member
foremaw
2008s do not have the auto hatch lock, its been discontinued . Crack a window or door, it'll help if you relieve some of the air pressure.
Interesting...I have
never heard this mentioned before.
Mar 3, 2008 | 09:59 AM
foremaw
If you have so much trouble closing the hatch that you need to relieve pressure from the car to make it easier then you have a lot bigger problems on your hands
Mar 3, 2008 | 11:24 AM
08's do have the auto hatch lock. Mine does.
JS
Mar 3, 2008 | 11:34 AM
03ZOHSX
08's do have the auto hatch lock. Mine does.JS
Auto-pull down when the hatch is almost closed?
Mar 3, 2008 | 12:39 PM
Could it be that some '08's have it and some don't? A mid-year change perhaps?
Mar 3, 2008 | 12:51 PM
scottycards
Rather than push mine, I pull it down with a little force and let it drop by it's own weight so the latch mech catches and pulls it shut.
Mar 3, 2008 | 12:53 PM
Miaugi
The Z06 and Convertible don't have it, the Coupe does.
Mar 3, 2008 | 01:18 PM
j_digi454
Now that does sound familiar....I think you may have the answer!
Mar 4, 2008 | 07:38 AM
j_digi454
I stand corrected, thanks for setting me straight.
Mar 4, 2008 | 10:07 PM
You do need to apply some force before it will pull it down automatically. Then again, that feature only works about 85% of the time for me and I hear that's a good average.
