TPMS Tool ?
Search is your friend. Expect to pay around $140 (IIRC) if you buy your own. My local tire store charged me 20 bucks.
To get the car into learn mode, depress lock and unlock simultaneously on your fob while the car is in ACC mode.
Then go around: LF, RF, RR, LR, and have each TPMS send it's signal using the little computer tool. Your horn will chirp each time.
Drive away happy!
I don't have any TPMS reset tools right now.
The Bartec Trackside is a great tool. It's very simple, and works great with our simple C6 sensors, which only require a continuous wave transmission from the tool. The Trackside is designed to only work on the C6 (and they have a Viper model and a Mustang model).
As of last September with the 2008 model year, Federal Law requires ALL 4-wheeled vehicles less than 10,000 lbs to have sensors and a TPMS.
With all the different sensors, the manufacturers have built them to require various different coded/pulsed transmissions from the tool to trigger all the different sensors. Even though the Trackside can be purchased for around $140 plus shipping, you might like to spend a little more to work with the sensors on your othe vehicles so when you rotate the tires on your wife's car you can reset the TPMS.
Most of these universal tools go for $325 and up on that popular auction website, but sometimes you can find one for down around $200 or so.
I do have a set of brand new sensors for $30 each.
Bob
When they are sold through GM they are a dark gray color and have the GM Part# (25758220) molded into the case.
The only "aftermarket" sensor that will work with the C6 is the exact same sensor sold by Schrader or other sources that distribute the Schrader sensors directly from them. That sensor looks exactly the same as the GM sensor, but is a red color, and is Schrader Part# 20076.
So.....there is no "aftermarket" sensor and no way to program the TPMS to work with any other than the Schrader sensor distributed by GM or purchased directly from a Schrader distrubutor.
With the Federal Law that requires sensors and a TPMS in ALL cars starting with 2008 model year an on, I believe Tire Rack and NAPA are starting to stock many of the Schrader sensors. Hopefully they'll be a little cheaper than the OE ones from a dealer.
Our forum vendors Gene Culley, Fichtner, and Bob's House Of Wheels have good prices on new sensors, and I think Bob has some of the red ones direct from Schrader.
Bob
All of the different sensors send out different digitized data streams, and nothing that I know of except those above will work with the C6.
Well.....a handful of very early 2005 C6's had a Schrader sensor that was GM Part# 10354988, but they are obsolete and I don't think there are any in the GM parts line anymore.
Bob
That's not dirt cheap, but it's the cheapest new C6 sensors on the planet.
Bob
http://www.bartecusa.com/products.html
The Trackside is the first tool shown on the website above.
The 2nd tool, the Tech 300, is a MUCH better tool. The Tech 300 is a completely universal tool that will work ALL sensors that require a radio frequency transmission to trigger them, and it's upgradeable for free as new sensors come out with new triggering protocols. It can usually be found on that popular online auction website for around $350. Keep on the lookout and you'll see them (or other universal tools such as the TIPS/KTi) for down around $200 to $250 from time to time.
By Federal Law, starting with the 2008 model year, ALL 4-wheeled vehicles under 10,000 lbs must have sensors and a TPMS. So....even though it costs more, you might like to get a universal tool if you can find one for low $200's.
BTW, the cheapest price I know of for the Trackside is about $150 ($140 + shipping).
Bob
So on my 08 Corvette I have to buy a tool!!!
It seems like the magnet method is just getting the sensor to send a signal, so now I'm wondering if just lowering the tire pressure will do the same?
Anyone tried it? No need for me to do it yet.
The C5 sensors are triggered by a magnet, and the sensors on other vehicles can be triggered by the air pressure change method you mention, but not the C6 sensors.
The only thing I know of that will trigger the C6 sensors is the transmission from the tool. Well....if you have a VERY early '05 you might be able to use a magnet. A handful of the early '05's built before about August '04 had a sensor that, like the C5, was triggered by a magnet. I've had several dealers do a GM parts distribution search for me and they say there are none left in the system. If you put the part# in a parts search website it comes up with "obsolete part#, superceded by part# 25758220", which is the current sensor that requires the 125 kHz signal to trigger it.
So......you need the tool.
Bob
