Tunnel plate installed!
Old Mar 23, 2008 | 09:43 PM
Larry R's Avatar
Larry R
Default Tunnel plate installed!
First, let me thank all those who answered on my post about installing the LAPD tunnel plate. I did what was suggested, unhooking the front exhaust connection and disconnecting the bolts on the rear hanger and let the pipes down. It was then quite easy to slip the new plate in and reinstall. I added the 1/4 plate along with the OEM plate. I do have one question, I noticed that one poster stated that he re-torqued the bolts that hold the plate in as they apparently came loose. Could the plate hold down bolts be installed with Loctite to prevent this?
Old Mar 24, 2008 | 12:15 AM
wjcook1's Avatar
wjcook1
SURE WHY NOT? Thats the way I installed my plate. I used LOCTITE RED Permanent 271. I don't plan on ever taking the plate down ever. I also believe inNEVER-SEIZE on bolts that I don't want to stick...
Old Mar 24, 2008 | 07:58 AM
Bandit1's Avatar
Bandit1
Good job Larry! You're going to love the results.
Old Mar 24, 2008 | 09:01 PM
CMY SIX's Avatar
CMY SIX
He's got the sickness! now I wonder what's next?
Old Mar 24, 2008 | 09:23 PM
VET4LES's Avatar
VET4LES
Old Mar 24, 2008 | 10:58 PM
jrpedraza's Avatar
jrpedraza
Post back with your impressions on the heat reduction; I just ordered a 3/8 plate from them, I should have it installed in a couple weeks along with the headers.
JR
Old Mar 25, 2008 | 04:21 PM
Carnac's Avatar
Carnac
Default Locktite on the tunnel plate...
I installed an Elite Engineering tunnel plate about six months ago.
I found the the bolts needed re-torqueing a couple of times after the install.
The question about using Locktite has come up a couple of times. There is a reason that I did NOT us Locktite - I think the plate needs re-torquing due to the plate settling into the base of the Corvette, not that the bolts are vibrating loose.
If you use Locktite it will be difficult to snug the bolts back to the required torque. You cannot check the torque of a bolt with Locktite on it.
The first time that I checked the torque (after about 1 week of driving) every bolt took about 1/4 to 1/2 of a turn to get back to the 89 inch pounds.
The next time I checked, after about a month of driving and a track day they all needed less the 1/4 of a turn.
The last time that I checked, (after about four months of driving) none of them needed any tightening. If I had used Loctite at first, I feel the tunnel plate would not have been correctly torqued after a couple of weeks driving and the plate settling into the Corvette.
I DO NOT THINK THE TUNNEL PLATE BOLTS ARE VIBRATING LOOSE - THE PLATE IS SETTLING IN AND LOCKTITE WILL NOT HELP AND MAY CAUSE PROBLEMS.
Cheers - Jim
Old Mar 25, 2008 | 05:51 PM
1BDRSK's Avatar
1BDRSK
Originally Posted by VET4LES
Old Mar 25, 2008 | 07:07 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Cheers - Jim
Old Mar 25, 2008 | 07:25 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
good job, ,blue locktite is the answer,it will allow you to re-torque with no problemo,
Old Mar 26, 2008 | 07:56 AM
Larry R's Avatar
Larry R
That's what I used.
Old Mar 26, 2008 | 08:14 AM
davekp78's Avatar
davekp78
True, but if the bolts move, the loctite is ineffective in the future.
To Tunnel plate installed!
