Comparative DA correction test from AZ to NJ
For sure I'll be there.
Not sure I'll make it down there tomorrow but I might try, good luck.
Also, if you're still around this weekend and have no plans late on Saturday night, this is happening not too far from you:
http://forums.corvetteforum.com/show....php?t=1984666
it is at midnight on Saturday night just in case you're back early enough. I'm still not totally positive that I'm going on the cheesesteak run yet either but probably.
I made 4 passes. Hooked up good for 1.90 60's for the first 2, but spun
for the first time on the other 2 runs. 1.97 and 1.95.1. 12.10 @ 117.95 DA 29' corr. to 12.10 @ 117.98
2. 12.08 @ 118.25 DA 5' corr. to 12.08 @ 118.26
3. 12.07 @ 119.54 DA -821' corr. to 12.17 @ 118.61
4. 12.09 @ 118.99 DA -1119' corr. to 12.22 @ 117.75
What a missed opportunity on the last two runs at negative DA. I may never get to run in those conditions again. At least not in Phoenix.
Assuming the car had no differences in performance between AZ and NJ, I would have expected it to run about .15 quicker and 3 mph faster if the online calculator is correct on the first 2 runs. I have to discount the last 2 runs due to spinning that I attribute to either the track prep going away or additional power from the neg. DA that I never experienced before. I'm guessing the former, even though I'd like to believe the latter.
I'm going to E-town on the 26th for the CC and try again. Won't have great air, but hope to have fun anyway. See you there.
I was checking the (online) air conditions throughout the evening at Atco last and didn't think the DA was ever as high as 29 feet, it would be quite odd for the DA to swing a whole 1100 feet when the barometer remained between 30.15 and 30.24 the whole time. Though temps did range from around 58 degrees down to 49/48 degrees during track hours so I guess it is possible.
I remember telling people ('glennhl' among them) years ago that simply because one suddenly runs their car in notably better quality air conditions, be it going from 70 degrees to 50 degrees or even from 1100 feet DA to as low as -1100 feet does not mean that they will automatically and without a doubt ET substantially quicker. Sometimes yes, but not always.
While again not totally conclusive, I think the above results kind of confirm at least a little of what some of us have been trying to explain for years now.
12.3 118.4 11.94 121.9 vs 12.08 118.3 (run was real close to real sea level)
ET was .14 off
Too many factors to know for sure but I would rather run 12.0 than 12.3 anyday.
I normally run faster with lower DA's, but NEVER as fast as the correction factors say I should.
Downsides were two guys with broken rears/axles and a C-5 that lost it and met the wall at 300'. Ouch!
My runs were not so good, but they were consistant. 12.21, 12.25, 12.26, and 12.25 red light on first comp. pass. I'm not sure what the DA was, as I was getting a sunburn and temp readings in the high 60's with humidity around 40%. The two close WU stations had high 50's and 70%.
Spent the last week in DC. Headed to SC and then home to AZ. Had a lot of fun and may do the east coast again next year.
Bet you're glad to be home now though.
