Voltage problem on a 06 C6.
Old Apr 10, 2008 | 01:09 PM
HIS4's Avatar
HIS4
Cruising
Default Voltage problem on a 06 C6.
The voltage is dipping below 12V at idle and causing the charge system service indicator to light up. The car has a supercharger installed but I don't know what manufacturer it's from. It also has a Pioneer AVIC-D3 installed in place of the factory radio but the rest of the factory Bose system is still in tact.
The dealer is trying to say that the aftermarket "accessories" on the car are drawing too much current and exceeding the output capabilities of the alternator. I think this is a bunch of bull because the only thing that's in there is the AVIC-D3 which may only draw minimal load over the factory head unit. The dealer tech tried to say that the supercharger also is a load which I also think is bull because the supercharger is a mechanically driven device so it should have no electrical load associated with it. I think it may be a pully issue but I don't know.
Can anybody possibly shed some light on this?
Old Apr 10, 2008 | 01:35 PM
Kent1999's Avatar
Kent1999
There's no way the head unit is drawing that much power, and as long as the S/C isn't dragging the idle speed down below spec, that should have no effect.
The other possibility (other than the obvious problems of a bad alternator or battery) is that underdrive pulleys were put on when the car was modded, causing the alternator to turn too slowly at idle.
Old Apr 10, 2008 | 02:01 PM
HIS4's Avatar
HIS4
Cruising
I was thinking the same thing about the underdrive pulleys. Other than the pulley, how would the S/C drag the idle speed down?
Old Apr 10, 2008 | 03:24 PM
johnodrake's Avatar
johnodrake
Moderator
What is the idle speed?
Old Apr 10, 2008 | 03:27 PM
HIS4's Avatar
HIS4
Cruising
I'll have to find out. What is a good range? Somewhere around 800-1000 RPM is normal for most cars right?
Old Apr 10, 2008 | 03:33 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
The "Service Charging System" warning has affected a number of forum member's cars. Those who have had underdrive pulleys installed, even with the idle raised to compensate, have had this. Also, people without underdrive pulleys have had it too. Alternators and batteries have been changed out with varying success. There may be something else involved, and there is supposed to be a TSB out.
GM
Old Apr 10, 2008 | 03:37 PM
HIS4's Avatar
HIS4
Cruising
GM
Thanks for the info. Is there a TSB already out or is it pending? So it seems like this is not really related to the pulleys or idle speed but it may be something else.
Old Apr 10, 2008 | 03:52 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
Default Back to stock
Sounds like this is common problem with after market superchargers that require pulley changes.
Put the stock pulley and manifold back on and see if that solves the poroblem.
These cars are just too complicated to add something as complex as a supercharger. Even if it's a kit made just for this engine.
It's simply not GM's problem.
LJ
Old Apr 10, 2008 | 04:33 PM
TXSTICK's Avatar
TXSTICK
I do not have a supercharger, but I have had similar problems on my 04 C5 and my 05 C6. Both started doing that before the battery went TANGO UNIFORM. After a new battery everything was stable at just over 14 volts.
Have a load check done on the battery.
Old Apr 14, 2008 | 09:51 PM
dschelat's Avatar
dschelat
I do have the same problem but have a supercharger on my 07 C6. Chevy replaced one alternator which fixed it for a while but the problem came back. Second time around they handed me a TSB (#PIC4402A) which basically says:
Subject: Service Charging System Message P0621 DTC Stored
Model: 2007 Chevrolet Corvette (LS2 and LS7)
Some customers may comment of a Service Charging System, Service Electrical System and/or a Battery Voltage Low message on the DIC accompanied by DTC P0621 in the PCM. This may be a result of a shorted wire on the generator bracket or a cut in the stator winding that is caused from high engine RPM, usually because the engine hit the rev limiter. The internal fan is flexing and when it does flex, it comes in direct contact with the winding. A new generator may do the same thing if the engine is placed against the rev limiter.
So....there answer is don't hit the rev limiter or the alternator will be damaged....so much for there high performace offering....
To Voltage problem on a 06 C6.
