Steering wheel spokes replacement
Old Apr 14, 2008 | 08:27 PM
marteeni's Avatar
marteeni
Default Steering wheel spokes replacement
Anyone have the instructions from the factory manual or a how-to on doing this? I'm aware that the air bag needs to get dropped from the wheel, but do you need to disconnect it? Dealer wants about 2-hours labor to do this and we all know how we feel about dealers working on our cars.
Old Apr 15, 2008 | 12:06 AM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
2 hours.... OUCH.
This is more like a 15-20 minute max job.
The airbag is held in with a spring that is depressed through small holes in the rear steering wheel cover. If you look on the side of the steering wheel housing youll see the 2 small holes. You press in that hole with a small metal rod the same size as the hole, It then just drops out. No need to disconnect it.
The spoke covers are held in with two torx screws and thats it.
Steps: Disable airbag (or not, at your own risk), Drop airbag out, unscrew 2 spoke screws, replace spokes, install the 2 screws, snap airbag back in place. Done.
Hope that helps.
Ben
Old Apr 15, 2008 | 12:16 AM
Tom_Slick's Avatar
Tom_Slick
Why not just buy painted/ glue on covers? Are they damaged? Are you replacing the whole steering wheel?
Here are the covers I bought from Apsisusa.
Old Apr 15, 2008 | 02:14 PM
marteeni's Avatar
marteeni
Thanks guys!
To Steering wheel spokes replacement
