C6 Navigation System Manual
Old Apr 22, 2008 | 12:05 PM
jimcattani's Avatar
jimcattani
Default C6 Navigation System Manual
I purchased a 2006 Z51 Coupe about 6 months ago. It has the Navigation package. I only received a quick reference guide for the Navigation System. Is there an actual manual for this system? I have a Garmin GPS in my other car and have no problems working it. This Corvette System seems very difficult to use. I try putting in Waypoints but there is no way to tell the System to go to the waypoint. Same goes for recently visited points. Perhaps the manual will help.
Old Apr 22, 2008 | 12:16 PM
johnodrake's Avatar
johnodrake
Moderator
I have a manual in PDF (it's an 05) I will send to you if you like. PM me your e-mail addy. There may be newer ones on line also...
Old Apr 22, 2008 | 12:48 PM
silvr07's Avatar
silvr07
You may want to go to www.mygmlink.com and register your Vette. Then check out the vehicle page. Go to “Glove Box” in the left hand column, and click on it. Then click on Owners Manuals and you should find a copy of the Navigation manual there in PDF format.
Good Luck
Old Apr 22, 2008 | 10:31 PM
haljensen's Avatar
haljensen
The Manual won't help much. The Nav. system is poorly designed and difficult to use.
Old Apr 22, 2008 | 10:48 PM
Vette_DD's Avatar
Vette_DD
I think you'll find a downloadable copy if you click the link in the post for which I've provided a link.
http://forums.corvetteforum.com/show...&postcount=194
Old Apr 23, 2008 | 08:56 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
If you go to www.gmpartshouse.com and hover over the downloads link you'll be able to download one there as well.
Old Apr 25, 2008 | 12:24 PM
jimcattani's Avatar
jimcattani
Much appreciated- please send to my email address: jimcattani@comcast.net. I Would like to start using this GPS instead of moving my Garmin back and forth!
Old Apr 25, 2008 | 12:40 PM
jimcattani's Avatar
jimcattani
Got it- thanks- a lot of reading- hope it helps
To C6 Navigation System Manual
