Brake Fluid help!
Old May 13, 2008 | 08:11 AM
jgraditor's Avatar
jgraditor
St. Jude Donor '08
Default Brake Fluid help!
Changing my calipers to some powdercoated ones, and was wondering what type of brake fluid a 08 z51 would use? Thanks in advance!
Old May 13, 2008 | 08:30 AM
C6~Missle's Avatar
C6~Missle
DOT 3 or 4. I believe it comes with dot 3 stock.. You can use dot 4
Old May 13, 2008 | 08:40 AM
AU N EGL's Avatar
AU N EGL
Castrol LMA or Valvoline Syntec are just fine
Old May 13, 2008 | 08:45 AM
jgraditor's Avatar
jgraditor
St. Jude Donor '08
Thanks!
Old May 13, 2008 | 08:54 AM
johnodrake's Avatar
johnodrake
Moderator
I like Motul RBF600 I use it in the brakes and in the clutch...
Old May 14, 2008 | 10:55 AM
LS3FORME's Avatar
LS3FORME
I like the motul 600 also, it is not the same spec as stock more heat tolerant is it ok with GM , does any body know.?
Old May 14, 2008 | 12:43 PM
AU N EGL's Avatar
AU N EGL
Who cares? Motul is far better brake fluid then GM specs.
GM specs are a bit behind the times for Disk brakes. DOT 3 was designed for drum brakes decades ago.
DOT 4 for brake fluid and clutch fluid.
I personally use Castrol SRF brake fluid in the race car and Castrol LMA in the street vette and the pick up trucks
Old May 14, 2008 | 02:03 PM
FireLikeIYA's Avatar
FireLikeIYA
DOT 3, 4 or DOT 5.1 but definitely not DOT 5. The higher the number the higher the temp rating but it also may absorb water faster and therefore degrade faster which is not the best for a DD.
To Brake Fluid help!
