Z51 Package includes?
Old May 18, 2008 | 05:20 PM
c6 Houston's Avatar
c6 Houston
Default Z51 Package includes?
What all does the Z51 package include?
Old May 18, 2008 | 05:27 PM
redline_ken's Avatar
redline_ken
Z51 Performance Package includes:
-Larger coss-drilled brake rotors, J55 H/D Brakes
-Performance tuned Formula 1 Goodyear Supercar "run flat" tires
-FE3 H/D suspension (stabilizer bars, springs, shocks)
-G90 3.15 performance axle w/limited slip differential
-Power steering, transmission, and oil coolers
and envy from those that don't have it.
Old May 18, 2008 | 05:31 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The 3.15 axle is only for the A6 cars.
The M6 cars get a different set of ratio's and also a transmission cooler.
Old May 18, 2008 | 05:36 PM
VET4LES's Avatar
VET4LES
Old May 18, 2008 | 05:39 PM
redline_ken
I have the A4 Automatic and my window sticker and build sheet both state the G90 - 3.15 axle with my Z51 performance package.
Old May 18, 2008 | 06:13 PM
mcwire's Avatar
mcwire
Old May 18, 2008 | 06:33 PM
Bad06vette's Avatar
Bad06vette
3.42s for z51 m6.
Old May 18, 2008 | 07:00 PM
danl72's Avatar
danl72
Yep, that's it.
Old May 18, 2008 | 07:29 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Originally Posted by Bad06vette
3.42s for z51 m6.
Old May 18, 2008 | 08:20 PM
Ragtop 99's Avatar
Ragtop 99
2.73 is a performance gear in 2008 for an A6 Z51. Was the 3.15 offered in 2005 with the A4?
Old May 18, 2008 | 10:10 PM
dennis50nj's Avatar
dennis50nj
yes the 315 gear was stock as part of the z51 package in 05 a4 z51 also no automatics get a special trans cooler, with the z51 package or oil cooler, they get the normal trans cooler that all automatics have and no oil cooler. gm did some trickery in there advertisements
Old May 18, 2008 | 10:55 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
Default 08 Brochure gear ratios
Reading from the 08 brochure options
2.73 performance axle with paddle shift is available.
2.73 also comes standard in the Z 51 package with the other stuff.
I assume the standard ratio with auto is still the 2.56 same as 07, but I couldn't find it in the brochure.
LJ
Old May 18, 2008 | 11:17 PM
LS1LT1's Avatar
LS1LT1
Not true. The 2.56 gears are standard and 2.73s are optional (as part of the Z51 package or also as a freestanding option).
Yes.
Correct.
Old May 18, 2008 | 11:47 PM
slvr76's Avatar
slvr76
If its a manual tranny you're considering its worth getting the Z51 just for the close ratio gear box IMO. Much better performance over the standard gear box in the first three gears.
Old May 18, 2008 | 11:59 PM
Showdown's Avatar
Showdown
Yes.
Correct.
Old May 19, 2008 | 08:59 AM
Ragtop 99's Avatar
Ragtop 99
The ratios aren't really closer (measured as a percent change between gears), but the gearing is shorter and that was a factor in my decision too.
Old May 19, 2008 | 09:35 AM
haljensen's Avatar
haljensen
1st thru 4th the Z51 manual is a WIDE RATIO gear box.
To Z51 Package includes?
Old May 19, 2008 | 10:59 AM
Former Vendor
Sorry...I meant to say A4. Typo
Old May 19, 2008 | 03:15 PM
Dgatto's Avatar
Dgatto
3:42 gears
Old May 19, 2008 | 04:14 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Guy's I have 07 C6 A6 Z51 and I just installed an exhaust and the rear shows a 2:56 gear, not a 3:15. so how can we be sure the Z51 has as far as gears.
Phil
