C6 Stabilizer Bars
Old May 29, 2008 | 02:45 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Default C6 Stabilizer Bars
What are the sizes (front & rear) for the C6 options & the C6 Z06?
Thanks!
Old May 29, 2008 | 04:22 PM
Modshack's Avatar
Modshack
Here ya go!
Old May 29, 2008 | 04:28 PM
Sully C5's Avatar
Sully C5
Originally Posted by Modshack
Here ya go!
Thanks!
Old May 29, 2008 | 05:11 PM
sthornburg's Avatar
sthornburg
Does anyone know the part numbers for the front and back Z51 sway bars. I called my local dealer to order and they could not find the part numbers. I want to upgrade my C6 bars.
Old May 29, 2008 | 05:17 PM
Keith N's Avatar
Keith N
Get them from Gene at GM Parts House (a forum sponsor).
Old May 29, 2008 | 05:51 PM
NEV3R L8's Avatar
NEV3R L8
So the larger the bar the better the handling basically?
Old May 29, 2008 | 06:18 PM
CMY SIX's Avatar
CMY SIX
yea to a point notice how most of the rear bars are Z-51 size Z06 Z51 front bars are the same size If you have a base model get the bars for a Z-51 and poly bushings and YOU WILL BE AMAZED!!! if you put the Z06 bar on the rear of base or Z51 it will not handle the right way
Old May 29, 2008 | 08:12 PM
NEV3R L8's Avatar
NEV3R L8
So you kinda have to follow a ratio? I already have the Z51 package I was just wondering how that worked. Thanks.
-David
Old May 29, 2008 | 08:22 PM
Radioman's Avatar
Radioman
Is putting the Z51 bars on a Base model a self-help project?
Old May 29, 2008 | 09:00 PM
BlueFish81's Avatar
BlueFish81
GM Parts only has a listing for the front one. I am looking for the bars also, can someone please give us the correct part numbers for front and back bars.
Thank you.
Karn
Old May 29, 2008 | 11:08 PM
danl72's Avatar
danl72
This is a mod I am going to do.
Old May 29, 2008 | 11:53 PM
Pozzo's Avatar
Pozzo
It' fairly easy to do alone. See sticky below.
http://forums.corvetteforum.com/show...09&forum_id=74
Old May 30, 2008 | 09:22 PM
CMY SIX's Avatar
CMY SIX
gene culley at gm parts house sells both bars "a set" lok for may specials about 180.00 shipped and yes you can do this your self in the drive way
Old May 31, 2008 | 12:05 AM
danl72's Avatar
danl72
But most likely you will have to get an alignment correct.
Old May 31, 2008 | 12:06 AM
danl72's Avatar
danl72
It says url not found.
Old May 31, 2008 | 12:14 AM
FIREMANMIKE's Avatar
FIREMANMIKE
I had my C6 sways bars (with F55 suspension) swapped for C6 Z51 units and an alignment done. I hope it gives me the handling I'm looking for!!!
Old May 31, 2008 | 09:51 AM
Modshack's Avatar
Modshack
Don't worry, Sway bars have absolutely NO affect on alignment.
To C6 Stabilizer Bars
Old May 31, 2008 | 10:11 AM
Pozzo's Avatar
Pozzo
Sorry. Go to C6 General Discussion. At top of page click on " Sticky: C6 FAQ (Frequently Asked Questions) (Multi-page thread 1 2 3 ... Last Page)" Scroll down to the section titled "MODS". The Z51 sway bar installation is in there.
Old May 31, 2008 | 03:49 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Thanks for the referrals.
To order you go to the front page at www.gmpartshouse.com. Click where it says search by gm part number. Use part number c6z51bars and be sure to select Chevrolet make.
We have a large shipment coming next week and then we'll get them out to you.
Thanks, Gene.
Old May 31, 2008 | 04:58 PM
danl72's Avatar
danl72
Thanks. That is good to know because that was holding me back.
