One more question - did you end up having so many problems because the transmission was really jacked up, because the dealership was incompetent or a little of both?
nope it was a typical tsb about mismachined case the shift solenoids get clogged in the screen so change if happens again tear out trans and clean inspect rebuild, they just kept changing the solenoids instead of fixing and the tech screwed up. my first trans ran cooler on a hot 95degree day in traffic with the c3800 converter then the new trans with stock converter on a cold day while cruising, even after all the over heating problems and all 4 lines changed they didn't change the fluid or screen, i asked them don't you think you should change it and they said nope if it breaks we will replace under warranty. so i say the tech is bad. and gm is to if they didn't insist
TM intervenes most when you hook up well, thats why most folk's 60fts suck even though they get decent traction. The harder you hook with TM still present in tuning, the more torque it reads and pulls back power accordingly.
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Dang, I hope don't end up going through anything even remotely close to that!
If I leave TM on during shifts, on my scanner I see the timing drop off by several degrees.
Since I'm not seeing that happen during launches, where and how is TM still being implemented?
It's in the tables that you don't see yet...you may have reduced (eliminated?) TM from the various tables/cells that you (or your tuner) have discovered but how do you know that you've uncovered all of the tables, ESPECIALLY on the newer 2008s?
It's in there somewhere, it's a sneaky little system that will not go down without a fight LOL.
I just posted a thread on HP's website to see what their thoughts are on the subject.
From what I understand, they are uncovering new tables all of the time, they are constantly working towards accessing new files and allowing more and more parameters to be altered, at least I hope that they are LOL.
Do keep in mind that some of the answers you might get from the likes of an HP Tuners or EFI Live employee might not be telling the entire story. Afterall they are in the business of selling this programming and it's certainly not in their best interest to outright tell people "no, we haven't uncovered all areas of your PCM yet, we're still working on it so you should wait a few more months before you buy our products". They want you to buy it now, not later.
Of course they are awesome when it comes to providing their customers with updates and revisions but what does that tell you?
That they are in fact constantly working on/uncovering new tables (TM) as I'd mentioned above.
I was out tonight in the 08, and just don't get this TM thing. I don't feel it hold me back at all, and I did a bunch of hard pulls tonight with the R888s!!!
Maybe you guys need to send your PCM to Charlie...
JB
Proper tires on a prepped track will avoid accidents and damage to the driver which cant be fixed. Be careful.
Manual transmissions dont fare well wth short sidewall drag radials on a prepped track. A dedicated 17" rim with a MT will lessen the shock to a manual's driveline. BFG's dont flex any and wind up snapping parts or making the clutch slip a bit. Your trap speed indicates a 1.6x 60' will result in a 11.5-11.6.
JB
Charlie is one of the best, and the m6 can have TM reduced, but shouldnt you get atleast 1.5s 60 fts with 450rwhp if you have no TM
I only launched at around 4000 RPM when I hit my 1.6s 60 ft. I imagine I could drop down to 1.5 if I launched closer to 6000 RPM. I'm just not sure I want to risk tearing up my diff or driveline for the extra tenth or two. I do have a unitrax built/cryoed diff with hardened shaft, but I also run on MT DR with a short sidewall...
I'd rather leave some on the table, and go out and do what these cars were really made for the next weekend: ROADRACING!!!!
1.5s at the very worst I would think. At that power level and weight the car could hit high 1.4s easily.
Yeah I can understand wanting to protect your rear and all but still...going through ALL that effort to mount DRs, make a trip to the drag strip (in some cases a drag strip hundreds of miles away ) and not at least make one all out launch attempt to show just what that Torco and Charlie have done with the car?
You have some will power man!
yes i omly have maybe 408rwhp 408 rwtg leave at an idle 1.4s no problem, and i still have TM. I HAVE THE WEAKEST C6 REAR 05
Good point.
Even though Joel's car is a manual, his 2008 rear is also FAR stronger than yours. He has PLENTY of room to hit it harder off the line without breaking it, especially being the excellent driver that he is.
C'mon Joel, launch that **** and let's at least see some low 1.5s.
Good point.
Have you guys forgot that the 08 is just my backup/wife friendly vette. The 98 is the hardcore vette. If I break the 08, and the 98 goes down, I'll have severe withdrawls...
On a side note, I should have some fresh pulls this weekend on video in the 08!! I've been playing around with different plugs, and may have found one that my combo REALLY likes!!! Man she pulled hard last night, almost felt like a bit of boost!
