plug wires??
Old Jun 18, 2008 | 09:55 PM
GREG O.'s Avatar
GREG O.
Default plug wires??
Want to change wires. I noticed my Delco's are only 7mm. Any ideas to who sells the best wires for a 500rwhp N/A zo6? thanks Greg
Old Jun 18, 2008 | 10:00 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
WCC
Old Jun 18, 2008 | 10:10 PM
glennhl's Avatar
glennhl
I've read that the 7mm GM wires are as good as any. I'm surprised that you want new wires other than the 8mm will look bigger.
Old Jun 18, 2008 | 10:30 PM
GREG O.'s Avatar
GREG O.
i laid into my vette yesterday at 120 degrees coolant temp. and it ran it's azz off with a little sputtering at the higher rpm. When the collant temp hit 200 degrees it sputters and spits. very aggravating! Any way b/4 it goes into a shop I changed my NGK tr55's and put new 55's back in. Same result. I have been told the wires probably need to be changed. I was just surprized they were 7mm. I am getting NO check engine light I just want to change these delco,s. They have the protective metal heat shields on them and they look ok, but they just can't take the heat.
Old Jun 18, 2008 | 10:37 PM
GREG O.'s Avatar
GREG O.
Default wires
Originally Posted by TommyV
Tommy i think thats what i need. i hope i can buy them ready to install instead of having to assemble
Old Jun 18, 2008 | 10:53 PM
EuroRod's Avatar
EuroRod
Several forum vendors sell upgraded ignition wire sets. Check around.
Old Jun 19, 2008 | 03:10 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Get Msd they are really improved to a nice wire! Some buddy going to chime in and "say save your money blah blah . I had the stock wires and with Ngk's gapped aroud ..060. I took them back out, in favor of the stock plugs. Then I switched to the msd with the Ngk's indexed at the out the box .059. Runs better all the way round! You won't gain any with out opening your plug gaps. The msd's allow a wider gap
do to the less resistance of the wire. They allow more current and voltage to the plug.
Old Jun 19, 2008 | 11:52 AM
vettl83's Avatar
vettl83
Callaway wires here with Kooks headers and Maggie on board = zero issues.
Old Jun 19, 2008 | 04:41 PM
MTI RACING's Avatar
0MTI RACING
Former Vendor
Default MTI Racing Plug Wires
Feel free to look at our MTI Racing Plug Wires.
They are made by the same constructor who makes high energy ignition wires for IRL and Daytona prototype racecars.
They consist of:
- High energy wire-wound core with 7mm Silicone insulation jacket
- Stainless steel terminals for superior corrosiion resistance
- High temperature silicone boots
- Silicone over Fiberglass Heat Sleeving adds additional heat and abrasion protection to wire.
- Fits with or without headers
- Resistance of only 180-200 ohms
Price $100
Items are located HERE:
http://www.mtiracing.com/artmaverick...kwirescar.html
Old Jun 20, 2008 | 09:08 AM
RFP's Avatar
RFP
St. Jude Donor '09
Any radio 'static' problems when using these wires?
[QUOTE=MTI RACING;1565966199]Feel free to look at our MTI Racing Plug Wires.
They consist of:
Price $100
Old Jun 20, 2008 | 10:26 AM
MTI RACING's Avatar
0MTI RACING
Former Vendor
No problems at all. We are extremely happy with the product!
Old Jun 20, 2008 | 02:35 PM
SoCalPhil's Avatar
SoCalPhil
Default Go W/ MTI Racing
No problems at all, and my tuner noticed a nice difference between the O.E.M. and MTI.
No radio static or any other problems.
Old Jun 20, 2008 | 07:40 PM
Gene Gorman's Avatar
Gene Gorman
I have had my Callaway wires on with headers for over a year now with no problems.
Old Jul 7, 2008 | 06:37 AM
GREG O.'s Avatar
GREG O.
Default wires
Man, I found the problem. I put the 8.5 MSD wires on and it runs like a champ. the thicker wires are more heat resistent. I will NEVER buy a Delco 7mm wire again. Plus the metal heat shields fit MUCH better on the MSD's. Anyway thanks everyone for the advice.
Old Jul 7, 2008 | 08:22 AM
MTI RACING's Avatar
0MTI RACING
Former Vendor
Default MTI Racing - Plug Wires
Our wires are available for purchase online at you r convenience HERE:
Old Jul 7, 2008 | 09:26 AM
Gene Gorman
Same here no problems.
Old Jul 7, 2008 | 11:49 AM
3 Z06ZR1's Avatar
3 Z06ZR1
To plug wires??
Old Jul 8, 2008 | 10:32 AM
AintQik's Avatar
AintQik
I hate MSD. Garbage. Local tuner makes wires like MTI. Good stuff.
Old Jul 8, 2008 | 01:30 PM
glennhl's Avatar
glennhl
No, thank you for your advice. I'll go to the 8.5's if I need new wires.
Thanks,
Glenn
Old Jul 8, 2008 | 04:16 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Your nuts, they have improved, from the old MSD's which were not top notch, Now they are one of the best wires out! Try a new set you will be happy you did. They allow opening the plug gap to .060 which the stock wires show missfire with the .060 gap on the dyno.
