Question,,
Old Jun 21, 2008 | 04:27 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Default Question,,
What's the tallest front tire that will fit on a C6{stock front fenders}
My M and H drag radials will be here soon and I have to find a front tire to match it with.{rear tires will be 345/35/18's with height of 28"}
Old Jun 21, 2008 | 05:11 PM
BEZ06's Avatar
BEZ06
I guess what you're worried about is issues with the ABS.
Your DR's will be just slightly more than 1 inch greater in diameter than a stock rear tire. I don't think that's enough to bother anything, but it might.
I certainly don't think you'd have any problem putting an approximately 1 inch greater diameter front tire on to maintain the ratio between front and rear to avoid ABS problems.
Butt....I don't think you'll have a problem running your DR's with stock size front tires.
I have a neighbor with a set up similar to yours. He's got an LS2 with a S/C and runs Mickey Thompsons on the rear (I think in the size you're talking about, and stock size up front). He hasn't had any problems at the track - except for getting kicked off when doing 10.91 with no cage!!
If you want to contact him his forum handle is "klancy kat", but I don't think he checks on too frequently. If you can't get him to respond to a PM let me know and I'll get his phone# if you want to see exactly what his tire set up is.
Bob
Old Jun 21, 2008 | 05:40 PM
1bdasvt's Avatar
1bdasvt
Thanks Bob!
If You can pm Me His # that would be great!!
Old Jun 21, 2008 | 06:14 PM
BEZ06's Avatar
BEZ06
I just talked with Gary and he said he'd be glad to talk to you, and he may have already in the past.
He was out to dinner so I didn't want to bother him, but I briefly explained what you wanted to talk about. I believe he said that he thinks the 28" diameter may be too tall and really mess with your overall gear ratio, even with a 3.15 rear end. But, give him a call and see what he has to say. He's been doing a lot of drag racing lately so has some good experience to pass on.
PM sent with his cell#.
Bob
To Question,,
