gears!!!
Old Jun 29, 2008 | 06:26 PM
james1990's Avatar
james1990
Default gears!!!
im looking to put gears into my 08 z51 A6 , any feed back and opinions would be a big help thanks
Old Jun 29, 2008 | 06:38 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
If you do a search you will get a wealth of information. Unfortunately you will have to weed thru all the BS to actually learn anything. You're best bet is to call this number and ask for Chuck.
914-332-0049
http://www.corvettes-of-westchester.com/main.htm
Old Jun 29, 2008 | 06:45 PM
xstang's Avatar
xstang
If I ever do gears on my A6, I'll do 3.42s
Old Jun 29, 2008 | 07:31 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
914-332-0049
Old Jun 29, 2008 | 07:32 PM
knkali's Avatar
knkali
3.15s here. THE BEST mod to date
Old Jun 29, 2008 | 10:39 PM
A-Pex's Avatar
A-Pex
Except it's WHEN I do gears.
Old Jun 30, 2008 | 04:59 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I've had both 3.15 and 3.42 gears in my A6 so allow me to chime in.
Performance-wise at the track or just driving around town, both will be an excellent improvement over the stock 2.56 or 2.73 gears. There is however virtually no difference between the 3.15 and 3.42's as to how fast it'll run and I have the timeslips to back it up.
On the freeway the 3.15's will get slightly better gas mileage than the 3.42's, but the 3.42's will make 6th gear very responsive to the point where if you need to pass somebody you'll be able to do it without having to downshift.
PM me if you have any other questions.
Christopher
Old Jun 30, 2008 | 08:09 AM
Max@Cartek's Avatar
Max@Cartek
We've done a bunch and could get you all setup with a set if you like. Give us a call if you are interested.
Thanks,
Max
908.317.4496
Old Jun 30, 2008 | 10:34 AM
HP JNKEY's Avatar
HP JNKEY
I went from 2:73's to 3:15's with great results.
I felt sorry that I didn't install 3:42's but Subfloor has confirmed that there is basically no difference in 1/4 mile performance. Thanks for that Christopher.
With the price of gas going up, install 3:15's and get the best of both.
Old Jun 30, 2008 | 11:13 AM
james1990's Avatar
james1990
what is the difference between the different gears? i know that 4:10's are only good from a stop. i would like something all around better..i do not track the car
thanks for all the input
Old Jun 30, 2008 | 11:15 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Christopher is the only person on this forum that has done testing with both 3:15,3:42`s with a stall convertor and has backed up his testing at the track!
Thanks Chris for all the information and the track results!
Here is a chart that Ragtop99 posted.
Old Jun 30, 2008 | 11:45 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Feel free to call the shop if you would like to discuss options and pricing. Here is our present specials, be sure to not over pay.
http://www.eastcoastsupercharging.com/Gears.html
Old Jun 30, 2008 | 12:11 PM
007vette's Avatar
007vette
This may be a stupid question but how do you find out what your Gear Ratio is?? I have a 2007 Corvette Coupe 6spd manl.
Old Jun 30, 2008 | 12:18 PM
thesubfloor
If you climb under the car, there's usually a sticker showing the gear ratio on the underside of the differential. It's pretty easy to see.
Old Jun 30, 2008 | 01:41 PM
HP JNKEY's Avatar
HP JNKEY
All manual's have 3:42 gears in stock form.
Old Jun 30, 2008 | 01:46 PM
thesubfloor
Yes, that is true but a 3.42 in a manual transmission car isn't the same as one in an A6 car.
Old Jun 30, 2008 | 02:02 PM
DOUG @ ECS's Avatar
DOUG @ ECS
but then the sticker on the rear would not be right anyway since it is an aftermarket build anyway.
To gears!!!
Old Jun 30, 2008 | 02:10 PM
A-Pex's Avatar
A-Pex
Christopher
Christopher, did you also have a stall converter installed with either of the above ratios? If so, for which set of gears if not both? Also, were your 1/4 mile times with/without the converter(s)?
Old Jun 30, 2008 | 02:11 PM
thesubfloor
That is true, but at least you'd know what the car came with originally.
Having it still on there however is probably a good idea as you'll be less likely to draw attention to yourself if the car ever ends up on a lift at a dealership.
Old Jun 30, 2008 | 02:14 PM
thesubfloor
Yes, I did have a 3000 stall converter with both of the rear ends and all of my times were with the converter.
